GP Proposal for 2009
Last post 11-19-2008, 7:20 PM by Jim G. 49 replies.
05-21-2008, 4:22 PM |
stevemhudson
Joined on 12-31-2003
Austin, Texas
Posts 252
Points 2,600
The June Fastrack has the PAC/SEB proposal for GP. The plan is to add some cars, but with limited preparation to make them less expensive and easier to build. Check it out at http://scca.com/documents/Fastrack/08-fastrack-june-solo.pdf
Steve Hudson DP Miata
05-21-2008, 5:47 PM |
subrew
Joined on 08-09-2004
Chico, CA
Posts 256
Points 3,110
Personally, I think a limited prep GP is a great idea, and long overdue. Being able to bring in some "slightly faster" cars from DP and EP with a friendlier prep level will open it up to a broader audience. My only reservation is that the overall lists seem incomplete. If you remember, I had proposed a class change for the Fiat 128 to GP last year, which got turned down. So, now we have a vehicle nearly identical in power, weight, prep ability to cars in GP and cars on this proposed limited prep GP list, but it isn't allowed in GP. Where is the consistency? Perhaps there are just a few more smallish cars than need to be brought into GP in either full prep, or limited prep. Or both. Give the option to run either prep level and deal with the weight issue.
The inclusion of the Porche 914-4 1.8L is interesting too. But it begs the question...why aren't other similar 1.6 to 2.0L sports cars from the time period on the list? Fiat 124 Spider, Alfa etc. Again, it just seems like the list might be missing a few.
Chris H.
05-21-2008, 6:17 PM |
MNbiker
Joined on 11-07-2002
Maplewood, MN USA
Posts 700
Points 9,115
Chris,
We relied pretty heavily on the work done by our comrades in Club Racing to develop the proposal. We didn't address other potential additions to GP that weren't already on the GCR Limited Prep list, as time constraints precluded duplicating the detailed specifications that Club Racing has refined over an extended period of time. The cars included were from G & H Production, and we erred on the side of caution, in not including a few cars, where there were concerns that performance potential might not be in line with current GP cars. We stayed away from Limited Prep F Production cars, as those clearly seemed too fast for GP. If you feel this approach was too conservative, or have other input regarding the proposal, please submit your comments to SEB@scca.com.
There certainly may be other cars that could be considered for a move to GP. However, we haven't identified any cars languishing in other classes that seem to offer significant potential for swelling the ranks of GP. If anyone thinks we missed something, feel free to submit a proposal to the SEB.
Steve Garnjobst #75 XP '99 Mazda Mutant
05-21-2008, 6:20 PM |
gary p
Joined on 11-23-2001
Monticello, IL, USA
Posts 2,263
Points 36,430
Snore. I don't see much there that would get anyone under 40 excited about Prepared except maybe the Hondas.....which are platforms that already have a reasonably competitive place to play in Prepared. I'd be surprised if this added more than 5 cars to the class at Nationals by 2012. When you've resorted to asking people build Renault Alliances, non-16V Swift 1.3s, Datsun 210s, Ford Fiestas, or Fiat 124s to bring participation up in a class, you're really scraping the bottom of the barrel. GP, thy future is bleak indeed.
05-21-2008, 8:57 PM |
genecooley
Joined on 09-30-2003
Posts 5
Points 75
The long wheelbase SOHC Fiat 128 sedan seems like a natural here. The 128SL and 3P with the 87" WB might not fit, but several cars on the list are not that much different in size.
BTW, the 1592cc and 1608cc Fiat 124 Coupes are DOHC. Some early 124 sedans had push rod motors, later ones are DOHC.
Gene Cooley
05-21-2008, 10:34 PM |
marka
Joined on 03-13-2001
Poland, OH
Posts 1,808
Points 27,195
gary p:
Ditto, but I'd love to be proved wrong.
I'm surprised that there isn't a limited prep choice for a miata or mr2 here. Seems like with the old weight from back in the "combined DP" days & limited motor/suspension work it'd be a good fit?
05-21-2008, 11:34 PM |
MNbiker
Maplewood, MN USA
Posts 700
Points 9,115
marka: I'm surprised that there isn't a limited prep choice for a miata or mr2 here. Seems like with the old weight from back in the "combined DP" days & limited motor/suspension work it'd be a good fit?
It's probable a Miata (and other cars listed under F Production Limited Prep) would be significantly faster than the current GP cars. To slow them down enough, allowances would need to be further limited and/or weights would need to go up. The hard part is determining what those limits should be to keep the cars competitive, but not dominant. Feel free to suggest a methodology where more cars could be added to the mix - preferably using the GCR Limited Prep rules & car listings as a starting point.
05-22-2008, 9:58 PM |
Joe_914
Joined on 12-05-2005
Gulf Coast
Posts 554
Points 3,220
I was just thinking of what kind of power a 1.8L 914 engine would make on a budget.
NOT much. However with big bucks an E production engine with high RPM and a narrow power band about 180 ish. Not and Autocross engine. Oh and about 25,000 dollars.
An autocross engine good heads 2,000 bucks the rest of the motor to the limit another 3 grand if you are thrifty. maybe 120 HP with about 100 ft lbs of torque. all Flywheel numbers.
Pass on GP
Want to go faster, please send money.
