Changing wheel size (diameter, width) would take you out of stock, and if you're just getting started, street tires are just fine.
As far as your other questions:
1) Most manufacturers have only a limited knowledge of solo/autocross, so they may or may not know what you're talking about when you call. If they don't, the easiest answer is "no."
2) Light, strong, cheap -- pick any two.
If I were to sacrifice anything, it would be "light" (but then again, I am a cheap bastage). Do NOT sacrifice strong.
3) Tirerack.com -- they have people there who autocross and can make good suggestions. Also, by just running locally on your street tires, it also gives you a chance to meet local people who can give you suggestions.
Glenn L. Austin, Computer Wizard and Race Car Driver
2005 Ultra Yellow Nissan 350Z Track Model
2007 Packwood ProSolo "first loser" (0.081)
2007 SCCA Solo National Championships - 10th place
