what shock setting do stock-jocks run on the street?
Last post 06-11-2008, 10:33 PM by SoraNezumi. 8 replies.
  •  05-04-2008, 4:07 PM 298373
    just wondering...  with stock springs and Koni OTF SA on the 00 MR2 I am trying to figure out a good street setting...
     what are others using?  Obviously between different cars and dampers there's no one answer, but is it full soft, middle ground, or close to autox setting?
    Filed under: , , , ,
  •  05-05-2008, 10:03 AM 298442 in reply to 298373
    Re: what shock setting do stock-jocks run on the street?
    I would set them at whatever works best in the rain. It would suck to be going down the highway or some curvy road and get caught out in the rain with a dry setup. Typically, a wet setup means full soft on shocks and I have my Koni Sports set there or maybe a hair up from there at most on the street.
    Steve W.
    #66 DS
    ACR SRT-4
  •  05-05-2008, 1:05 PM 298481 in reply to 298442
    I have double adjustables, and I leave them at autocross setting for compression, but put the rebound at 0.
    DS #313 | the rolling couch of doom | La-Z-Boy Racing
  •  05-05-2008, 8:37 PM 298576 in reply to 298481
    With stock springs, I always back everything off to zero.
    Mark Pilson
    owner of STS2 Honduh
    co-driver of HS Subaru (race tires rule)
  •  05-05-2008, 11:21 PM 298604 in reply to 298373
    My street shock settings are basically the same as my rain shock settings.
    Glenn L. Austin, Computer Wizard and Race Car Driver
    2005 Ultra Yellow Nissan 350Z Track Model
    2007 Packwood ProSolo "first loser" (0.081)
    2007 SCCA Solo National Championships - 10th place
  •  05-05-2008, 11:58 PM 298607 in reply to 298442
    Ditto on full soft.  I run Koni Sports.  If I forget to soften the rears, my rattling teeth on the drive home quickly remind me.  :O
    Remember..."Civic" spelled backwards is "civiC"
    Todd Owenby
    1993 Civic Si HS
    1989 Civic Si STS (IF I can find a BLOCK...)
  •  05-06-2008, 10:18 AM 298647 in reply to 298373
    I'm running 1/4 turn off of soft all around for the street (00 MR2-Spyder, stock springs, OTS Koni Sports).  Don't run them at their extent settings (full soft/hard), just turn them back at least a 1/8 turn.
    Godspeed.
    --Wayne
    www.WalterMotorsports.com
  •  06-11-2008, 7:56 PM 305080 in reply to 298647
    thanks, guys, I've been running at 1/4 off soft, and the car feels a lot better than on full soft...
  •  06-11-2008, 10:33 PM 305103 in reply to 305080
    I run Full Hard front and rear all the time! Cool
    2005 Mazda SP23 Hatch
    http://www.wny-scca.com/
    http://www.mazda3forums.com/index.php