10-23-2008, 4:38 PM |
10-23-2008, 6:14 PM |
MNbiker
Maplewood, MN USA
Posts 700
Points 9,115
To get a complete set of rules for the proposed "Limited Prep" cars, you'll need to look at both the June 2008 Fastrack, and the GP section of Appendix A in the Solo Rules. Per the Fastrack, you may port match the intake manifold, and perform a few other minor modifications. I see no allowance for alternate intake manifolds or throttle bodies. Note: throttle body diameter is one of the primary "choke points" utilized to limit engine power. Alternate injectors are OK. I believe the engine computer would be covered by the general Prepared rules, since neither the GP Appendix or Limited Prep rules address this engine component - in which case, re-programming would be OK. Nope, the Limited Prep rules don't allow the 40 DCOE's.
Not an official opinion, etc., etc.
10-24-2008, 8:22 AM |
DILYSI Dave
Joined on 12-12-2002
Posts 494
Points 5,975
Chris Raglin:
...If the times ran this year at Nationals are a good indication of current GP potential, I think the new cars are going to mop up. Then we will have to listen to GP whine again about not being competitive anymore.
-Chris
See also: the goal. :)
10-24-2008, 1:45 PM |
Posts 634
Points 7,935
Chris Raglin:
The times for GP are somewhat representative. The X1/9 that won is a reasonably well prepared car. I have driven it and know it has more potential than we saw this year. Not a LOT but more. As Steve G. noted above, the throttle body is a choke point and the X has been choked alot. It has to run nearly a stock carb in GP. Its limited to a 36mm 2 bbl Weber. This motor could make another 25 to 35 hp with unrestricted inake.
Note that Steve Bolinger won DP in '05 in a "GP" Sprite. Back then my MR2 had to weigh 1980 lbs. That's over 200 lbs more than the current DP weight formula. I think this is more representative of GP's potential. No they aren't going to beat DP but the class I don't think is where it could be. I do think the Honda is likely going to dominate the current GP as we see it now.
I don't like the limited prep allowance. I have been involved with preping a "limite prep" production road racer and I really don't think there is that much savings. Developement still proceeds at the same pace. There is some savings in one time expenses for things like chassis fabrication and cylinder head porting but that is limited savings.
Steve Hoelscher #27 DP - Toyota MR2 http://www.terriehoward.com
10-24-2008, 7:18 PM |
10-24-2008, 7:53 PM |
DILYSI Dave
Posts 494
Points 5,975
Davard:Looking at STS results, you'd only need to go a second faster per course (from 2008 Nationals) to equal GP times. I would think that just taking a stock ('89-91) Civic Si motor (with STS mods, minus the cat, and perhaps allowing the SP overbore) and trans in the '88-'91 Civic DX body makes more sense as limited prep than a 11.0:1, cammed, carbed, ported DX motor. Or even just the Civic Si without opening the motor.
Civic is limited to 1.5, and there's no allowance fo de-stroking, so an 88-91 Si is no good. An 88-91 DX fits, but with the DPFI it's limited. I think the 86-87 Si is the one to have. MPFI, 1.5L. It can easily be adapted to run OBD software to get rid of the mechanical distributor and then it's just as tunable as the STS cars.
10-24-2008, 9:46 PM |
Davard
Joined on 12-29-2000
Topeka, KS
Posts 1,224
Points 18,445
I fully understand what the rules say. What I was trying to say was that if you wanted truly "limited" prep, using a stock Civic Si motor rather than building up a DX motor would make more sense. The comparison between STS and GP was to show just how well a Civic would do in GP.
David Avard 89 Honda Civic Si black (STS) 07 Mazda 3s (HS?)
10-24-2008, 10:15 PM |
11-10-2008, 6:16 PM |
spitfire4gp
Joined on 01-17-2002
Salina, Ks.
Posts 74
Points 820
I like the whole limited prep concept to add cars to GP, and until proven otherwise I don't think they'll dominate.
In fact, I suggested to the SEB years ago a limited prep concept, but since that was a concept invented on the road racing side the attitude then was "it ain't solo" as the rationale to ignore it. That's another subject, but one autocrossers need to get past.
I drive my GP Spitfire in both solo and road racing, it is GP over there too (or was, HP now). I've raced against limited-prep G Production cars, most notably an MGB and a Volkswagen Golf. The biggest problem I had with them is that is impossible to "steal" a straightaway. My Spitfire is a full-prep G Prod car (Okay, it could have more money thrown at it, but it is set up under the full-prep rules). What I found racing against Limited Prep cars with half-again as much engine as mine (my 1147cc against an MGB's 1800) is that I'm faster in the corners but they just drive away from me on straights. Result: I catch up in the turns and bang on their tailpipe, bit if they drive good lines, although slower, there's little I can do but wait for a mistake. The races I won was because I pushed them into a mistake late enough in the race and got enough lead they couldn't catch up again before the checker (once in literally the last corner of the last lap).
The point being: Solo doesn't have those long straights. We're all about the corners. I'd usually even out-qualify those limited prep cars on the race track only because I was doing corners quicker. They advantage they have over my car on race tracks basically go away on autocross courses. But not so much that they become uncompetitive either. IMHO, the proposal has the potential to be a very good fit for G Prep.
--Rocky Entriken
11-10-2008, 6:23 PM |
11-10-2008, 9:30 PM |
Posts 634
Points 7,935
DILYSI Dave:Rocky / Steve - If the cards fall in such a way that a Fuel Injected Honda ends up on top, will that car still be accepted, or will the rules be "fixed" so that some LBC still wins.
Well, knowing the history on this one I would say yes.
Page 1 of 3 (50 items)
