Holy Splitter Batman! - is it legal?
Last post 01-29-2008, 10:20 AM by 129STS. 15 replies.
01-26-2008, 11:11 AM |
ChrisSwearingen
Joined on 08-01-2006
Posts 97
Points 1,395
The 2008 SCCA rule book says that in SM/2
[QUOTE=SCCA]
M. Front splitters are allowed and shall be installed parallel to the
ground (within +/-3 degrees fore to aft) and may extend a maximum
of 6 inches forward of the front bodywork/fascia as viewed
from above. Splitters may not extend rearward past the centerline
of the front wheels. No portion of the splitter may extend beyond
the widest part of the front bumper/fascia as viewed from
above.
[/QUOTE=SCCA]
So without getting into the merits of the design etc, I just want to
gather opinions as to whether or not it's legal before I make it out of
anything other than cardboard and start testing.
Chris 51 SM2
01-26-2008, 3:33 PM |
Joe_914
Joined on 12-05-2005
Gulf Coast
Posts 533
Points 2,845
Re: Holy Splitter Batman! - is it legal?
No such thing as too much down force at 60-70 MPH top end speed.
Just remember to do a wing equally big out back.
I've been designing one like these in my head for awhile now. Is yours going back to the front axe?
Want to go faster, please send money.
01-26-2008, 5:08 PM |
ChrisSwearingen
Posts 97
Points 1,395
The rules say it can go to the centerline. I may stop at the front of the crossmember. And for the rear
Chris 51 SM2
01-26-2008, 7:52 PM |
Rodney
Joined on 01-16-2003
new friggin york
Posts 273
Points 3,535
holy cone splitter.... you will chop them in half if you hit one. do too many, and you will get a bill from the scca at the end of the event...
01-26-2008, 10:20 PM |
ChrisSwearingen
Posts 97
Points 1,395
Rodney:holy cone splitter.... you will chop them in half if you hit one. do too many, and you will get a bill from the scca at the end of the event...
Then I could have a half off cone sale....... Thanks, I'm here all week, try the veal!!! SO... If I slice the cone in half, and the bottom stays in the box, no penalty right?
Chris 51 SM2
01-27-2008, 12:31 AM |
geewiz
Joined on 07-13-2005
Posts 92
Points 880
My splitter looks exactly like what you are templating, Chris. And in fact, APR should now have a suitable pattern on file ;-).
And I have a strangely similar wing as well (shorter pedestal, though, to comply with XP rules)....
Jesse, I don't understand the pin & wrap mounting you are describing. By 'wrap' are you referring to a lip with five screws attaching the splitter to the air dam?
-- Glenn
01-27-2008, 4:53 AM |
129STS
Joined on 10-01-2001
Posts 1,131
Points 16,145
geewiz:
-- Glenn
The cotter pins hold the actual splitter up. The "wrap" we have is a separate piece of cotton belting material. It sits perpendicular to the splitter surface, and covers the area between the bodywork and the splitter. Hopefully that describes it, as I don't have any pictures handy. Of course, I'm awake before 5am because I'm going to an event this morning.... maybe I should bring my camera. :)
01-27-2008, 9:50 AM |
Rodney
new friggin york
Posts 273
Points 3,535
129STS: Of course, I'm awake before 5am because I'm going to an event this morning.... maybe I should bring my camera. :)
fuggin sucks... it is 20 degrees here... :( i haven't run since topeka
01-27-2008, 2:09 PM |
SS RX7 R2
Joined on 03-26-2003
Irvine, CA
Posts 101
Points 1,690
geewiz:
And I have a strangely similar wing as well (shorter pedestal, though, to comply with XP rules).... -- Glenn If anyone is interested, I can help with custom or off the shelf APR wings/splitters. We've been supporting the solo community with carbon fiber and aluminum aero APR parts, including the large custom SM/2/XP dual element set-ups. PM or email for racer's discount.
01-28-2008, 12:13 PM |
DrJones_CMR
Joined on 08-07-2006
Ohio :(
Posts 131
Points 1,070
"SO... If I slice the cone in half, and the bottom stays in the box, no penalty right?"
we thought about this with an a-mod car and some tight piano string across the front wing. and just drive straight through a slolam :)
But i just looked in the rule book
7.9.1 "...If the pylon is upset or totally displaced outside the penalty limit, two seconds will be assessed..."
that makes it kinda gray. the rule says totally displaced. using this you could say the cone was not totally displaced.
Alex Jones 2007 A-Street Prepared GXP www.CrazyMonkeyRacing.com  because 285's were not enough...
01-28-2008, 12:27 PM |
ChrisSwearingen
Posts 97
Points 1,395
DrJones_CMR:"SO... If I slice the cone in half, and the bottom stays in the box, no penalty right?"
no, but I am willing to bet that if cut in half, the pylon would be Upset. I agree the design is legal, just was a bit shocked at how big it actually was. I trimmed it back a bit as I want to put an air dam around the front and that will make it a bit wider. Prototype is cut out, but not attached yet. The good news is you can get two of them out of one 4x8 sheet of material, but not one out of a 4x4 sheet.
Chris 51 SM2
01-28-2008, 1:40 PM |
Stan Whitney
Joined on 10-04-2004
DFW
Posts 308
Points 2,700
Part of the downforce generated is the negative pressure on the underside of the splitter. You want to maximize that area, go all the way to the wheel ceneterline, and as wide in between the wheels as you can. Just 0.10 psi of negative pressure adds up to quite a bit as the number of square inches go up.
01-28-2008, 3:22 PM |
DrJones_CMR
Ohio :(
Posts 131
Points 1,070
ChrisSwearingen:no, but I am willing to bet that if cut in half, the pylon would be Upset.
off topic -
I have only seen a cone get cut in half once and the lower portion stayed in the box. Sure the cone was badly damaged before the impact and should have been replaced before the event. Still a funny story thought :D
01-29-2008, 10:20 AM |
129STS
Posts 1,131
Points 16,145
So I did get around to snapping a picture of the "wrap". EDIT: the attachment won't work...
http://img254.imageshack.us/my.php?image=picture001bh2.jpg (copy and paste)
