Blytheville Pro Solo Index Results
Last post 06-22-2009, 10:53 AM by Dave Schotz. 26 replies.
Page 1 of 2 (27 items)   1 2 Next >
  •  06-08-2009, 7:27 AM 364284
    Attached is a PDF of the Final Pro Solo Index Results.  I will post Left & Right Results in the following two posts.  These three sets of results use the Pro Solo Index Factors, NOT the PAX/RTP factors.
    H's & K's,
    Rick Ruth
    EDIT: I have replaced all of the PDFs in these posts at about 8:52am CST.  There were, apparently, some errors in the original posts.  Hopefully, I have corrected them.
    EDIT 2:  I have, again, replaced all of the PDFs (at 1:52pm CST).  I had Erik Strelnieks Actual Time computed incorrectly.  Gee, I hope that's all.
  •  06-08-2009, 7:28 AM 364285 in reply to 364284
    Re: Blytheville Pro Solo Index Results
    Attached is a PDF of the Left Side Pro Solo Index Results.
    H's & K's,
    Rick Ruth
    EDIT 3: I posted the correct list at 4:18am CST on 6/9/09.  Sorry.
  •  06-08-2009, 7:30 AM 364286 in reply to 364285
    Attached is a PDF of the Right Side Pro Solo Index Results.
    H's & K's,
    Rick Ruth
  •  06-08-2009, 7:32 AM 364288 in reply to 364286
    Attached is a PDF of the Final Pro Solo Index Results using the PAX/RTP Index factors.  I will post Left and Right side results using these factor in the following two posts.
    H's & K's,
    Rick Ruth
  •  06-08-2009, 7:33 AM 364290 in reply to 364288
    Attached is a PDF of the Left Side Pro Solo Index Results using the PAX/RTP Index factors.
    H's & K's,
    Rick Ruth
  •  06-08-2009, 7:34 AM 364291 in reply to 364290
    Attached is a PDF of the Right Side Pro Solo Index Results using the PAX/RTP Index factors.
    H's & K's,
    Rick Ruth
  •  06-08-2009, 8:41 AM 364298 in reply to 364291
    • ron is not online. Last active: 03/20/2010, 6:42 PM ron
    • Top 200 Contributor
    • Joined on 03-03-2003
    • Topeka Ks. U.S.
    • Posts 464
    • Points 7,610
    You might want to check your figures again, The majority of your index results are wrong becouse the actual times  that were user to make it are wrong. Your origional post figures are correct actual times.
    Ron Williams
    Multi-time national champion
  •  06-08-2009, 9:55 AM 364309 in reply to 364298
    Hopefully, I have corrected the errors in my original PDFs.  Thanks, Ron, for the heads-up.
    H's & K's,
    Rick Ruth
  •  06-08-2009, 11:40 AM 364330 in reply to 364309
    Thanks Rick!  Once again, I like the RTP results a good bit better. ;-)
    2006 GS National Champion
    2007 GS National Champion....Runner up lol
    2008 GS National Champion
    2009 BSP National Champion....Runner up, lol again, although, not so funny lol
  •  06-08-2009, 12:03 PM 364341 in reply to 364330
    OasisTan:
    No way... PRO index is MUCH MUCH better!
    Shawn Hill
    07 Mini Cooper HS
    Kansas City Region SCCA
  •  06-08-2009, 12:18 PM 364343 in reply to 364309
    Something still seems a little off, at least in the Pro Index results.  Erik Strelnieks in shown as sharing 123rd with Lori Gill after winning SSM?
    Christine Berry
    2006 Mitsubishi Evo RS, BSP
  •  06-08-2009, 2:26 PM 364364 in reply to 364343
    RaceChickSolo2:
    I'll look at it again.
    H's & K's,
    Rick Ruth
    EDIT:  I have, again, replaced all of the PDFs (at 1:52pm CST).  I had Erik Strelnieks Actual Time computed incorrectly (it shouldn't have been computed at all).  Gee, I hope that's all.  Thanks Christine.
  •  06-08-2009, 9:43 PM 364454 in reply to 364364
    • Topeka Ks. U.S.
    • Posts 464
    • Points 7,610
    I got to say that the HS change is wrong in so many levels, This particular pro had no long straight for the faster cars to take advantage of and HS ended up doing ok in the pro index. But... your rtp index places the top two drivers in the pro index way below many other classes that had multiple drivers in higher spots. SS had three above the top HS driver. I would agree HS should have been changed slightly, but, about half of what it actually did change. Again multiple drivers at nationals per class were ahead of the top drivers in H and yet the index changed. Now H cars don't have a chance in haiti's  to win the index. Just an opinion of course.
    Thanks for all you do Rick
    Ron Williams
  •  06-09-2009, 3:11 AM 364486 in reply to 364454
    OK, now the left Pro index is actually the left PAX/RTP.
    David Avard
    89 Honda Civic Si black (STS)
    07 Mazda 3s (HS?)
  •  06-09-2009, 5:19 AM 364489 in reply to 364486
    Davard:
    Geesh.  I posted the correct list at 4:18am CST on 6/9/09.  Thanks, David.
    H's & K's,
    Rick Ruth
