Shifter kart package
Last post 05-09-2008, 12:57 PM by Ryan Thompson. 0 replies.
  •  05-09-2008, 12:57 PM 299353
    I'm selling my shifter kart and everything else you'd ever need to race it. You can't go faster for any cheaper. All consumables are a fraction of what you'd pay for auto-xing a car. Asking $4200 for everything.  If you have a civic I'll even throw in the trailer hitch.  I am located in Atlanta, GA.  You can contact me at ryan12321@gmail.com
    Kart Details
    99 MBA kart
    Ribtect medium seat installed in 2007. Never have to worry about rib pain
    Extended front porch for taller drivers. Custom built by MRC fabrication in Lawrenceville, GA
    Pedal position is adjustable so it will not effect normal height drivers.
    Extended rear bumper built by MRC. Great for safety if you want to do any sprint or road racing.
    4 wheel disc brakes with dual master cylinders
    All electronic wiring done
    Kill switch wiring and switch on front fairing
    New fuel line installed in 2008
    Brand new 40mm axle bearings installed in 2008.
    All new bolts/nuts hardware on entire kart replaced in 2008.
    All tie rod ends replaced in 2008
    1 set douglas magnesium wheels with beadlocks for dry tires. Vega yellows on wheels
    1 set aluminum wheels with brand new rain tires
    2 spare rear aluminum wheels
    2 sets of tire bags
    1 set of Shockwave 65mm front hubs
    1 set of Shockwave 95mm front hubs
    1 set of MBA 120mm rear hubs
    Brand new retrofitted 2007 kart front hub mounts
    New as of 2007 rear brake rotor
    New brake pads as of 2008, also have a set of spares
    Engine Details
    Honda CR125 built by Banke Motorsports
    6 speed sequential transmission
    vforce3 carbon fiber reed cage
    K&N filter
    K&N airbox with airbox filter. Air flow tubes have been upgrade to 29mm tubes.
    RS Piston
    ported and polished
    O-ringed cylinder head
    Epic racing thermostat system
    Kehin PWM carb with pumparound system
    RLV pumparound fuel pump, completely rebuilt in 2008
    full jet set
    full range of pilot jets
    multiple needles
    Shockwave karting free-heel engine mount. Uses spherical bearings so it does not stress the engine. Only mount of its kind on the market.
    Shockwave fuel pump mount
    Shockwave exhaust port with O-ring seals. Extra O-rings included
    RLV exhaust pipe with EGT gauge port welded on
    M4 titanium exhaust silencer
    Freeline radiator
    Engine spares
    Full set of 40mm lightweight aluminum axle gears
    A few extra steel axle gears
    Full set of engine gears
    Extra spark plugs
    Extra O-rings for cylinder head
    Tools
    T-handle hex wrenches
    Tire wizz tire mounting tool
    RLV tire dismount tool
    Fuel ratio mixing tool
    5 gallon VP racing fuel jug
    Brake bleeding tool for quick and easy brake system flushes
    Tire guage
    valve stem removal tool
    Kart lift pro kart stand (single person kart lifting) - Sells for $550
    Electronics
    AIM Mychron 3+ data aquisition system with the following sensors
    EGT - exhaust gas temperature gauge
    Water temperature gauge
    RPM
    Speed sensor
    2hours of onboard memory storage
    USB cable to download system information to PC
    Other
    Full documentation on CR125 motor
    OMP Ribvest
    Shift kart size 56
    Karting neckbrace
    Northern Tool 5x8 trailer with toolbox permanently installed (can be removed if desired)
