What is the proper way to charge a trailer break away battery?
Last post 05-21-2008, 3:57 PM by Major_Lee_Slow. 3 replies.
  •  05-21-2008, 12:20 PM 301494
    Can I just use a "standard" lead acid battery charger to charge the battery for the break away brake circuit?
    #57 ESP 1998 Camaro SS
    MLS Motor Racing
  •  05-21-2008, 2:44 PM 301527 in reply to 301494
    Re: What is the proper way to charge a trailer break away battery?
    Ideally it should be wired to charge off of the towing vehicle.
    www.jjsons.com
  •  05-21-2008, 3:21 PM 301541 in reply to 301527
    Ryno:
    I have had exactly zero luck doing this.  It always shorts on one side or the other and it inevitability causes an entire rewire of the trailer.
    My battery charger has a few settings - one of them is a small/gel setting.  I've used that with no problems.
    Rob Leone
    '07 Solstice GXP in AS
    '87 Toyota Corolla in EP
  •  05-21-2008, 3:57 PM 301550 in reply to 301541
    I've seen systems which charge off the tow vehicle, unfortunately, I don't believe that my trailer has this system because when I checked the voltage accross the leads of the battery with the trailer connected, and the tow vehicle running, the voltage is only 9 volts.  It is also 9 volts when it is not connected to the tow vehicle.
    MLS Motor Racing
