New Hoosier Size ---265/xx/18
Last post 05-28-2008, 12:37 AM by ratt_finkel. 12 replies.
  •  05-23-2008, 6:42 PM 302014
    I spoke with Jeff @ hoosier today regarding a potentail new tire size.  And I wanted to see if anyone here might be interested in such a size.
     We had discussed essentially a tweener tire between the 245/35/18 and the 285/30/18.  Basically would be the same height as the 245/35 but an inch or so wider.
    I feel with all the current car as well as new ones that are coming with narrowish 18" wheels and don't want to cram a 285 or 295 might benefit.
    Jeremy Foley
    2001 2.5RS GS#80 2004-2006
    2003 Evo8 STU #80 Who Knows?
    2004 Mazda RX-8 BS #75 RWD? WTF do I do now?
    President
    Team if you can't beat them-Join them!
  •  05-23-2008, 9:07 PM 302029 in reply to 302014
    Re: New Hoosier Size ---265/xx/18
    I'm interested in the 265/35 18 size.  It would mean I wouldn't have to mess with spacers anymore.  The 285's have been tearing the front of my car up.  Indifferent
  •  05-24-2008, 8:01 AM 302064 in reply to 302029
    sounds like something that could work for me
    265/35/18 on a 7" rim, only one way to find out Big Smile
    Scott
    07 Mazdaspeed 3
  •  05-24-2008, 8:18 PM 302094 in reply to 302064
    Wow, that's exactly what the GT3 needed in super stock for a front tire.
    1999 Civic Si SSC
  •  05-25-2008, 1:43 AM 302119 in reply to 302094
    I would like try this size on the CS Solstice ZOK. Lower the profile, the better the feel?
    I am not happy with the feel on the 295's that I am using now.
    FM
  •  05-25-2008, 11:44 AM 302131 in reply to 302119
    It would make a great front tire for the Noble, too.
    Robert Puertas
    www.EvoSchool.com
  •  05-25-2008, 10:29 PM 302156 in reply to 302131
    Took several adjustments to get them there, but I'm extremely happy with the 295s.  I won't be changing.
    My bet is 265/35 (assuming it happens) and it likely won't match a 245/35 diameter, it will need to be club racer friendly too and they don't get the sizing leeway we do in Solo
    "Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
    Horsepower is how fast you hit the wall, torque is how far you take the wall with you." --Anonymous
  •  05-26-2008, 12:30 AM 302166 in reply to 302156
    • Jaker is not online. Last active: 08/20/2008, 11:59 PM Jaker
    • Top 500 Contributor
    • Joined on 03-25-2003
    • Surrey, BC, Canada
    • Posts 239
    • Points 2,545
    TeamRX8:
    I don't know about that. Case in point: 255/40-13 and 275/35-15 are not available in the road racing compounds. They'll probably do exactly what they did for the  225/45-15 - 275/35-15, and add an inch to center of the mould of the 245/35-18 to make the 265/32.5-18.
  •  05-26-2008, 1:51 PM 302218 in reply to 302166
    Jaker:
    TeamRX8:
    That's exactly what Jeff said they could do.  So it would be the same 24.9" diameter as the 245/35/18.
    Jeremy Foley
    President
  •  05-26-2008, 2:16 PM 302220 in reply to 302218
    I sure wish they would do the same thing with the 285/30-18 and make a 305. The 285 is to narrow and the 315 is to tall for the GT3. I know Hoosier used to make a 305-18. Would be nice to have it back some way.
  •  05-26-2008, 6:33 PM 302247 in reply to 302218
    • Posts 239
    • Points 2,545
    ratt_finkel:
    That's an awesome tire size, especially if the recent rule proposal for Street Modified goes through - 275 or narrower tires widths earn a 200lb weight limit reduction.
  •  05-27-2008, 8:33 PM 302551 in reply to 302247
    yeah, I suppose a 265/30-18 is possible if they feel there's enough demand
    I thought it odd that the 305/30-18 dropped out of the A6/R6 lineup, but it's still available as as the speed-rated Wet Radial
    FastMike, if you're 295s aren't excessively worn I may be interested in taking them off your hands
    MS
  •  05-28-2008, 12:37 AM 302609 in reply to 302551
    TeamRX8:
    I think the tire would work on a ton of cars.  Let me think of a few stock class cars that could benefit.
     RX-8
    Boxster
    New STI
    New EVO and HS Lancer GTS
    New Cobalt SS
    GT3
    MS3
    Audi TT
    Crossfire
    Etc.
    Jeremy Foley
    President
