May 4th WAI Event at Miller Park?
Last post 05-06-2008, 4:55 PM by mrexotica. 35 replies.
04-21-2008, 10:17 PM |
Electronchick
Joined on 04-05-2008
North of Chicago
Posts 15
Points 360
Anyone planning to go to this event?
---Traci--- www.myspace.com/ga_electronchick
04-21-2008, 11:32 PM |
ebnrt
Joined on 04-20-2004
East Troy
Posts 337
Points 4,905
Re: May 4th WAI Event at Miller Park?
Yep.
I am sure there will be something like 100-150 entries there; mostly the same people that run MKE & CHI SCCA/TRISTATE. It's run just like an SCCA event--you won't be able to tell the difference.
Erik B. Wisconsin Autocrossers, Inc www.waiautox.org ___/\___/\___/\___/\___/\___ 2007 Mazda6 2000 "Fozda" ZX2 S/R--STS Anti-Civic
04-22-2008, 12:20 AM |
theman631
Joined on 07-23-2006
Waukesha, WI
Posts 178
Points 1,550
Electronchick:
Newbies, they crack me up.
Like Erik said, 150 people.
I just worked on my civic for 5 hours and got all the suspension pulled off. Now all I have to do is put the new bushings in, change the oil pan gasket, put in a new clutch, remount all control arms, get proper springs, put shocks and springs back on after I get new ball joints and tie rod ends, put on the rear sway bar, install header, take all a/c componenets off, get some brake lines for the rear, bend them to fit, install steel braided brake lines, bleed whole system, get tires mounted on new rims, get an alignment,.....
Might be more, IDK
Hope to be there in the civic
Jimmy "Everyone ahead of me must be cheating, everyone behind me is a great driver." www.wildemotorsports.com www.lakecountryalignment.com www.triplehelixracing.com
04-22-2008, 1:39 AM |
redwhale240
Joined on 06-26-2007
Milwaukee
Posts 83
Points 1,615
Jake (20CiviC02Si):Will be there to hopefully take 1st in STX, that is if Mike doesn't do better than me with his WRX again. Took 2nd on Sunday! Was really nice how the car handled.
Congrats on the 2nd place finish. I'm glad you like those tires. They helped me scare the civics in STS last year when I switched to them
Ryan K
04-22-2008, 10:00 AM |
ebnrt
East Troy
Posts 337
Points 4,905
theman631:
Might be more, IDK
Awww, c'mon, Man! A couple of hours and a 6-pack, and you'll be good to go!
We have to diagnose the noise our car was making--it'll either be an inner CV or domething amiss in the diff. Then I need to pray to the Koni gods that our strut makes it back from Truechoice...get that in, and get it re-aligned and cornerweigted. I also want to try and source a slightly smaller RSB--junkyard Escort or Protege should work...just to have along and do some back-to-back testing.
04-22-2008, 10:07 AM |
Mugenlude
Joined on 02-13-2002
Southeast WI
Posts 720
Points 7,560
theman631:I just worked on my civic for 5 hours and got all the suspension pulled off. Now all I have to do is put the new bushings in, change the oil pan gasket, put in a new clutch, remount all control arms, get proper springs, put shocks and springs back on after I get new ball joints and tie rod ends, put on the rear sway bar, install header, take all a/c componenets off, get some brake lines for the rear, bend them to fit, install steel braided brake lines, bleed whole system, get tires mounted on new rims, get an alignment,.....
Might be more, IDK
I thought you bought a complete STS car.... LOL. We've also learned that it's best to do one corner at a time so we can still make events. If we waited until we finished everything on the STS car we wouldn't have attended an event in the last 2 years!
Jason Frank Bridgestone / Redshift Motorsports STS prepared '89 Civic Si -- teamundercoatracing.com
04-22-2008, 10:09 AM |
04-22-2008, 2:35 PM |
Gefiltefish
Joined on 06-13-2002
Milwaukee WI
Posts 625
Points 6,350
I likely won't be there
The Miata won't be attending WAI events, so I have nothing to drive.
It also part of "Project cut-back 2008"
~Sam Karp~ 1994 Mazda Miata R, ES SCCA-Milwaukee
04-22-2008, 2:46 PM |
04-22-2008, 3:41 PM |
redwhale240
Milwaukee
Posts 83
Points 1,615
How about the TSSCC event the day before, anybody planning on attending? If you didn't know their was an event on 5-3-2008 check out www.tsscc.org for info. I won't be attending the tsscc but ill be at the wai event 1 for sure. As long as nothing else breaks on the car... It's not STS in a 17 year old car if something doesn't break!
Ryan K
04-22-2008, 7:28 PM |
Electronchick
North of Chicago
Posts 15
Points 360
Hmmm, is it May 3rd or May 4th? Maybe I got the dates mixed up....I was told the events are mostly on Sundays and I got Sunday stuck on the brain...Cool, one day sooner!
04-22-2008, 9:14 PM |
redwhale240
Milwaukee
Posts 83
Points 1,615
Electronchick:Hmmm, is it May 3rd or May 4th? Maybe I got the dates mixed up....I was told the events are mostly on Sundays and I got Sunday stuck on the brain...Cool, one day sooner!
There is going to be an event on both Saturday the 3rd (www.tsscc.org) and Sunday the 4th (www.waiautox.org). Follow the hyperlinks to the respective event holders. Both events will be held at Miller Park. Edit: Because I can't make links that work...
Ryan K
04-23-2008, 5:16 PM |
Jake (20CiviC02Si)
Joined on 05-01-2007
Greenfield, WI USA
Posts 81
Points 1,120
redwhale240: Jake (20CiviC02Si):Will be there to hopefully take 1st in STX, that is if Mike doesn't do better than me with his WRX again. Took 2nd on Sunday! Was really nice how the car handled.
Thanks Ryan! Yeah the tires are superb! I can't wait to be able to run a 17x8 wheel with 235/40/17's RE01R on em.
Jake Kaminskis 2002 Honda Civic Si STX SCCA MKE Region www.MidwestTuning.com www.Datatoys.com
04-23-2008, 6:26 PM |
BMoore
Joined on 02-08-2008
Posts 11
Points 175
I don't believe Pops or I will be there. I for sure wont, and my mom tells me Pops wont be there either. I'm not sure he knows yet though...
It's going to an interesting season...
04-25-2008, 3:55 PM |
Gefiltefish
Milwaukee WI
Posts 625
Points 6,350
Mugenlude:
we aren't attending CHI events,
That sucks. Not a good way to prep for Nationals IMO.
Now that Wynveen has joined the fat-car/power ranks of Cashmore and Padberg, we'll NEVER see another slalom in Milwaukee now.
Page 1 of 2 (36 items)
