H-Stock Question
Last post 04-11-2008, 5:34 PM by motoring. 4 replies.
  •  04-10-2008, 8:56 PM 294570
    H-Stock Question
    I recently joined SCCA with the intenton of running a few autoX events in the WDCR, the first is on June 1 at FedEx Field.  Anyway I am running my 2008 Rabbit in the HS class and need clarification, the rules for stock class state that a tire may not be a race compound tire, but I have seen that contradicted on a few forums...what is the real deal. I would hate to get out there on R compounds and be put into a class that I have no earthy buisness in. Thanks
  •  04-10-2008, 9:49 PM 294575 in reply to 294570
    Re: H-Stock Question
    You are fine with just about any DOT approved tire in stock class.  Slicks are prohibited because they are not DOT approved.  R-compounds are fine and pretty much required to be competitive in most areas.
    Mark Pilson
    owner of STS2 Honduh
    co-driver of HS Subaru (race tires rule)
  •  04-10-2008, 10:49 PM 294583 in reply to 294575
    There is no rule stating you MUST be on R-comps. Frankly, if you're a complete novice, learning on R-comps may not be the way to go because if you possess any bad driving habits a race tire will mask those.
    Anthony "Mario" Crea
    NNJR-SCCA
    www.autox4u.com
  •  04-11-2008, 5:19 PM 294745 in reply to 294583
    as far as I understand it, stock class cars can change exhaust, dampers, and air FILTER only.
    You CAN run slicks, or, I believe you can run street tires & have a different index.
    Am I right?
    "Most amateur drivers go too fast in slow corners and too slow in fast
    corners"
    Emerson Fittipaldi
  •  04-11-2008, 5:34 PM 294747 in reply to 294745
    mrexotica:
    Am I right?
    Real race tires are generally refered to as "Slicks" and are not DOT approved, and therefore not legal for Stock, SP, or SM.
    R compounds are DOT approved and have at least 2 longitudinal grooves running around the tire, and they are legal for Stock SP and SM
    The is no special index for street tires, although some regions have played with a multiplier to allow comparison between street tire classes (not Street Touring classes) and regular classes
    Keith
    '07 MINI Cooper S with some sort of stripes
    www.chaserace.com
    www.tightntidyracing.com
