Ignition Switch issues
Last post 09-17-2007, 4:25 PM by gc102750. 1 replies.
  •  07-17-2007, 9:14 AM 254153
    I tried to put a Longacre Ignition switch on my 84 RX7 (IT7). I hooked the White/Red wire to brown power in wire. I hooked the Black/White to the yellow accessories wire and I hooked the Black/Yellow to the green starter button wire. When I flip the toggle switch I can tell the gauges are getting power. When I press the starter button, it sounds like the fuel pump is kicking on, but it is not spinning the starter. It almost seems like I need to hook both the Black/White and the Black/yellow to the yellow accessories wire, but then I'm not sure what I should hook the green starter button wire to.
    Any ideas on what I have hooked up wrong?
    Thanks, Gordon
  •  09-17-2007, 4:25 PM 264416 in reply to 254153
    Re: Ignition Switch issues
    Was able to solve this.
