Swaybar Bracket Strengthening
Last post 04-20-2008, 12:24 PM by daverx7. 10 replies.
  •  04-11-2008, 12:35 AM 294601
    4th gen Camaros can break the swaybar brackets, especially in F-Stock where you can have a strong bar and relatively weak springs. I threw up some pictures of how I strengthened my brackets (thanks for the idea goes to the folks at http://www.frrax.com ). I'm curious, is this a Camaro only thing, or do other cars suffer, too? BTW, I'm sure this is F-Stock legal to do, as it is a bolted on part of the swaybar, and some prominent F-Stockers have done it.
    http://www.explodingdinosaurs.com/camaroswaybarbracket/
    1994 Camaro Z28 FS
  •  04-11-2008, 1:19 AM 294609 in reply to 294601
    Re: Swaybar Bracket Strengthening
    i know its legal on the miata but not sure it is on any other stock class car.......it could very well be,,,,,,,,,Sam Strano....you on here?
    David Hedderick
    Pearland (Houston), TX
    01 CRG YZ125
    08 Mazda 3s
  •  04-11-2008, 9:52 AM 294640 in reply to 294609
    Haven't heard of many other cars tearing up their brackets besides Miata.  Agree...looks legal to me.  You're just fabricating a better bolt on bracket, and front sway bars and brackets are free.
    STU Evo
    www.winghats.com
  •  04-11-2008, 11:09 AM 294663 in reply to 294640
    As long as everything mounts up to the original holes, it would have to be acceptable either self fabricated or after market.  Ask Sam about those brackets on the Shelby at Dixie.
    Rob S.
    116 FS 2008 Ford Mustang Bullitt
    Central Carolina Region
  •  04-14-2008, 2:19 PM 295131 in reply to 294663
    I run these on my FS Mustang GT in conjuction with the Steeda sway-bar...
    http://www.atomicperformance.com/index.asp?PageAction=VIEWPROD&ProdID=530
    The steeda bar comes with the typical steel brackets with red poly-bushings, but that billet aluminum one by steeda with the black poly-bushings weighs about the same as the steel, but is much stronger....
    *edit* you might have to copy and paste the link into your browser
    Christopher R.
    Mississippi Region SCCA
    '05 Yellow Pony GT # 69 FS
  •  04-14-2008, 2:31 PM 295137 in reply to 295131
    Since you can add a swaybar to a car that never had one,  you are not limited to stock holes for attachment.   BUT, and a big BUT, the swaybar mount can serve no other purpose, so no connecting subframes or other fun parts.
    Keith
    '07 MINI Cooper S with some sort of stripes
    www.chaserace.com
    www.tightntidyracing.com
  •  04-14-2008, 3:35 PM 295154 in reply to 294601
    100% legal, the bracket is considered part of the swaybar as long as the bracket does nothing else.  For a 4th gen F-body, it does nothing else.
    Phil K.
    2002 Camaro SS, #68 ESP
  •  04-14-2008, 3:45 PM 295155 in reply to 295154
    Every CS MR2 rips it's brackets off.
    Rob Leone
    '07 Solstice GXP in AS
    '87 Toyota Corolla in EP
  •  04-16-2008, 7:18 PM 295656 in reply to 295155
    ES MR2's too.
  •  04-18-2008, 2:04 PM 295952 in reply to 294601
    Even front wheel drive cars can run into problems with tear out at the swaybar mounts.  Integras and Civics can use the stock swaybars without trouble, but a popular mod is putting the thicker Type-R rear bar on these cars.  It works, but without extra bracing the holes rip open.  In that group there are suppliers who sell small brackets to a big plate that spans the entire width of the two mounting locations - reinforcing the whole thing.
    Nice job of fabrication!
    GregHavener
  •  04-20-2008, 12:24 PM 296071 in reply to 295952
    My S2000 just broke a FSB mount.  After that happened, I researched and learned that this is pretty common for this car too.  Mine lasted about 2 years.
    -Dave
