source for 1/16" thick 4x100 spacers?
Last post 05-27-2008, 3:52 PM by Rocwandrer. 20 replies.
04-16-2008, 5:12 PM |
Rocwandrer
Joined on 04-20-2007
Posts 124
Points 2,265
Anyone know of a place that has them? My wheels just barely don't clear the rear brakes, I've no interest in cutting the wheels, and have a good reason for not wanting to go thicker than is necessary on the spacer.
WTB: CSP Spyder parts. What you got?
04-17-2008, 9:45 AM |
Rocwandrer
Posts 124
Points 2,265
Re: source for 1/16" thick 4x100 spacers?
that's funny! any serious answers?
04-17-2008, 10:04 AM |
Randy Eickhoff
Joined on 03-20-2001
Kansas City, MO USA
Posts 46
Points 480
How about a couple washers on each lug?
Too Many 2's are never enuf 00,00,01Spyder, 91T, 93NA, 85NA>SC project
04-17-2008, 10:10 AM |
Bimmerman
Joined on 09-03-2002
Signal Mtn, TN USA
Posts 99
Points 1,040
Randy Eickhoff:How about a couple washers on each lug?
Oooohhh! Oooohhh!!! I know the answer to that one!
Brian Flanagan Serial ConeKiller STX #98 BMW E36 328is (TrackBitch) Beeg black truck!
04-17-2008, 10:16 AM |
96SM2
Joined on 01-24-2003
St. Louis, MO
Posts 388
Points 3,415
Bimmerman:
Something you have seen happen?
Andy Hohl Thanks Kyle for the drive in the Shelby GT this year
04-17-2008, 11:14 AM |
SpyderVenom
Joined on 01-11-2001
Southeast, PA
Posts 1,402
Points 18,650
96SM2: Bimmerman:
Once or twice - or anytime that someone wants to know "what's the worst that can happen?"
Rob Leone '07 Solstice GXP in AS '87 Toyota Corolla in EP ex - '91 MR2 Turbo in SM2 <- If you can't set a good example, serve as a horrible warning.
04-17-2008, 2:51 PM |
Joined on 12-26-2000
Wausau, WI
Posts 1,497
Points 19,955
For something that thin, you can go find your local laser or waterjet job shop, give them a dimensioned drawings, and they can cut a custom spacer out for you out of .060 sheet aluminum. Make it full bearing. Probably pretty cheap.
Patrick Washburn STU Evo www.winghats.com
04-17-2008, 8:44 PM |
Bimmerman
Signal Mtn, TN USA
Posts 99
Points 1,040
96SM2: Bimmerman:
See my sig, below.... Particularly the reference to my DSP car, AKA "Supertrike" LOL. There was a video Cashmore shot circulating around a few years ago of the offending wheel departure...
"Just Say NO to washers!" - Nancy Reagan (stoned on painkillers)
04-17-2008, 10:07 PM |
96SM2
St. Louis, MO
Posts 388
Points 3,415
Bimmerman: 96SM2: Bimmerman:
I got to see it in real time in ATL. The dismount of the offending wheel was most impressive.
04-18-2008, 11:41 AM |
cmamich
Joined on 12-10-2007
Posts 20
Points 715
How quick do you need them? I have access to laser processing...... need ID, OD and it appears 4 holes on 100mm bolt circle? Ill make them out of mild steel, there will be a small cost involved but nothing too extreme....
04-18-2008, 12:10 PM |
TedV
Joined on 09-14-2006
Knoxville, Tn
Posts 34
Points 360
Bimmerman:I also remember when I was running the old E30 Bimmer DSP car (also 4x100), my codriver came up with some really thin spacers, like 1/8 inch or less, that he told me were factory parts from an old Fiat (he was a little bit nutty, a real Fiat freak)... may be thin enough to work, if there are any to be found and he wasn't hallucinating.
umm, which co-driver was that and did he get the idea from me? Fiat X-1/9 has steel spacers about 1/8" thick but the bolt patern is 4x98. drill em out to fit, I've been running them over 10 years cause I'm a cheap SOB. I even have the .063 6061 AL layin around the shop, oh yeah, I'm a lazy SOB
04-20-2008, 11:25 PM |
Davebs14
Joined on 10-10-2001
Houston, Texas USA
Posts 1,776
Points 20,630
If you're going to be a smarta$$ and not listen, then don't ask ;) That was a serious answer. Sorry you don't like it. You could always buy wheels that fit Rocwandrer:that's funny! any serious answers?
04-21-2008, 1:07 PM |
vinax
Joined on 07-02-2006
Posts 53
Points 540
Bimmerman:See my sig, below.... Particularly the reference to my DSP car, AKA "Supertrike" LOL. There was a video Cashmore shot circulating around a few years ago of the offending wheel departure...
http://myfastbmw.com/videos/dsp.mpg This one??
Vinax 1994 BMW 325i FP AutoX car. http://www.myfastbmw.com
04-23-2008, 10:29 AM |
Bimmerman
Signal Mtn, TN USA
Posts 99
Points 1,040
I clicked the likn but all I got was a bunch of this:
µh…˜•™=j=mÆÒ²¯CØÀÖv¥ªjkk•O!4 veEž5‚–P9ž¡^¬³wFÖÄ\’[â¶Qã‹i¿ˆ])i,æážŠH.1¨3AˆYK--‡ÔÀö¤ñÀ@0Xð¿ÛïÇB2ó´cpò€|¿‰ñíñðDtÌÇí>[U¾ž1ƒry1ÒK’kv]Ú·mß_ü‹ß/ˆâùØî„dµrI8}nh¿é Ÿx'ÜŠ'¯ä^d#zÊ7-ò}œ-(A²Ò1o×n©´)NkêK! c~>€¼ünuð+¬I7xò>Õ&„·ÑÿH½|Lë¢8¾vc¸˜¨T,é[ÀuÌßÚ÷³(ÚßI2s&Qö´EiA jU@Ûò÷ûíåïÚ^í°}kœµ¥E)E ›¶,Sü[•|à šŠ¥[FÔ±…ÒÔ•@fÄ`˜—…zúœÚf”Y¬î£àÀÓXy&E!(ÒB|j Bi ,°‘Ã¥,( gƒI<Ûjœ{j–„6”ê SÊÊõ=ˆà4JiËh ˜T¾- eP°6=ŠÔ àÆÑ¦„!VŠê\f0„Ê©M©å”m!ˆ7ÕIlI€f –/¨Ö0—YKS%É£ÉE˜]ñCf¡•.èy*±sP´Õþ ¤¡¾<Ë-B*’Y©ë@²[E°»
I would LOVE to have another copy of that video, had it saved on a harddrive that crashed hard. (And NO, there were no washers used on my computer that caused it...)
04-23-2008, 10:55 AM |
Rocwandrer
Posts 124
Points 2,265
I'm going to make some out of 5052 sheet stock. It looks like there isn't anything out there for sale in this size, and making them from sheet stock will be way less work than machining down some thicker spacers.
Page 1 of 2 (21 items)
