Fox Mustang Questions
Last post 05-14-2008, 3:44 PM by madarash. 1 replies.
  •  05-14-2008, 1:02 PM 300258
    I am thinking about getting a 1992 Mustang LX 5.0 for some local autox fun.  I have no plans to make it nationally competitive but I do want it to be fun and quick.  I have been autocrossing a Mini Cooper for about 4 years now and while it is a lot of fun, low power and FWD is starting to get a little old. I would like to give a rwd v8 a try because I think I will learn more.
     So with that in mind, I have a couple of questions:
    1.  Can the fox body mustangs take autox abuse pretty well, or is it a constant battle to keep them in god running shape?  Running costs due to reliability concern me a bit.
    2.  I can pick one up for around $1500 and have approximately $1000 to spend on suspension (I have a separate bucket of $1000 for wheels and tires, probably R01-Rs to start with).  Where is the $1000 best spent?  Is it the usual approach of shocks/springs, camber plates and a rear sway bar, or is the money better spend on bracing and stiffening the chassis up a bit? Or is it a combo?  Do I just drop a bunch of $$ into the rear to remedy the not so great solid rear?  What parts would you recommend? Should I just plop down a grand on a Grip box from MM? (I don't care about power at this point because it will already be night and day compared to the Mini)
    Classing isn't terribly important to me, I just want to have fun and learn how to drive a RWD car but I guess I would rather stay in the Street Prepared class.
    Thanks!
  •  05-14-2008, 3:44 PM 300305 in reply to 300258
    Re: Fox Mustang Questions
    Use to run an 87 GT back in the day placed as high as 10th at Nationals and hadn't done much to the car.  Here is what I know.
    Global west springs I may even have some up in the attic.  I would get a set of double adjustable koni's.  Put a pan-hard bar on the rear helps with the back end hook up.  Also run hem joint on the upper control arms to cut down on bind.  And a set of global west camber plates which I think I might also have up in the attic.  Urethane control arm bushings front.
     That should get you started.
    I am going to the Atlanta Pro so I won't be checking my E-Mails tell I get back.  If you interested in some of the parts let me know I will see what I still have.
    Mark Madarash
