**new here** what class is my heavy sled in
Last post 06-08-2008, 6:53 AM by caSSino. 10 replies.
03-07-2008, 1:56 PM |
NotoriouSS
Joined on 03-02-2008
SoCal
Posts 14
Points 265
**new here** what class is my heavy sled in?
96' Impala SS - GM B-body @ 4300+ lbs Fully built 358 LT-1 stock stroke NA - factory engine Fully built automatic - factory trans Fully billet adjustable suspension Kumho 710's or Nitto 555s depends on my mood
NotoriouSS Tad 96' Impala SS - Johhny 5 - 4300+lb - 12.8-1/4 NA 390RWTQ+ 431RWHP unlocked 91 suspension and motor build ar autocross oriented
03-08-2008, 10:23 AM |
NotoriouSS
SoCal
Posts 14
Points 265
Re: **new here** what class is my heavy sled in
motor is a 358 cube inch or 5.86 Liters factory motor - blue printed
Am I in SM?
03-08-2008, 11:11 AM |
cmt52663
Joined on 04-16-2004
Wenham, MA
Posts 206
Points 2,810
13.10 "rotating and reciprocating parts may not be balanced", so the Stock class is out
15.10.R "rotating and reciprocating parts may be balanced but not lightened", and .S which permits port matching
I'd guess ESP, but other folks on this forum would know better. I am unable to find an Impala line in the Chevrolet section of the ESP car list, nor is there a Not Otherwise Classified catch-all that I can spot. Unless you intend to run Nationally with that car I'd expect the Region to exercise some judgement. Mostly I'd say it'd just be fun to see it run, and to drive it.
Charlie Thompson '04 JCW Cooper [STX] NER Cannon Fodder
03-09-2008, 10:15 AM |
00R101
Joined on 08-24-2001
Litiz, PA, USA
Posts 310
Points 5,265
That's a NC car if ever I saw one :-)
Run it in ESP locally but I think its a CP or SM car nationally.
Regards,
Alan
Alan Pozner Slow and proud
05-27-2008, 1:13 PM |
my96dcmimpalass
Joined on 05-10-2004
Posts 35
Points 485
NotoriouSS:
If your "fully built" engine has either been lightened or balanced, you are in CP. If your bore is over 0.020", but less than 0.060" (I'm guessing it's 0.040"?), you are in CP. If you have changed from the 3.08 rear gear, you are in CP. That is just making some quick assessments, and reading through here: http://www.scca.com/documents/Solo%20Rules/2008_Solo_Rules_2.pdf
Hope this helps! (from a fellow SSer!)
Bob P. '96 Impala SS St. Louis, MO
06-03-2008, 4:11 PM |
caSSino
Joined on 09-05-2006
Posts 22
Points 125
my96dcmimpalass: NotoriouSS:
I thought you could change rear end ratios and stay in SM, but Tad you are definatley above ESP specs.
P.S. Now we just need to get Ed into this thread and it will be like the Impala forum over here.
Mike Casino 95 Impala SS (maybe 10% prepared CP car)
06-04-2008, 9:24 AM |
my96dcmimpalass
Posts 35
Points 485
caSSino: my96dcmimpalass: NotoriouSS:
I thought so, too, but didn't see the provision in the SP section. Maybe I just overlooked it.
Hey, CaSSino, are you going to be in St. Louis this year?
06-04-2008, 12:55 PM |
Impala SS AutoXer
Joined on 05-13-2003
Santa Clara CA, USA
Posts 70
Points 960
I told Tad months ago on the SS Forum (before he even headed over here) that it was a CP or SM car. Evidently I'm not a credible source
06-04-2008, 1:54 PM |
bharmer
Joined on 03-17-2008
Topeka, KS
Posts 13
Points 305
my96dcmimpalass: caSSino: my96dcmimpalass: NotoriouSS:
Rule 16.1.D says "Drivetrain and related components (induction, ignition, fuel systems, etc.) are unrestricted except for the following limitations."
Those limitations are that the engine must be from the same manufacturer. So that rule right there says he can be in SM. Now since the the displacement increased then the minimum weight increased. Although with that engine your minimum weight is going to be higher then highest minimum weight (No car is required to weigh more than 3100lbs).
Brian Harmer SCCA Solo Technical Assistant Solo National Rules: http://www.scca.com/documents/Solo%20Rules/2008_Solo_Rules_2.pdf FastTrack: http://www.scca.com/contentpage.aspx?content=78
06-08-2008, 6:53 AM |
caSSino
Posts 22
Points 125
No plans for St. Louis this year but if all goes well maybe I will find my way out to Topeka.
