STS2 CRX alignment recommendations?
Last post 05-14-2008, 9:46 PM by ibaker. 59 replies.
Page 1 of 3 (60 items)   1 2 3 Next >
  •  04-02-2008, 11:20 PM 293297
    195/50/15 RE-01Rs shaved to 4/32nd
    Ran 37 psi fronts and 34 psi rears
    Listed setup below is what I ran when I was running the RT-615s
    -3 degrees and 0 toe up front
    -2.5 degrees and 0 toe in the rear
    Koni DAs on both end with 430 lb fronts and 500 lb rears
    Stock Si front bar and non adjustable ST rear bar
    After the first event it seems like the car would feel better with a little less camber.  My co-driver and I both agreed we weren't getting as much traction as we could possibly have.  It was a relatively cold day, so it could be a matter of paranoia.
    Any thoughts would be appreciated.
    The Brown Sean
    1988 Honda CRX Si (STS2 #48)
    Not DFL at DC!
  •  04-03-2008, 8:20 AM 293327 in reply to 293297
    Re: STS2 CRX alignment recommendations?
    Before you make any wholesale changes I would wait until you have run on a warmer day...the 'stones definitely do not like the cold.
  •  04-03-2008, 10:50 AM 293339 in reply to 293327
    Take off that front bar.  You don't need it... Sure, it makes the car easier to drive but it's slower since you can't use much gas on exit with out wheelspin and push is the devil.
    You're alignment looks good... maybe a tad too much front camber.
     Pressures seem right.
  •  04-03-2008, 12:11 PM 293351 in reply to 293339
    I'll try no bar this weekend since its a test day, so much for spending all that money last summer and getting new front sway bar bushings.  *laughs*
    I think you guys are right about the cold weather, hand test and pryometer readings were extremely low on the tires.  My notes said ambient temperature was in the 44-45 range.
    The Brown Sean
    Not DFL at DC!
  •  04-03-2008, 12:38 PM 293357 in reply to 293351
    Yeah, I was running an evo school in the Miata last weekend in 55-65 deg weather with no sun and windy conditions.  Even at the warmest of the day doing back to back to back runs, the stones were not at optumim temp.  They were just starting to get happy, then it got cooler and grip dropped again.
  •  04-03-2008, 2:08 PM 293375 in reply to 293357
    Sean, I'm running 0 toe all around as well, with -2.8f and -2.1r
    '91 CRX Si (STS2)
  •  04-03-2008, 2:13 PM 293378 in reply to 293375
    David: we have very similar setups.  I think we both posted ours on roadrace-autox.com once a while back.
    I'll try no bar and hopefully the warmer weather this weekend gives me a little more time to get used to the 'stones.
    The Brown Sean
    Not DFL at DC!
  •  04-08-2008, 1:10 AM 294051 in reply to 293378
    We ran the following:
    Front:  -2.5 camber, 1/8" toe out, no front bar, 36psi
    Rear:  -2 camber, 1/16" toe in, st adj bar on middle setting, 31psi
    The combination of no front bar and the little bit of toe in in the rear really made the car controllable.
     YMMV
    Jay Ruggles
    #97 STS2 CRX "Lil Evil"
  •  04-08-2008, 10:46 AM 294117 in reply to 294051
    TractionCircle:
     YMMV
    Hey Jason, if you're running 15" B-stones that set up sounds pretty damn good.... spring rates?  :)
  •  04-08-2008, 12:56 PM 294157 in reply to 294117
    Hey Matt,  to be honest I don't really remember what the rates were.  It was Darrin's car and they kinda came with it.  I wanna say 450/600 but I think I am making that up.
    Yeah, that was on the 15" stones...we never had the money to experiment with the 16's.  It's a moot point now since that car is in Iowa somewhere :)
    Jay Ruggles
  •  04-08-2008, 2:08 PM 294171 in reply to 294157
    We had 1/8" toe out at Nats...don't you remember, Jay??
    -MK
  •  04-08-2008, 3:49 PM 294191 in reply to 294171
    Yeah, isn't that what I said?  On a side note, I may be calling you about some setup tips on my Z.....
    Jay Ruggles
  •  04-08-2008, 6:02 PM 294208 in reply to 294191
    We'll see if I return that call...Rollseyes
    -MK
  •  04-09-2008, 7:31 AM 294252 in reply to 294208
    Well, I managed to smack a deer in 'Lil Evil heading to a T&T in Des Moines... guess the name fits.
    So, my question for those with more seat time in an STS2 CRX (which is pretty much anyone who has one), do you recommend no front bar for all conditions, low/high grip surface, temp, etc.?  Maybe I was not getting on the power early enough, no push and no problem putting power down.  Most imrpovement would come from left foot braking for smoother transition of front/rear weight when going through some faster off-sets.
    I attended a local school this year with an HF bar and the car rotated very well (cool 45F) and was planning to disconnect it along with a few other adjustments at the T&T, but bambi altered those plans and the racing budget.  A replacement hood, headlight, radiator, and windshield are on order.
     Steve
    Steve Curran
    '89 CRX Si STS2
    "Zippy"
  •  04-09-2008, 9:38 AM 294268 in reply to 294252
    Oh man, that is terrible!  I'm assuming this is really our old "lil evil"?  Post pics!
     We found with the CRX there was never a problem with rotation (hence the name), so removing the front bar was a win win situation.  We didn't really find an instance/surface where the lack of a front bar hurt us.  The car even still slalomed well!
    Left foot braking is a huge win in these cars, just ask Mike King :)  I could never get the hand of it and I'm sure I paid for it in lost time.
    Hope this helps,
    Jay Ruggles
  •  04-09-2008, 11:57 AM 294304 in reply to 294268
    Hmmm, that means that Mike and Jason are both big on LFBing. If I can figure out how to stop hitting cones, then I plan to try to learn LFBing. One thing at a time Smile
    Brian Davis, 89 Civic Si, 158 STS
  •  04-09-2008, 12:17 PM 294307 in reply to 294304
    I don't left foot brake.  I'm trying it out on the street with some success but I haven't tried it at an auto-x yet.
  •  04-09-2008, 2:29 PM 294337 in reply to 294307
    I don't left foot brake....I tried it, but without a harness, I just ended up pinned against the door :)
    Jay Ruggles
  •  04-09-2008, 4:13 PM 294361 in reply to 293378
    Sean,
    How did it go last weekend?
    Eric
  •  04-09-2008, 10:29 PM 294430 in reply to 294361
    Update:
    No bar is the way to go, I noticed a very big difference with the endlinks off.  I am ditching the bar this weekend!
    The Brown Sean
    Not DFL at DC!
