96' Impala SM? or what?
Last post 03-10-2008, 7:31 PM by SMSupercoupe. 5 replies.
  •  03-09-2008, 1:41 PM 289130
    96' Impala SS
    GM B-body @ 4300+ lbs
    Fully built 358ci / 5.86 Liter LT-1 stock stroke NA - factory engine just .045 over
    Fully built automatic - factory trans
    Fully built mostly billet adjustable suspension
    Kumho 710's or Nitto 555s depends on my mood
    Ususally when I show up they don't know what to put me in at the sign in table.
    The car is pretty quick on track, from the events I have attended.
    I have been in FModified at two SoCal SCCA events in the past??
    I have been told on sccaforums: NC  ESP CP SM
    I don't even know what that means, yet.
    Anyone in SoCal wanna help me out show me the ropes?
    Need to get the car / my driving evaluated and have some fun.
     Elephant on Roller Skates
    NotoriouSS Tad
    96' Impala SS - Johhny 5 - 4300+lb - 12.8-1/4
    NA 390RWTQ+ 431RWHP unlocked 91
    suspension and motor build ar autocross oriented
  •  03-09-2008, 7:48 PM 289154 in reply to 289130
    Re: 96' Impala SM? or what?
    Anything internal on the engine other than an overbore and port matching automatically moves a car to SM, I believe.  So if you have a cam and/or head work, that's where you go.  The easiest way to get into CP is to strip the interior or start cutting on the unibody/frame, depending on what your car has.  Replacing a K-member is a no-no for SM.  I'm assuming NC means novice class, and since that's not an actual national class you'd just have to ask the local guys what their rules are like for that class.
  •  03-09-2008, 8:51 PM 289162 in reply to 289130
    • Jaker is not online. Last active: 08/20/2008, 11:59 PM Jaker
    • Top 500 Contributor
    • Joined on 03-25-2003
    • Surrey, BC, Canada
    • Posts 239
    • Points 2,545
    What ever happened to the displacement limit in SM? I'm sure there used to be one, and it does make reference to it section 16 of the rules ("see displacement limit in appendix A"), but htere's nothing in Appendix A.
  •  03-10-2008, 2:02 PM 289264 in reply to 289162
    Jaker:
     no displacement limit in SM anymore. to the OP, you can run SM for fun. ESP is out, and CP is a possibility. if you plan on gutting the car, CP will be the way to go. besides, you prob stand a better chance of winning CP then SM... Stick out tongue
  •  03-10-2008, 4:46 PM 289306 in reply to 289264
    any links to were I can look at class rules and info?
    NotoriouSS Tad
  •  03-10-2008, 7:31 PM 289342 in reply to 289306
    http://scca.org/documents/Solo%20Rules/2008_Solo_Rules_2.pdf
