Daily Driver/ Autocross car that is competitve but won't beat me up 10k and under
Last post 04-10-2008, 3:42 PM by mrexotica. 55 replies.
Page 1 of 3 (56 items)   1 2 3 Next >
  •  05-28-2007, 4:15 PM 246500
    I think the time has come to sell my Miata that I have been using for the past several years from E stock, SM2, and lately CSP. I recently moved to a major metropolitan area and I cannot stand the car anymore. I dont have any storage space for simple trips to the supermarket or out to dinner with friends. The car has been a blast but its too rough, loud, and small for my current needs. I do not want to hear anything about you can put alot of stuff in a Miata I know but it gets old after 4 years of stacking tires behind your head or moving them from your apartment to the street and back every time you need to use the car.
    So the question is what can I get for 10K and under that meets the following loose criteria
    Drivetrain: fwd, rwd, awd I dont have a strong preference they can all be fast if properly setup but rwd would be nice
    Weight: under 3,000 pounds
    Number of doors: either coupe or 4 door depending on size and weight
    Power: My Miata had 100 whp and was alot of fun so 4,6,8 power isnt a huge consideration just looking for decent gearing and power to weight ratio.
    I need something that will be competitve regionally have decent usuable everyday space and comfort. I want to stay out of prepared classes and stick to stock level prep. My list that I put together includes
    E36 BMW 318 sport fo H stock, E36 BMW M3 B Stock, Acura Integra D Stock, Toyota Celica G Stock, Eagle Talon D Stock
    Please help me out with any other suggestions. Also I must note that I can do my own maintinence to a point but I am not looking for a nightmare to keep on the road either.
    Ryan
  •  05-28-2007, 5:28 PM 246513 in reply to 246500
    Re: Daily Driver/ Autocross car that is competitve but won't beat me up 10k and under
    Well, the only car I've driven to an autocross that I've not needed more space is my 05 Camry. I would recommend that you get a trailer or a tiretail as a fix.
    If you're looking to get a tiretail talk to  Sean of http://www.izoomgraphics.com as he has a Miata and uses his tiretail at local events.
    From your list and considering the criteria of being able to stay reliable and being easy to maintain, I would recommend the Celica or the Integra.
    I personally would like to have a good Integra Type-R and run more competitively in DS.
  •  05-28-2007, 5:35 PM 246516 in reply to 246513
    I have a tire tail and used a tire trailer before I moved.
  •  05-28-2007, 5:46 PM 246517 in reply to 246516
    powersmx5:
    So basically I gather you're tired of using either and want to run a turnkey car on Street Tires?
  •  05-28-2007, 5:54 PM 246519 in reply to 246517
    I would like a turn key car and still like to use race tires but the issue I had was storing the tires. I would like to leave the tires in the car or the back seat in the tire rack totes.
  •  05-28-2007, 6:00 PM 246520 in reply to 246519
    Well on either of the cars I recommended, you probably could do that. I'm getting a trailer so I can keep stuff completely out of the car. Right now, the good thing is that I've got the Camry so I keep all the stuff in my race car and leave it in the garage.
  •  05-28-2007, 6:17 PM 246523 in reply to 246520
    Can't really go wrong with a type-R...
    Or a mini cooper.
  •  05-28-2007, 6:22 PM 246525 in reply to 246523
    I didn't think you could buy a type R for my price range?
  •  05-28-2007, 6:22 PM 246526 in reply to 246523
    You're going to have a hard time finding a lot of the cars you mentioned under 10K.  An E36 can't be had under 15K in any kind of shape.
  •  05-28-2007, 6:35 PM 246528 in reply to 246526
    Here are some additional HS cars that might work for you:
     Acura RSX, Honda Civic Si (previous model), Nissan 200SX SE-R
    Jeff Hurst, NYR SCCA
  •  05-28-2007, 9:14 PM 246546 in reply to 246500
    a 2004 mazda3i might be a decent HS car... the base model MSRP's at 14 or so, so should be down to under 10 by now.
  •  05-28-2007, 11:27 PM 246563 in reply to 246546
    root:
    The Kev Master agrees that from the list of cars mentioned only the Mazda 3i would probably be easily had for under 10k You don't want the Eagle Talon or a Mitsubishi Eclipse by any chance as they have horrible reliability.
  •  05-28-2007, 11:29 PM 246565 in reply to 246528
    jeffh:
    Or you could sneak in one of the above cars for under 10k
  •  05-29-2007, 8:51 AM 246608 in reply to 246565
    Is an SVT Focus competitve regionally because it looks like a great all around car.
  •  05-29-2007, 10:57 AM 246643 in reply to 246608
    powersmx5:
    That depends on your local competition because it is in GS along with the new Civic Si and the almighty Cooper S.
  •  05-29-2007, 2:11 PM 246686 in reply to 246643
    An 02 WRX looks like a great car also. Every day space and awd for winter months. Does anyone have experience with a WRX as far as stock performance in D stock?
  •  05-29-2007, 3:14 PM 246695 in reply to 246686
    BMW 318i (E36 chassis)
    Matt Murray
    I am perfectly capable of learning from my mistakes. I will surely learn a great deal today.
  •  05-29-2007, 3:29 PM 246703 in reply to 246695
    The RX-8 fits all your criteria except price.  Maybe a 1st gen Sentra SE-R.  The E36 M3 is no fun to drive without camber plates so no B stock.
    -2006 Lotus Elise- SS
    -2000 Honda S2000- AS
    -2009 Mini Cooper S- GS
  •  05-29-2007, 3:42 PM 246707 in reply to 246563
    The Kev Master:
    root:
    Hmm I've had 3 Neons and 1 Eclipse,all with basically the same drivetrain and no significant problems from either.2 of the Neons have over 140,000 on the odometer and the Eclipse has 97,000.I've found them to be very durable.For the room I'd say pick a Mazda3 or Mini Cooper,both can be had for around $10,000.The Eclipse is not bad but the Neon has a ton more room with the same 2.0 driveline.
    Anthony Hodges
    95 Neon DSP 72
    Stokesdale,NC
  •  05-29-2007, 3:47 PM 246708 in reply to 246695
    Sentra SE-R SpecV.   Now that it's moved from DS to GS, it should be a competitive local/regional car.
    2007 Mazda MX-5 MRS (C-stock)
