How to ruin a good DS car OR How to dethrown the BMW's....
Last post 09-22-2008, 4:53 PM by solo-x. 171 replies.
02-11-2008, 12:35 PM |
solo-x
Joined on 09-19-2003
Posts 839
Points 13,640
To the Sandbox members, I apologize for the cross post. I've
been kinda piddling along on this project all winter. As you can see,
the 2812's are already on and I've already mounted a Magnaflow cat-back.
In the last couple of weekends the car has slowly been disassembled
until it reached it's current state. The disassembly phase is almost complete and the assembly phase should start shortly.
With front fenders and the Keizers mounted up.....
 Front shot before I took the fenders off, with the Keizers on....
 How far the Keizers stick out past the stock fenders.....
 Side shot, no fenders.........
Things still to do listed in no particular order:
1) Get a junkyard set of fenders or order some from Veng to chop up 2) A trip to the junkyard for some misc. bits and peices gone missing from the car in the last 10 years 3) Correct the hub bore on the Keizers (didn't realize they were different on an R then on a Civic. oops!) 4) Get a header. I need to do some research on this subject, as many require modification of the block brace. 5) Get rubber mounted 6) Order a pair of 15x7 rear wheels 7) Double check the alignment 8) Replace the clutch 9) Order a steering wheel 10) Order an OBD2 -> OBD1 harness 11) Wire in the DL1 12) Pull the a/c, radio, rear wiper assembly 13) Get a good base ECU tune 14) Get the passenger seat ordered and a mount for it fabbed together.
First event is in a couple of months. I'm getting the feeling that I'll be thrashing on this thing the night before. Anybody have some spare Integra fenders they don't need anymore?  Nate
02-11-2008, 2:43 PM |
Mike Shields
Joined on 08-25-2002
Temple, NH
Posts 281
Points 4,020
Re: How to ruin a good DS car OR How to dethrown the BMW's....
How does one dethrown?
Is that like catching? De-Throw? Un-Throw?
Bring it on!! I hope you've got enough gears in that thing to make up for the torque deficit!!
-Mike
Mike Shields 1993 BMW 325is | 92/192 DSP
02-11-2008, 3:02 PM |
neilschelly
Joined on 09-01-2006
Tyngsboro, MA
Posts 74
Points 955
It looks like it'll be a good year to watch DSP from the ranks of FSP ;-) Good luck with all that checklist to go. I've only got a few things left on mine, but one of them is roughly translated (minus vulgarities) to "assemble engine." That's a big one.
-N
#128 FSP - '99 Soloru Wagon - NER
02-11-2008, 6:18 PM |
Beans
Joined on 10-13-2006
Rhode Island
Posts 68
Points 925
I hope your sawzall skillz are better than mikes, I remember the original carnage, it was something only a mother could love
someday i aspire to hack up a perfectly good car, but for now I will happily sit back and watch you two from the saftey of my stock class, but just you know, I could be there at the line behind you at any moment. Dont think because you skipped out on DS you are safe.
Scott 07 Mazdaspeed 3
02-11-2008, 8:07 PM |
solo-x
Posts 839
Points 13,640
I've done the "assemble engine" one before. The red car was purchased in february, the motor was out in march, and it was assembled and ready for competition in April. Being self employed at the time helped tremendously, though it didn't afford much in budget. I'm not too worried about the list. Much of it will get knocked out next weekend. A lot of the rest can get taken care of as the season progresses. My big one is the fenders. I've only got two to modify which makes me twice as likely to make them prettier then Mike's sawzall job, but it's still a bit of a project.
02-12-2008, 6:34 AM |
Rodney
Joined on 01-16-2003
new friggin york
Posts 313
Points 4,320
nate, pm me about my super secret nitrous install... oops, i have said too much already
02-12-2008, 9:09 AM |
solo-x
Posts 839
Points 13,640
Rodney:nate, pm me about my super secret nitrous install... oops, i have said too much already
I'd like to disassemble the motor in a slightly more controlled manner.... The TypeR engine code is b20z, right?
02-12-2008, 12:22 PM |
Rodney
new friggin york
Posts 313
Points 4,320
solo-x:The TypeR engine code is b20z, right?
no, it is k24a2....
02-12-2008, 3:55 PM |
ChrisFranson
Joined on 07-07-2005
Posts 72
Points 890
Beans:but for now I will happily sit back and watch you two from the saftey of my stock class
Two?
02-12-2008, 4:49 PM |
ibaker
Joined on 02-09-2004
WDCR
Posts 114
Points 2,335
solo-x:My big one is the fenders. I've only got two to modify which makes me twice as likely to make them prettier then Mike's sawzall job, but it's still a bit of a project.
Use an air nibbler on the fenders, much cleaner line and more controllable than the sawzall... I was ALMOST over R-comp withdrawl, almost! I think a pair of 15x9.5's and some 275's are in the future for the CSP CRX. Damn, it's going to take a month to get it out of my head... Ian
--CRX Addict --Recovered Mini Addict
02-12-2008, 11:08 PM |
ChrisFranson
Posts 72
Points 890
Mike Shields:Ian, you know you want it... it's calling you... of course you'll need to make new full wheel tire blankets
But the last set was so stylish. Or something.
02-13-2008, 5:13 PM |
tkm
Joined on 10-20-2001
OH
Posts 926
Points 14,805
Last I checked you could get generic Integra front fenders for like $67/piece. Why not get a set and hacksaw those up?
Not that I once thought about DSP or anything...but since you're doing it I'll let you be the guinea pig.
Todd Too many ST cars "Restricted Area Racing"
02-13-2008, 6:37 PM |
solo-x
Posts 839
Points 13,640
Todd, that is the plan. I have to swing by the yard anyhow for some other things, so I'll check for some teg fenders for uber cheap that are workable. I've heard the aftermarket ones don't fit so well or I'd go that route without any hesitation.
02-13-2008, 7:26 PM |
ibaker
WDCR
Posts 114
Points 2,335
mmmmmm 15in Jiffy Pop. Ian
02-13-2008, 9:37 PM |
Beans
Rhode Island
Posts 68
Points 925
ChrisFranson:
Two?
yeah you and nate you can mean chris or mke, depending who is reading this currently
02-13-2008, 9:53 PM |
Crosser1
Joined on 02-24-2002
Austin, TX
Posts 204
Points 3,170
ibaker:
Ian
I hear it need 10" of plexiglass just to get enough heat to pop though.
Eric
02-14-2008, 6:12 PM |
ibaker
WDCR
Posts 114
Points 2,335
Crosser1: ibaker: Mike Shields:Ian, you know you want it... it's calling you... of course you'll need to make new full wheel tire blankets
I hear it need 10" of plexiglass just to get enough heat to pop though.  Eric
Hahahahaha, I forgot to put the silver foil on the plexiglass so it didn't concentrate the solar rays and warm up the tires :) So Nate, what would it take for me to borrow your set of 15's for a day to do some testing on my CSP car???? Maybe I should bring both cars up for the Devens Tour? Ian
02-14-2008, 9:06 PM |
Jojoo
Joined on 03-14-2006
Posts 236
Points 2,325
Good luck. I'm one who does believe the Integra can compete with the right course set up (prays for the right course set up).
Page 1 of 9 (172 items)
1 ...
