STS2 1993 Miata For Sale
Last post 05-13-2008, 2:56 PM by P40vic. 1 replies.
  •  05-13-2008, 2:05 PM 300014
    • nealb is not online. Last active: 07/04/2008, 3:30 PM nealb
    • Joined on 07-04-2003
    • DFW TX and central FL
    • Posts 44
    • Points 505
    For Sale:   1993 Miata STS2
    Original white with decent tan top, black interior.  Northern car.  Has some rust but healthy drive train and fast.
    Former Craig Mankiewicz car.  2006 STS2L National Champ car.
    Not street driven.  No A/C.  Unknown mileage on engine, but leak down and compression test, plus dyno tune prove it is healthy.  Car has VLSD that is as good as those get.
    The good stuff, all new in 2005-07:
    • Racing Beat header
    • Mazda cat
    • Borla stainless cat back exhaust
    • all poly suspension bushings
    • Mazda clutch/pressure plate
    • clutch master and slave cylinders
    • new brake master cylinder, rotors, rear calipers, pads
    • suspension bolts including new style eccentric adjusting bolts
    • Unorthodox Racing crank pulley
    • plug wires
    • timing belt/water pump/cam oil seals/cam tensioners/fan belts/plugs
    • dyno tune at Applied Racing Technology
    • corner weighting and alignment by Spec Miata specialist to my autocross settings
    • synthetic fluids
    • Jet reprogrammed ECU
    • revalved double adjustable short yellow Konis with new coil overs & springs
    • front hubs w/ longer studs
    • Mazda radiator and all 8 coolant hoses
    • SP Induction Systems SPX2 intake and filter
    • small battery and full size battery
    • MazdaSpeed HD front swaybar mounting brackets
    Can sell with or without competition wheels (15” Rota Slipstreams or Kosei K1-TS) or with just 14” original rims with ok tires, and with stock seats or Ultrashield Rally driver seat.
    Other stuff can go with the car, including two spare front sway bars, rear bar, spare power steering rack/pump, black soft top in good shape ready to bolt on.
    $4,800     Car located in Texas.  Depending on location and timing, willing to discuss delivery on my trailer with you buying gas.  Pix available
    Neal Bellamy
    FOR SALE 1993 Miata STS2
    1992 STS2 Miata
    1993 Miata, almost a Spec Miata for track
    2003 Corvette Z06 retired to cruiser
  •  05-13-2008, 2:56 PM 300023 in reply to 300014
    Re: STS2 1993 Miata For Sale
    Can the car be street driven, ie plates on it currently?
