Please explain the April FastTrack SP recommendation on 15.10.J
Last post 03-21-2008, 6:39 PM by randychase. 5 replies.
  •  03-21-2008, 10:56 AM 291284
    http://www.scca.com/documents/Fastrack/08-fastrack-apr-solo.pdf
     I understand the listing changes for the Escorts and the addition of the Street Touring language for camber correction.  I'm not sure about the part on engine mounts and bobble struts.  The part that's printed in the FastTrack looks like the same as what's in the rules but with some sentences left out.  Did they just print the sentences that change and I missed the changes or is the recommendation to leave out the part of those two paragraphs that's not in the FastTrack, and what's the reason for the change?  Thanks!
    DJsilver
  •  03-21-2008, 11:57 AM 291290 in reply to 291284
    Re: Please explain the April FastTrack SP recommendation on 15.10.J
    What is printed is how the rule would work. Anything omitted would no longer matter. Looks like this allows solid motor mounts to me.
    Nate Whipple
    NER
    188/88 DSP ITR
  •  03-21-2008, 3:19 PM 291315 in reply to 291290
    I emailed my SPAC rep for clarification and he said that removal of the language was intended and that, if this is approved, you'll be able to run solid motor mounts if you like.  I like my teeth so I'll stick with rubber mounts regardless of which way it goes.  For the record, I sent an email in favor of the listing changes and the camber correction rules but against the motor mount rule.
    seb@scca if you wish to comment.
    DJsilver
  •  03-21-2008, 3:52 PM 291334 in reply to 291290
    solo-x:
    Which is effectively the case now, since Delrin is legal and provides almost the same level of "solidity" as metal.  The whole "metal" thing is way past its prime.
    --Andy
  •  03-21-2008, 6:08 PM 291367 in reply to 291334
    • actor is online. Last active: 07/24/2008, 3:31 PM actor
    • Top 500 Contributor
    • Joined on 11-20-2001
    • Los Angeles, CA USA
    • Posts 199
    • Points 1,870
    Andy Hollis:
    ...Delrin is legal and provides almost the same level of "solidity" as metal.
    --Andy
    Yes, they do! :-)
    Bill Schenker
    CalClub & S.D.R. #14 CSP 10AE Miata
  •  03-21-2008, 6:39 PM 291371 in reply to 291334
    And it's more slippery too. Delrin rocks.
    2006 Noble M400 (E-Mod?)
    http://chasecam.com/ official supplier to SCCA Pro Racing. Sponsor for SCCA ProSolo. Supplier to MazdaSpeed, V8Supercars, etc.
