DSP and FSP data and info.....
Last post 06-26-2008, 11:27 AM by whitecivic. 2 replies.
  •  05-16-2008, 2:22 PM 300693
    I am researching DSP and FSP with respect to the performance of the top ranked cars in each class.
    If you have, please e-mail me at kevin dot barnett at ncmail dot net the following (or post here if you do not care if others see):
    Year / make / model / class / % level of preperation
    competition weight
     hp and tq and where the peaks are in the rpm band
    any suspension limitations  or advantages in class
     developemental limitations
     largest tire size usable
     weight balance
     max lateral accel
     max accel and braking forces
     anything else you can think of that woudl be beneficial in the evaluating of cars in class.
    Best regards,
    Kevin
    94 Audi S4 (not stock)
    85 Bertone x19 (18k orig miles)
    85 Bertone x19 (DSP car)
  •  05-16-2008, 2:48 PM 300699 in reply to 300693
    Re: DSP and FSP data and info.....
    I run an FSP Impreza wagon.  I can fill in some blanks anyway.  I've got my list of modifications at http://www.jenandneil.com/28fsp.
    The car weighs 2680 lbs and that's with heavy-ish STi seats and steering wheel, 22lb alloy wheels, power windows/locks, and the passenger airbag-equipped dashboard.  I imagine swapping in a lighter set of seats and steering wheel without an airbag, the older dashboards without an airbag, lightweight wheels, and manual windows/locks could yield another almost 50 lbs.  A lightweight exhaust could help some more.  The weight split is 55/45 F/R.
    The engine is built, but there's no engine management.  So I'm getting about 112 HP and 120 lb-ft of torque measured with a G-Tech Pro/SS.  The torque peaks at about 4000-4200 RPMs and starts to really trail off around 5300 until redline at 6200.  I'm running 245/40R17 tires this year, but the 275/35R15 are definitely a contender.  I'm sure you can be pretty competitive on both sets.
    I haven't run with my new tires yet.  On my old 205/45R16 tires, I was getting lateral Gs between 1.2 and 1.3.  I could always turn faster to the left but hopefully my new alignment will repair that.  I can accelerate about 0.3G and decelerate at almost 1G.
    Hope that helps.  I'm only 0.3L displacement down from a Impreza 2.5RS and otherwise, there's nothing to distinguish my car from a DSP Impreza, except the weight balance is a little in my wagon's favor.
    -N
    #128 FSP - '99 Soloru Wagon - NER
  •  06-26-2008, 11:27 AM 307397 in reply to 300693
    I think I'm very happy person right now because if I have read the rule right my car go's to FSP next year.
    Mr White
