SCCA News and Racing Information. Racing Forums, Racing Discussions and Blogs.
                                            WoodHouse Motorsports
Click to get your ad featured here TODAY! Click here to read up to date SCCA racing news!
So i went to install new front rotors...
Last post 07-24-2009, 10:06 PM by sknlim. 21 replies.
Page 1 of 2 (22 items)   1 2 Next >
  •  07-03-2009, 1:29 PM 367832
    on my 89 Civic Si that i just picked up and notice the one's that came on the car are 1/2" larger then the 9.5" Power Slot's that I wanted to install. Any ideas/tips on what I will need to fit the 9.5" rotors.
  •  07-03-2009, 3:20 PM 367839 in reply to 367832
    Re: So i went to install new front rotors...
    I don't understand your dilema, if the new rotors are smaller they should just fall right into place.  Unless, the caliper bracket modified as well.  If not, it should be a plug and play type of install.
  •  07-03-2009, 4:39 PM 367840 in reply to 367832
    sknlim:
    One of the Civics that I bought came the same way.  90-91 rotors are bigger than 88-89 and that is what was on there.  I just put the correct ones on and it was all good.
    --Andy
  •  07-03-2009, 7:37 PM 367857 in reply to 367840
    I tried what you suggested and the hub is also bigger. The 9.5" rotors will not fit. Here's a picture of the setup.
  •  07-04-2009, 10:12 AM 367894 in reply to 367857
    are the larger rotors legal in ST? What about the caliper?
  •  07-04-2009, 1:02 PM 367898 in reply to 367832
    • jsi is not online. Last active: 04/07/2010, 6:07 PM jsi
    • Joined on 08-21-2002
    • Montreal, Canada
    • Posts 97
    • Points 1,760
    Possibly swapped EX sedan knuckle/brakes?
  •  07-04-2009, 2:13 PM 367899 in reply to 367898
    jsi:
    Yea, that is what it looks like to me with those brake calipers!!!
    Thats not bad news you can sell those and get the correct ones..
    Kerry
    Kerry Coughlin
    1988 Honda CRX SI
    191 STS
    Cenla Region SCCA
  •  07-04-2009, 5:09 PM 367902 in reply to 367857
    sknlim:
    While you're in there, get some new axle nuts. No telling how many times those have been re-used.
    Jim Plotkin
    '05 FSP Echo
  •  07-04-2009, 8:02 PM 367912 in reply to 367902
    Went to the local Pick N Pull and i think they are from the older Integras.
    What will i need to swap these out? I already have new pads,rotors,brake lines.
    Are all 88-91 Civic front knuckle and calipers the same?
  •  07-04-2009, 8:05 PM 367913 in reply to 367902
     Both axle are shot and will be replaced.
  •  07-05-2009, 10:22 AM 367935 in reply to 367912
    sknlim:
    HAP (Honda/Acura Parts) in Rancho Cordova can tell you what interchanges. Also, it would be wise to change the balljoints.
    Jim Plotkin
    '05 FSP Echo
  •  07-05-2009, 3:57 PM 367957 in reply to 367832
    I just took the rotors off of my 90 Si and ran into the same thing.  I had 90 Integra front calipers and 95 EX rear trailing arms with disks on the rear.  Apparently these are the most popular "junkyard" items that fit the EF civics.  Since I'm running STX this year it isn't a big deal but since I am in the process of STX to ST I ran into this and decided to research what I had.  I haven't put the stock parts on from another donor car yet to know if the calipers will fit or if I will need to swap the spindles too, they LOOK like they will be ok, but I will see once I get to the point of buttoning everything back together.
    M. Posey
    ST Civic
    Atlanta Region
  •  07-05-2009, 5:28 PM 367968 in reply to 367957
    MPosey:
    The DA Integra calipers typically require the DA Integra spindles, which is not allowed in STX.  Nor is the swap of the rear trailing arm legal.  So you need to fix it anyway.  And while you are picking up parts, you'll need the right e-brake cables for the drums since the disc uses a different length.
    Lots of good info in the H-T EF Civic/CRX FAQ.
    --Andy
  •  07-05-2009, 5:29 PM 367969 in reply to 367957
    MPosey:
    I'm going to pick up the knuckle assembly and caliper and just be done with it. Maybe i can find someone local to swap mine for theirs..
  •  07-06-2009, 7:46 AM 368059 in reply to 367968
    Andy Hollis:
    MPosey:
    --Andy
    Good Point Andy.  I found out the spindles on the donor car have new ball joints anyways so I will swap the spindles just to be safe and have new ball joints (plus everything is torn apart now, there won't be an easier time to swap everything).  The ebrake cable will have to be checked once I get the other parts up and on the car, hopefully it will work.  Probably wont.  For just changing the transmission and swapping brakes I sure feel like I have taken off a ton more parts that I thought I was going to.  And there is the "well since I have it apart" part replacement thing too...  But it will be ST legal and I will freaking know what parts to buy, I had to guess twice when I bought new brake pads since I thought it was simply CRX parts for the brakes...
    M. Posey
    ST Civic
    Atlanta Region
