Lincoln Pro Solo Index Results
Last post 05-07-2009, 1:46 PM by TedDBere. 20 replies.
05-04-2009, 6:55 AM |
rtp.rick
Joined on 05-11-2001
O'Fallon, MO USA
Posts 1,341
Points 18,065
Attached is a PDF of Pro Solo Index Results from the Lincoln Nebraska Pro Solo. These are figured using the Pro Solo Index factors. I will post Results using the PAX/RTP factors in the following post.
EDIT: Due to an error in computing the Actual Time for a driver, I have replaced the attached PDF on May 5, 2009 at 1:10pm.
H's & K's, Rick Ruth
05-04-2009, 6:57 AM |
rtp.rick
O'Fallon, MO USA
Posts 1,341
Points 18,065
Re: Lincoln Pro Solo Index Results
Attached are Index Results from the Lincoln Nebraska Pro Solo using the PAX/RTP Index factors.
05-04-2009, 1:42 PM |
OasisTan
Joined on 06-23-2004
Blue Springs, MO
Posts 1,030
Points 12,515
Me likey the PAX much better! ;-) It seems to me some of the Pro indexes went the wrong way in comparison to RTP-PAX. How can an AWD class go DOWN for Prosolo along with other classes that have the ability to launch well to use the 200'+ straight to their advantage. I never really looked at the prosolo index until I was put into the Bump class. The Prosolo index seems a good bit off to me for a few classes.
2006 GS National Champion 2007 GS National Champion....Runner up lol 2008 GS National Champion 2009 BSP National Champion....Runner up, lol again, although, not so funny lol
05-04-2009, 3:06 PM |
sm2dan
Joined on 12-27-2000
Round Rock, Texas. y'all
Posts 714
Points 9,625
OasisTan:. The Prosolo index seems a good bit off to me for a few classes.
understatement of the year!
Dan Pedroza CS 72/172 2008 Nationals CS first loser Defending 2009 Nationals CS first loser
05-05-2009, 7:28 AM |
rtp.rick
O'Fallon, MO USA
Posts 1,341
Points 18,065
Zauskycop:Prosolo Index link not working...RTP works fine
It opens okay for me, Tracy. Are you using a newer version of Acrobat Reader? No one else seems to have complained. I really wouldn't know what to do to fix your problem.
05-05-2009, 8:55 AM |
gregmeier
Joined on 12-01-2005
Downers Grove, Illinois
Posts 236
Points 2,720
RR said " I really wouldn't know what to do to fix your problem."
Geez Rick...I could have a field day with that one!!! No one knows how to "fix" Ramsey!
H&K's right back at you!
Greg M. Keeper of one of the most successful Toyota Spyders in autox! AtTrack Graphics/Skull Motorsports/Top Dog Productions/Karol, Alex and Jessica
05-05-2009, 10:59 AM |
KevinDietz
Posts 57
Points 875
The Pro index is way off on some classes. Just look at the GS Pro index as an example. No one at the SCCA does the hard data work to support their index numbers it's all a guesstimate.
How to make your car faster. 1. Bigger Engine 2. Bigger Tires 3. Bigger Brakes 4. Or just give me the keys!
05-05-2009, 12:46 PM |
rtp.rick
O'Fallon, MO USA
Posts 1,341
Points 18,065
gregmeier:
I answered that way on purpose. And, I repeat, I really don't know how to fix Tracy's probelm(s). As you suggest, I don't think anyone can. We all love him anyway, though.
05-05-2009, 12:52 PM |
Davard
Joined on 12-30-2000
Topeka, KS
Posts 1,258
Points 19,110
KevinDietz:The Pro index is way off on some classes. Just look at the GS Pro index as an example. No one at the SCCA does the hard data work to support their index numbers it's all a guesstimate.
[edit] found an error, which I sent to Rick, which makes this post irrelevant.
David Avard 89 Honda Civic Si black (STS) 07 Mazda 3s (HS?)
05-05-2009, 1:11 PM |
Davard
Topeka, KS
Posts 1,258
Points 19,110
In a somewhat related note, does someone (Darrin?) still post the reaction and 60-foot times on here? I saw them posted at the event, but didn't bother to write things down.
05-05-2009, 2:10 PM |
rtp.rick
O'Fallon, MO USA
Posts 1,341
Points 18,065
Due to an error in computing the Actual Time for a driver, I have replaced the above, attached PDFs on May 5, 2009 at 1:10pm.
Oh, and David, you are correct, Darrin usually posts the 60 ft. times. We may have to give him time to get back to Florida before he is able to do that. :-)
Sorry for the inconvenience, with Numerous H's & K's, Rick Ruth
05-05-2009, 6:14 PM |
ddisimo
Joined on 08-26-2003
Coral Springs, FL
Posts 94
Points 1,915
Here is the requested RT/60ft times from the Lincoln Pro. And Rick is correct. I needed some time to get back to Florida. 28+ hour drive is a long one. Here ya go.... Darrin
05-05-2009, 7:08 PM |
Mark Duerst
Joined on 02-20-2001
San Diego,CA,USA
Posts 40
Points 535
So Darrin
When do we get the Lincoln "lifestyle" report?
Mark Duerst
Page 1 of 2 (21 items)
