can you run a harness bar in a stock class?
Last post 04-17-2008, 11:12 PM by Windscreen. 5 replies.
  •  04-16-2008, 9:05 PM 295679
    that's my only question.
     thanks.
    dave
  •  04-16-2008, 9:51 PM 295686 in reply to 295679
    • cmk is not online. Last active: 07/02/2008, 1:13 PM cmk
    • Joined on 03-19-2005
    • Outside Pittsburgh, PA
    • Posts 48
    • Points 485
    Re: can you run a harness bar in a stock class?
    You can find the rules here: http://www.scca.org/documents/Solo%20Rules/2008_Solo_Rules_2.pdf
    The part that you need:
    13.2.I. Driver restraints as outlined in Section 3.3.1 are allowed. Seats may not be cut to allow for the installation of alternate seat belts or harnesses. Passive restraint systems may not be removed. A horizontal “harness bar” may be used as part of the installation hardware for allowed driver restraints. It may serve no other purpose (e.g., structural enhancement).
  •  04-17-2008, 12:14 AM 295718 in reply to 295686
    Keep in mind that safety is paramount.  A harness bar may indeed actually provide somewhat limited structural enhancement if it is built strong enough to actually hold a driver restraint.  I am tired of seeing good safe harness bars not used because they might "add structural enhancement".
    I've seen things as stupid as custom solid mounts in the B-pillars with just a sliding-insert bar to "not provide structural enhancement".....Oh yeah?, I said....one yank, by hand, bent the bar in half and would have potentially been catastrophic and cause injury/death in the event of an incident.  We DO NOT WANT this liability to occur, especially if someone was to drive home to/from an event and get themselves killed over a stupid by-line of a rule.
    I say write a letter for clarification on this, it has bugged me for the past 9 years of autocrossing after seeing many wrecks and incidents at local events.
    /rant
    *Banned Again* Permanently
  •  04-17-2008, 3:10 AM 295727 in reply to 295718
    I find it funny how a harness bar isnt exactly legal but a 4pt roll bar is....
    -James "Budski" Schmidt
    '99 Subaru GC8 Impreza
    old school RS crew
    #20 STS
  •  04-17-2008, 9:32 AM 295748 in reply to 295718
    STS3gCivicSi:
    /rant
    A bar can be properly designed to meet both requirements...be strong enough for AX use, AND not provide structural enhancement.  Your giving good advice....be carefull what you design and use, and *DO NOT* use it on the street.  Retain your factory setup for daily driving.  We can't address what people do on the street on their own time...that's up to them.
    STU Evo
    www.winghats.com
  •  04-17-2008, 11:12 PM 295898 in reply to 295748
    James, please do write that letter.  I agree that we shouldn't discourage use of a good, strong harness bar.  I also agree with you Pat, in that parts can be designed to be reasonably strong, but not provide structural enhancement.  However, why should we drive folks to design and fabricate parts (especially in stock class), when there is a selection of off-the-shelf parts available?
    IMHO, in the majority of cars the bar provides a negligible amount of stiffening, but the rule (13.2.I) doesn't say negligible, it just says It may serve no other
    That, to me, is saying no amount of stiffening is allowed, which is why I'm not currently using a harness bar. Sad
