315's on a S197 Mustang
Last post 07-02-2009, 4:57 PM by SCCA Cobra. 27 replies.
Page 1 of 2 (28 items)   1 2 Next >
  •  06-29-2008, 12:59 PM 307814
    Has anyone seen 315's on a new style Mustang?  Either 17" or 18"?
    What wheel specs do you need, offset? how wide?
    I do not what to disturb the fenders at all.
    Detroit Region
    ESP #56
    2007 Ford Mustang GT
  •  06-30-2008, 8:01 AM 307884 in reply to 307814
    Re: 315's on a S197 Mustang
    I think they will on the back. Not sure on the front. You are welcome to borrow one and see.
    Marcus
    ESP 89
    www.margravemotorsports.com
  •  06-30-2008, 4:44 PM 307956 in reply to 307884
    I did test fit one of your 315's while at the Palace last event. But due to the offset(SN95), they stuck out way too far. I want to see if anyone else out there has successfully put 315's all the way around on a S197
    Detroit Region
    ESP #56
  •  06-30-2008, 6:33 PM 307977 in reply to 307956
    Ok, I would think the fronts would be more of a worry than rears.  On an 18x8.5 at 45 offset, a set of 295/30/18 A6's has roughly 18mm clearance between inside of the tire and the strut.  Now since it does not rub when the wheel is lock to lock, there has to be some clearance left there too.  Based on a couple quick calculations a 315/30/18 on an 18x9 wheel at a 45 offset would still have roughly 8-10mm of clearance on the inside against the strut and would stick out that much more on the outside which I doubt would be an issue given our 4x4 look on r-comps.  This is all of course in theory which does not exactly help your original request but I thought it might be of some value.  Good luck and please post if you have good or bad results in case we decide to go the SP route for some odd/fun reason.
    Rob S.
    116 FS 2008 Ford Mustang Bullitt
    South Carolina Region
  •  06-30-2008, 7:41 PM 307990 in reply to 307977
    While working at Steeda, we had several cars running 315 width tire on 20" wheels in 10-11" wide variety without any problems,  Im pretty sure that 315's should work fine with the right wheel probably 18x11 and then you just have to measure offset.  our 10" wheels were around 40 i believe
  •  06-30-2008, 8:27 PM 308003 in reply to 307990
    I would like to use 17" wheels due to the price of tires. My thoughts are 17"x9.5" or 17"x10" with +38mm offset and 315's.
    Any thoughts?
    Detroit Region
    ESP #56
  •  07-01-2008, 12:02 PM 308099 in reply to 308003
    ShawnAlexander:
    Any thoughts?
    Well yes. Those wheels are more appropriate for 275 width tires.......Not 315's.
    Just bolt Marcus' wheel back on, and take some measurements. Even if the offset isn't right you have an idea how much "not right" it is.....Then go from there......I cold be wrong but I remembered Marcus being on 12" wide wheels. Going with an 11" wheel would be fine with a 315 and you'll have a little more room.....
    Be happy you are't in an E30 BMW. Any decent size tires require surgery
    DSP 325IS.
  •  06-15-2009, 2:43 PM 365276 in reply to 308099
    Well the 315/30/18 Hoosiers are mounted. The wheels are 18x10, +40 offset with a 9mm spacer up front to keep the tires off of the struts. I know the wheels aren't optimal for the tires but CCW's are costly.
    Detroit Region
    ESP #56
  •  06-15-2009, 4:43 PM 365310 in reply to 365276
    Got a bigger pic?
  •  06-15-2009, 8:17 PM 365345 in reply to 365310
  •  06-16-2009, 6:10 AM 365399 in reply to 365345
    and for those of us who can't check facebook @ work:
    Alex Jones
    2007 B-Street Prepared GXP
    www.CrazyMonkeyRacing.com
    "Your co-worker can't make it in today, the water pump on the Porsche broke"
    "Isn't his car air-cooled?!"
  •  06-16-2009, 10:11 AM 365425 in reply to 365399
    thanks Alex
    Detroit Region
    ESP #56
  •  06-16-2009, 11:48 AM 365456 in reply to 365425
    As stated, they fit.  You don't have to go to CCW, but I only was able to find 10.5's with a 35mm offset. *rears actually could use a 55mm offset*
     I have yet to get R-comps on the car, but I think Nats will see them show for it.
    STU/ESP 181 - '06 Stang GT
    Mercenary for Cameron
    *I do stuff, they pay me. It works*
    Vorshlag Test Pilot Program
  •  06-23-2009, 11:58 AM 366136 in reply to 307814
    I mounted 315/30/18 A6's on 18x10.5 +50 wheels. I had to use a 1/2" or 12-13mm spacer in front, rears fit fine.
    SFR - #05 ESP
    2005 Mustang
    www.maierracing.com
  •  06-23-2009, 1:08 PM 366152 in reply to 366136
    The fronts fit w/out a spacer with the struts, but when I installed the coilovers they hit on the spring adjusters.
    Detroit Region
    ESP #56
