I'd agree with Lehman that your rear pressure might be a bit high. Depends to some extent on what shocks you're running and what kind of front bar.
I ran my Z06 in Stock trim at 29F/24R, but have seen national-level drivers both higher and lower. You might try 30F/26R and adjust from there (cold pressures) as sort of a middle ground.
