Weight vs. power
Last post 05-05-2008, 9:35 AM by Bobzilla. 40 replies.
03-09-2008, 5:35 AM |
atechnica
Joined on 05-23-2007
Posts 80
Points 1,205
Say you have two cars, they have an extremely similar suspension setup and are on the same tires, one has 70whp and weighs 2000 pounds, one has 120whp and weighs 2300 pounds. They are both FWD open diff and the lighter car also has a 2 inch shorter wheel base. How much of a difference will there be in the performance?
03-09-2008, 8:49 AM |
ebnrt
Joined on 04-20-2004
East Troy
Posts 374
Points 5,570
323 vs. EGT?
Erik B. Wisconsin Autocrossers, Inc www.waiautox.org ___/\___/\___/\___/\___/\___ 2007 Mazda6 2000 "Fozda" ZX2 S/R--STS Anti-Civic
03-09-2008, 10:27 AM |
ProDarwin
Joined on 05-18-2007
Nova
Posts 37
Points 690
When you say same tires... same compound, or same size? I look at it this way... the Civics that dominate STS are dog slow in a straight line. But they only weigh 2000lbs.
-Travis Finlay 1997 Saturn SC2 2002 Subaru 2.5RS 1995 YZF 600R
03-09-2008, 1:18 PM |
jzr
Joined on 10-20-2002
San Diego, CA
Posts 787
Points 11,375
atechnica:
They both get slaughtered by the cars on those same tires, that have even better suspensions, make 120whp, and only weigh 2000 pounds.
STS Civics are not that slow in a straight line, at least in comparison to other STS cars.
03-12-2008, 2:35 AM |
03-12-2008, 11:02 AM |
03-12-2008, 11:34 AM |
03-12-2008, 8:12 PM |
atechnica
Posts 80
Points 1,205
turbohappy:Weight is definitely more important, to a point. You have to have some power though. And a good suspension design. It's a mix for sure. If weight completely dominated the other factors, you'd see 1600 or 1700 lb cars on top of STS, not 2000 lb cars.
We had a nearly stock old old old style civic with 50hp play in STS here and it did SURPRISINGLY well. It kinda makes me wonder. I can't really think of anything that's better than the 89 civic, but I got a 323 for $200 so I was considering trying it once or twice just to see what would happen.
03-12-2008, 8:53 PM |
jdgomez
Joined on 03-12-2008
Posts 1
Points 20
Go for the lighter one. Just add a little more power to it and the good suspension design turbohappy suggested. :) _____________________________ Perfect trucks, perfect truck parts.
03-25-2008, 5:50 PM |
Grintch
Joined on 06-04-2004
Huntsville, AL
Posts 137
Points 1,340
It all depends. Land speed racing - its all about power and drag Drag racing - its all power to weight Autocross - is more about weight, because lightweight makes you accelerate faster in ALL directions (better braking, cornering, and straight line acceleration) Road racing - is a mix between Autocross and drag racing And of course, a really light car on skinny tires will often be beat by a heavier car with wide tires. So think tire to weight too.
Bruce Funderburg '02 CMC 7 - DM '04 Subaru WRX STi - STU It will be of little avail ... if the laws [or rules] be so voluminous that they cannot be read, or so incoherent that they cannot be understood... Alexander Hamilton
03-26-2008, 12:39 AM |
Mooobunnny
Joined on 05-29-2007
Posts 77
Points 1,295
ProDarwin: I look at it this way... the Civics that dominate STS are dog slow in a straight line. But they only weigh 2000lbs.
I have to agree with Jason here, a fully prepped STS civic is pretty darn fast in a straight line. I was amazed when I first drove one with a healthy motor.
03-26-2008, 11:36 AM |
SeniorPBA2B
Joined on 08-30-2005
Posts 71
Points 875
Grintch:
Basic physics suggests otherwise, and has been proven in many different classes in drag racing, i.e. Bill Jenkins small block Vega vs. Sox & Martin Hemi Cuda. Given equal power to weight ratios, the lighter car will be quicker due to the forces of inertia. "An object at rest tends to stay at rest." It is easier to get the lighter vehicle moving. Henceforth, it it also easier to get it to slow down or change direction. "An object in motion tends to stay in motion."
