SCCA News and Racing Information. Racing Forums, Racing Discussions and Blogs.
                                            WoodHouse Motorsports
Click to get your ad featured here TODAY! Click here to read up to date SCCA racing news!
Clarification - How to calculate front splitter / spoiler area for ST?
Last post 07-05-2009, 9:45 PM by first350. 0 replies.
  •  07-05-2009, 9:45 PM 367992
    I've searched and can't find clarifcation on how to calculate the SA (Surface Area) for Splitters/Spoilers, is it:
    1) the actual/real SA (taking into account for any curvature)
    2) calculated similar to a rear wing
    3) surface area as veiwed from above
     The rules appear to only give guidance for a rear wing (section 12.9)...I would assume method #1 is correct b/c the rules don't give guidance to calculate it any other way, so the actual SA would seem most logical (unless I've missed a rule somewhere).
    I've got a front lip that I'd considered a splitter...it's got about 2 inches of vertical curvature, and sticks out about 3 inches in the middle.
    I've also got the "standard" CSP miata spoiler...the rule only gives guidance for a rear wing.
     Thanks!!!
    14.2 F...
    Surface area of all splitters, spoilers and rear wing (see 12.9)
    shall not exceed 5 square feet in sum total. Substitution of rear
    spoilers or wings must retain any original third brake light functionality
    unless otherwise equipped. No underbody panels may
    be added or substituted. The drilling of holes for the purpose of
    mounting these pieces is permitted
    12.9 WING AREA COMPUTATION
    The area of a wing element shall be computed by multiplying the
    maximum chord (straight line distance from leading edge to trailing
    edge) by the maximum span (width). Curvature of the element
    (camber) and angle of attack when mounted on the vehicle will not
    affect the area measurement. The area for multiple-element wings
    will be the sum of the individual areas of each of the elements. Any
    airfoil shadowed by another airfoil with more than six inches between
    them will have its own projected area added to the wing area
    calculation. Any diffuser-type aerodynamic device under the car
    which is used in downforce generation is not included in the wing
    area calculation.
    1993 STS Miata
    retired:
    BSP 350Z
