El Toro Pro Solo - Pro Solo Index Results
Last post 04-02-2009, 12:18 AM by imstimpy. 14 replies.
03-30-2009, 6:54 AM |
rtp.rick
Joined on 05-11-2001
O'Fallon, MO USA
Posts 1,341
Points 18,065
Attached is a PDF of the Pro Solo Index Results from the El Toro Pro Solo. These results are calculated using the Pro Solo Index factors, NOT the PAX/RTP Index factors. I will post Left and Right Side Results in subsequent posts, followed by Results using the PAX/RTP factors.
EDIT -- I lied, I did them manually. New PDFs have been posted for Final, Left Side, Right Side using both the Pro Solo and PAX/RTP factors.
H's & K's, Rick Ruth
03-30-2009, 10:07 AM |
rtp.rick
O'Fallon, MO USA
Posts 1,341
Points 18,065
Re: El Toro Pro Solo - Pro Solo Index Results
Attached are Left Side Results using the Pro Solo factors.
EDIT -- I corrected the file. A new PDF is attached.
H's & K's, Rick
03-30-2009, 10:08 AM |
rtp.rick
O'Fallon, MO USA
Posts 1,341
Points 18,065
Attached are Right Side Results using the Pro Solo factors.
03-30-2009, 10:09 AM |
rtp.rick
O'Fallon, MO USA
Posts 1,341
Points 18,065
Attached are Final Results using the PAX/RTP factors.
EDIT - I updated this PDF.
03-30-2009, 10:11 AM |
rtp.rick
O'Fallon, MO USA
Posts 1,341
Points 18,065
Attached are Left Side Results using the PAX/RTP factors.
03-30-2009, 10:12 AM |
rtp.rick
O'Fallon, MO USA
Posts 1,341
Points 18,065
Attached are Right Side Results using the PAX/RTP factors.
03-30-2009, 10:22 AM |
SteveEkstrand
Joined on 01-23-2001
Pasadena, CA USA
Posts 355
Points 5,930
On the right side results something looks wrong. I checked my actual time and a few friends and they were all off. I saw some that looked correct, though.
Dr. Conemangler #15 STS '91 Civic Si CalClub
03-30-2009, 10:43 AM |
Ken Motonishi
Joined on 11-08-2002
Orange, CA
Posts 307
Points 6,205
A lot of the right side runs are based off of Saturday's results, not Sunday's- which in many cases involved a faster time. # 1-5 (Cawthorne, Fraser, Strelnieks, Braun and McKee) are based on Saturday's. # 6 Smith is based on Sunday's.
03-30-2009, 11:09 AM |
rtp.rick
O'Fallon, MO USA
Posts 1,341
Points 18,065
I was not able to correct the problems with the Left and Right Side Results, so I deleted those PDFs. I do not expect to repost.
Sorry, with H's & K's, Rick Ruth
03-30-2009, 7:48 PM |
JerryLamb
Joined on 01-16-2003
Snohomish, Wa, US
Posts 423
Points 5,790
Thanks Rick. Does anyone know if the RTs and 60' times are available anywhere?
03-30-2009, 9:05 PM |
Eunos
Joined on 03-10-2003
Phoenix, AZ
Posts 109
Points 1,300
JerryLamb:Thanks Rick. Does anyone know if the RTs and 60' times are available anywhere?
I sure hope not! :P
Brian Peters
03-31-2009, 2:12 AM |
jzr
Joined on 10-20-2002
San Diego, CA
Posts 1,104
Points 18,250
Don't worry Brian, you don't have to learn how to launch if I keep driving like this! http://www.youtube.com/watch?v=TbCuC0s7ysc I'll be making some finer adjustments before Wendover, perhaps we'll see you there!
03-31-2009, 5:35 AM |
rtp.rick
O'Fallon, MO USA
Posts 1,341
Points 18,065
I have updated all of the PDFs above. Hopefully, they now reflect the correct left and right side times. I also discovered that two drivers were omitted from the original versions.
Sorry for the confusion and inconvenience.
03-31-2009, 3:18 PM |
ddisimo
Joined on 08-26-2003
Coral Springs, FL
Posts 94
Points 1,915
JerryLamb:Does anyone know if the RTs and 60' times are available anywhere?
Jerry, Here is the RT/60ft times from El Toro. Darrin
04-02-2009, 12:18 AM |
imstimpy
Joined on 10-25-2008
Posts 16
Points 185
Thank you for posting the RT/60ft.
