2001 Corvette Z06 T1 For Sale-SOLD
Last post 12-03-2008, 3:31 PM by racer5.7. 1 replies.
  •  11-08-2008, 2:37 PM 331348
    SCCA T1 Car for Sale – Four time Southeast Division and 2008 Southwest Division National Champion $25,000 Now $23,000-SOLD
    Pictures at http://www.flickr.com/photos/28328827@N06/sets/72157607271956343/
    You won’t find too many cars out there with a better pedigree than this one.
    4 Southeast Division T1 National Championships
    2008 Southwest Division T1 National Champion
    29 National wins (3 in 2008)
    8 current or former track records
    Consistently the fastest, most reliable C5 in T1 in the South.
    Top 10 Runoffs car every year except 2008 including a top 5 finish. (The only Corvette faster in 2004 was John Heinricy).
    Full T1 kit (shocks, springs, sway bars, control arms, etc.), set up exclusively by Phoenix Performance
    2004 spec engine, tuned exclusively by Phoenix Performance
    3 sets of Kodiak ultra-light three-piece wheels with many, many Kumho tires and Kumho rains.
    Carbon Fiber hood
    Ron Davis radiator
    Oil Cooler w/Aeroquip lines and LG adapter
    Trans Cooler and pump
    Hardbar camber kit
    DRM brake ducts
    Butler aluminum seat w/shoulder supports
    Firebottle
    Safequip HANS-friendly belts (good through 2008 for SCCA, good for HPDE, NASA?)
    Momo steering wheel w/quick release
    Fairly new calipers, tie rod ends, hubs, shocks, steering rack and pump
    New front rotors and Hawk DTC 70 pads
    SS brake hoses
    Radio, speakers, air bags, A/C, mufflers and cats removed
    Kirk cage
    The car is capable of (and has run) a 1:52 at TWS (2.9 CCW), a 1:32 at Road Atlanta, a 1:42 at CMP, 2:05 at VIR, 1:15 at Roebling, and 2:19s at Sebring. It’s safe, fast and reliable. This car will meet your needs if you’re thinking about T1 or just a great HPDE or NASA ST2 car.
    Chris Ingle special ordered it new, then slowly modified over the years into one of the best T1 cars in the country. In 2000, Chris went to Bowling Green, watched it being built (frame to finish), and was the first to start it. It’s been Chris’ baby from new through the 2007 Runoffs.
    I bought the car in late 2007 with some rear body damage, repaired it and raced it five times in the Southwest Division.
    This is NOT A SHOW CAR; it is a used race car that has the usual cracks and scratches that would normally be collected over years of racing. Some non-race items do not work; one headlight does not pop up, power windows will not go up, etc. It appears to have been well maintained and is still fast and reliable.
    The car has a current and clean log book, a complete history, photos, original sticker, build sheet, etc.
    The car is not shifting properly at speed and may need a new clutch, new parts are included. I have acquired a GT-1 Camaro in a trade and plan to race it in 2009. I invite serious inquiries, and will consider street trades, but no project cars; I have plenty of those already.
    E-mail eritchie@consolidated.net
  •  12-03-2008, 3:31 PM 335470 in reply to 331348
    Re: 2001 Corvette Z06 T1 For Sale
    New lower price $23,000 OBO or interesting trades.
    Extras that come with car include:
    Tires, all Kumho:
    V710 slicks
    315/35R17
    4 new,
    8(4 on car) race-ready scuffs,
    4 used "race",
    4 used "track days"- 20 total
    4-295/40R17 new
    Victoracer rains
    2-315/35R17 new
    2-275/40R17 new
    28 tires total
    Wheels
    12 total (including 4 on car) Kodiak three piece (6-17x10; 6-17x11)one front is different offset and requires spacer plus 4 C4 stock wheels 17x9.5
    1 New GM flywheel, clutch disc, pressure plate
    1 New AP hydraulic throwout bearing assembly
    2 New GM rear axle CV assemblies
    1 Set New Hawk rear brake pads
    1 New GM front hub/bearing assembly
    1 New GM rear hub/bearing assembly
    1 each new GM fuel line and dipstick/tube
    3 (or more) New fan belts
    2 New or rebuilt Delco power steering pumps
    1 New power steering pressure hose, aftermarket
    1 Used transmission, probably original, has wear on output shaft but works good; 1 Rear diff. (junk, basket case); 1 Used BCM (body control module); 1 Used Turn One power steering pump and pressure hose; 1 Used Turn One power steering pump and pressure hose; 2 Sets used plug wires; 1 Set each used front and rear brake pads; 1 Used ABS controller (good but one hole is stripped); 1 Used power steering rack (Less than two hours from new, but leaks); 3 (or more) Used power steering pulleys; 4 Used T1 Sachs shocks; 1 Used alternator; 1 Used stock Exhaust pipe with cats; 2 each used front and rear brake rotors; Used parking brake assemblies; Several used tie rod ends; Several used hubs.
    Extra Body panels (all rough)
    LF fender
    RR quarter
    LF Headlight cover
    Front bumper cover
    Body side molding
    2001 GM factory Service manual set
