STi vs. 135
Last post 04-23-2008, 10:58 AM by murph1379. 85 replies.
12-28-2007, 9:21 AM |
murph1379
Joined on 11-05-2006
Minneapolis
Posts 197
Points 3,325
Looking at the specs for the new STi a couple things struck me: 1) the price! $35k??? so 305hp subaru vs. 300hp BMW.... same price.
2) the weight! It actually weighs as much as a BMW, and I'm sure doesn't have the balance of a BMW 3) the design looks very much like a cross between the E46 (headlights) and 135 (taillights) and a Mazdaspeed Protege. For autocross purposes, it still has AWD, an extra half inch of wheel, better diffs, and probably better springs, but I'll be surprised if it compares well in the marketplace.
DS #313 | the rolling couch of doom | La-Z-Boy Racing
12-28-2007, 9:36 AM |
aansorge
Joined on 08-06-2002
Austin, MN USA
Posts 180
Points 3,095
1. Yeah, kind of surprising. Considering all the technology in the Suburu, AWD, diffs, etc., I would expect the BMW to be cheaper
2. See above but change cheaper to lighter.
3. I like it.
Not staying in DS?
12-28-2007, 10:05 AM |
12-29-2007, 2:21 PM |
12-31-2007, 1:42 PM |
John V
Joined on 01-12-2004
Columbia, MD
Posts 793
Points 9,835
cmamich:
Will these both fall in the A-Stock class?
Should be.
Figure the STi will probably be a good car, especially at Pros.
The BMW will be a bigtime also-ran, given that it's a heavy, one-wheel drive car with no camber.
John Vitamvas stranoparts.com / TeamWTF.org '04 Z06
12-31-2007, 2:04 PM |
Darkhelmet
Joined on 10-04-2006
Plaid
Posts 132
Points 1,515
Wow... sounds like my Cobalt, except for the "Bigtime also ran" part...
Interested to see what AS looks like this year with those 2 in there.
Brian Huber 2006 Cobalt SS-Supercharged #58DS Official car of One-Wheel Drive Racing's 2008 Solo campaign... If you aint last, then you aren't driving this car.
01-04-2008, 4:47 PM |
Mooobunnny
Joined on 05-29-2007
Posts 104
Points 1,745
aansorge:1. Yeah, kind of surprising. Considering all the technology in the Suburu, AWD, diffs, etc., I would expect the BMW to be cheaper 2. See above but change cheaper to lighter. 3. I like it. Not staying in DS?
So the BMW does not have a lot of technology in it? hrmm...
01-04-2008, 11:18 PM |
John V
Columbia, MD
Posts 793
Points 9,835
Sure, the BMW has loads of technology.
Problem is that very little of it goes into making the car faster.
01-05-2008, 12:27 AM |
01-05-2008, 1:12 PM |
01-06-2008, 9:45 AM |
John V
Columbia, MD
Posts 793
Points 9,835
PedalFaster:
prostcj:No LSD in the BMW.....it controls traction in the back with the brakes. This sounds like a show stopper in stock class.
I agree -- I think the car would be cannon fodder in A Stock. Problem is, its huge power would create big course dependencies in B Stock; I think it might be too fast for F Stock, and it would probably kill D Stock. Tough car to class -- I'd probably put it in F Stock, especially since the similarly powerful Shelby raised the bar there last year.
I tend to think F Stock is the place it belongs as well. It'll be buried in A Stock.
01-06-2008, 2:00 PM |
solo-x
Joined on 09-19-2003
Posts 839
Points 13,640
If it controls wheelspin by applying only the brake on the tire that is spinning, and provided the software is appropriately programmed, I honestly don't think the lack of a conventional LSD is a deal breaker. I don't know all the details on this brake assisted "LSD", but if implemented correctly it could be better then any of the conventional LSD's. On the other hand, if it is implemented poorly and/or gets disabled when you turn off the TC, then yeah, deal breaker.
01-06-2008, 7:18 PM |
01-06-2008, 10:28 PM |
solo-x
Posts 839
Points 13,640
The difference between theory and application I guess. Seems to me it shouldn't be too hard to program the virtual LSD to work better then even a s00per p1mp 2-way clutch type. Finally, an LSD option that could bias 100% of the torque to one axle that isn't axle speed differential dependant. Of course, the engineers have to have Solo performance in mind when they program the LSD to allow that 10-12% slip and apply brake to ONLY the wheel that is spinning.
Now, just because this technology on the 3-series is crummy for solo doesn't automatically mean the next iteration in the 1-series will be equally as crummy. Certainly doesn't bode well though.
Matt, drop me an email and explain what happened with the 330 and it's psuedo lsd. Just curious how it drove compared to one with a conventional LSD.
Nate - doesn't get to play with the fancy new electronic gizmo's
01-06-2008, 10:49 PM |
RX7 KLR
Joined on 01-19-2001
Ladera Ranch, CA
Posts 1,364
Points 18,990
I think the difference is a real LSD will always put power down through one of the wheels, if it is a good one it gives power to the wheel with grip.
A "virtual LSD" only slows down the spinning wheel, it does nothing to apply more power to the wheel with grip. So while the V-LSD might help to stop the endless one-leggin, it will not help you accelerate by transferring power to the other tire, it is still an open diff.
I think the 135 might have a shot in HS.
Jason Isley 2005-2006-2007-2008 B Stock National Champion
01-06-2008, 10:53 PM |
01-06-2008, 11:33 PM |
cashmo
Joined on 04-19-2001
Milwaukee, WI USA
Posts 451
Points 6,085
cmamich:Will these both fall in the A-Stock class?
I doubt the 135 will go to AS. Until we actually get our hands on one, BS, DS and I suppose FS are all possibilities. With 9" wide wheels, fat RE01R's, a good LSD and all the other STU allowances the 135 could be a contender.
Are twin turbo's allowed in STU? Jeff
01-07-2008, 2:13 AM |
Lynn
Joined on 11-30-2004
Saint Louis
Posts 1,590
Points 14,720
cashmo:Are twin turbo's allowed in STU? Jeff
No.
2002 Mercedes C230k, retired, 2005 Nationals STU DFL 1969 Beach Solo Vee and 1985 Lynx B Solo Vee
Page 1 of 5 (86 items)
