My Auto Events Preregistration
Last post 01-29-2010, 4:54 PM by Eclipse2Lancer. 8 replies.
  •  01-27-2010, 3:55 PM 400482
     For some reason My Auto Events is not letting me preregister under the SMS class. Doesn't even give me that option. When I preregister it shows up unclassified. Anyone know anything about this? Never had any trouble last year. How can I fix it?
    Kevin Miller SMS 11 2000 ITR
  •  01-28-2010, 9:02 AM 400583 in reply to 400482
    Re: My Auto Events Preregistration
    I'm betting Scott might be having some troubles setting it up. I'm sure he will get it all figured out soon.
    89/189 STS Miata
    Clemens:
    Shahab has it figured out
  •  01-28-2010, 9:39 AM 400592 in reply to 400583
    SMS should be on the list.  I'm showing you as registered in SMS Kevin so you're all set.
    Scott T.
    SCCA Member 401575
    91 Saturn SC - FSP/ITA 16
    2010 Indy Region Solo Chair
    indyregionsolo@sbcglobal.net
  •  01-28-2010, 5:27 PM 400653 in reply to 400592
     I didn't have any problem when I reserved my number for the season. However, when I tried register for the first couple of events, SMS was not an option. I noticed that a couple of other people had the same problem. Not a big deal, I just wasn't sure if there was something I was doing wrong.
  •  01-29-2010, 8:48 AM 400731 in reply to 400653
    Ah, yep...I left SMS off my custom "event" list...
    Fixed it though and you're in SMS where you should be. Smile
    Scott T.
    SCCA Member 401575
  •  01-29-2010, 12:30 PM 400762 in reply to 400731
    Scott, I had a little trouble too.  I wanted 190 but got 90. Could that be because I've already got it reserved from last year?
    90 Miata - STS #90/190
    If it aint broke, don't fix it.
  •  01-29-2010, 1:44 PM 400780 in reply to 400762
    Nope, none of the numbers from last year got carried over.
    I'll look into it tonight for you, Geoff.
    Scott T.
    SCCA Member 401575
  •  01-29-2010, 4:16 PM 400799 in reply to 400731
     Sank you veddy much!
  •  01-29-2010, 4:54 PM 400804 in reply to 400762
    GChambers:
    Just looked.....exactly the case. The '2010 Reserved Number' event was referencing the '2009 Reserved Number' event for numbers saved for some reason. I turned it off, so should be fine now.
    Scott..... for the events you have set up for the season, make sure you make the event "reference" the 2010 Reserved Number entries (on the bottom of the page where you can edit registration form fields....should be a drop down box asking "Event to use for reserved numbers").
    -Will
    Will Lahee -- Indy Region
    Section 8 Racing
    Knowledge is realizing that the street is one-way, wisdom is looking both directions anyway