200 hp @ 2000 lbs. vs. 400 hp @ 4000 lbs. ... my money is on the lighter car.
03-26-2008, 1:31 PM |
Grintch
Huntsville, AL
Posts 137
Points 1,340
Basic physics is F=m*a (force = mass x acceleration) or a = F / m. Where HP is related to the force availible. The Vega & Cuda probably both mounted the same size rear tires, so the Vega had the superior tire to weight ratio. So if you have the choice of sending $1000 to reduce the weight by 10% or increase the power by 10%, for top speed increase power for drag racing it is close to a wash (with fixed tire sizes, reducing weight will be slightly better) for autocross or road racing reduce the weight Of course in real life the choice is never that easy, too many other factors (like what the rules allow), and the comparative cost and results usually aren't known ahead of time.
03-26-2008, 2:00 PM |
tkm
Joined on 10-20-2001
OH
Posts 922
Points 14,725
Mooobunnny: ProDarwin: I look at it this way... the Civics that dominate STS are dog slow in a straight line. But they only weigh 2000lbs.
They should at least be mid 15 second 1/4 mile cars if fully built for STS. I wouldn't call that extremely fast, but that certainly isn't dog slow, either.
Todd Too many ST cars "Restricted Area Racing"
03-26-2008, 4:37 PM |
atechnica
Posts 80
Points 1,205
tkm: Mooobunnny: ProDarwin: I look at it this way... the Civics that dominate STS are dog slow in a straight line. But they only weigh 2000lbs.
I wouldn't be surprised if they were faster than mid 15's, my STS car (the 120+?whp 2300lb one) runs even with low 15 second cars from a roll, but then it does have more torque than a civic.
03-26-2008, 5:31 PM |
atechnica
Posts 80
Points 1,205
SeniorPBA2B:FWIW: We've run 14.60's with our STS Neon ACR.
That's impressive, what was your power/weight and tires? EDIT: actually this is interesting enough to make a thread out of :cool:
03-26-2008, 9:13 PM |
gtitronic
Joined on 03-13-2005
Boulder, CO
Posts 56
Points 720
ya.. I foolishly thought my old 97 GTI VR6 would be the fastest STS car in a straight line with 150hp and 160lb-ft to the wheels (at mile high elevation), though it was 2700lbs and not fully prepped or lightened at that. At the 2006 Denver ProSolo I went up against many well-prepped Civic Si's and I had nothing on them. After the first corner it was all downhill of course.. especially as I was using the same 205/50-15 Azenis 615's that they were. Good times. http://naufana.com/autox/20060722diaprosolo (videos)
-Kelly Rocky Mountain Region - 94 Integra DB8 STS/ codriver B18C'ed JRSC'ed EG Civic hatch SM. Apex RacingGroup.com
04-16-2008, 11:27 PM |
Chris D
Joined on 12-14-2007
St. Louis, MO
Posts 143
Points 2,350
gtitronic:ya.. I foolishly thought my old 97 GTI VR6 would be the fastest STS car in a straight line with 150hp and 160lb-ft to the wheels (at mile high elevation), though it was 2700lbs and not fully prepped or lightened at that. At the 2006 Denver ProSolo I went up against many well-prepped Civic Si's and I had nothing on them. After the first corner it was all downhill of course.. especially as I was using the same 205/50-15 Azenis 615's that they were. Good times. http://naufana.com/autox/20060722diaprosolo (videos)
I foolishly thought the same thing this year. My tC pushes about 163hp at the wheels and weighs about 2800lbs. Needless to say, I'm finding I need to do a lot of suspension work so I can handle all the weight I'm throwing around the track. Weight definitely has the advantage over the power, unless you're running on a course with straights long enough to where you can utilize all that power.
#12 STS 2007 Scion tC #24 ITS/DSP 1991 Nissan 240SX
Page 1 of 3 (41 items)
