We will be having a discussion and Q&A prior to driving. We'll then
run two drills in the morning with a full course in the afternoon.
The instructors for this school are TBD.
-GET PLENTY OF SLEEP THE NIGHT BEFORE.
-If you have regular street tires, make sure you air them up to at
least 5 psi above recommended pressures. There may not be a
compressor at the event, so come prepared!
-Bring your helmet if you've got one, but we do have loaners. Helmets
must be SNELL approved, not simply DOT.
****The event is rain or shine, so be prepared for inclement weather,
PLEASE DRESS appropriately, you will be standing outside in whatever
weather we have.***
-If it's going to be hot, please bring plenty of water. (Note from Jason:
we'll have two cases of water for 15 people, if you need more than a
couple 3-4 bottles I'd consider gatorade) Remember that
you'll be standing on hot asphalt the whole day, so you can add about
10 degrees to the forecast... (Note from Jason: don't forget sunscreen!!)
-Bring good walking shoes and get plenty of rest, there will be a lot
of driving. (Note from Jason: When you are not driving you will be
running for cones, this is a high activity day, come prepared!)
-Bring a chair to rest in.
******Arrive by 7:30am sharp.*******
The program will be over at 3pm.
Directions and a Parking Map for FedEx Field are here:
http://www.redskins.com/fedexfield/**Lot is TBD**
