Nitto NT-01 tires for autocross
Last post 06-07-2007, 10:31 PM by 83911SCDrew. 6 replies.
  •  04-28-2007, 10:58 AM 242548
    Anyone tried these for autocross?  I was thinking of getting these instead of v710s for my g35.
    The reason why I am asking is because I have been autocrossing for about a year and a half and still learning a lot every time I go out.  I was thinking since these are less expensive about 900 vs 1075 shipped a set and hae a higher treadwear they would work for me better for me (lastlonger)  since I am just learning and not going to be winning anything substaintial anytime soon.
    I was wondering what you thought about them....
  •  04-28-2007, 1:21 PM 242554 in reply to 242548
    Re: Nitto NT-01 tires for autocross
    If you are wanting to stay cheap you could look for the AVON's that are on closeout at Tirerack, although they won't last as long as the Nittos its a cheap way to try out some R-comps.  I have been running some Hankook Z211's this year which I got from frisbyracetire.com which are similar to the Nittos but are on closeout and are quite a bit cheaper.
    Ryan Kowalewski
    Pontiac Solstice GXP
    21 BSP
  •  04-28-2007, 10:15 PM 242572 in reply to 242554
    The word on the street is that this is the Toyo RA1 compound. If that's the case, they are apoor choice for autocross. The RA1 compound is meant for road course use and needs more heat than you can build up at an autocross to work well. A better choice might be a Kumho Victoracer. They are a long-wearing tire like the NT-01, but should warm up faster on short runs. At least, 205s on my 2200lb Miata heat up well enough.
    -Philip Maynard
    No weenies!
  •  04-29-2007, 6:59 AM 242586 in reply to 242554
    • ebnrt is not online. Last active: 02/08/2010, 8:25 PM ebnrt
    • Top 150 Contributor
    • Joined on 04-21-2004
    • In Grid--with the A/C on
    • Posts 646
    • Points 10,710
    duck_hunter_117:
    If you are wanting to stay cheap you could look for the AVON's that are on closeout at Tirerack, although they won't last as long as the Nittos its a cheap way to try out some R-comps. .
     I agree.  If you prefer the long-wear-but-still-pretty-sticky-tire, I also agree that the Victoracers are a good choice.
     I'm off  now to play on my Avon's...Wink
    Erik B.
    Wisconsin Autocrossers, Inc
    www.waiautox.org ___/\___/\___/\___/\___/\___
    2007 Mazda6
    2000 "Fozda" ZX2 S/R--ST unCivic
  •  04-29-2007, 9:07 PM 242619 in reply to 242586
    Are Victoracer V700's available in your size?
    I learned on a shaved set of these and they seemed to last forever... They are much better than streets, but just get out gunned with the V710's, A6's and likely Z214's.
    Just a thought.
    -Dave
  •  05-01-2007, 1:06 AM 242834 in reply to 242572
    John (motorsports engineer) actualyl said it's a R888-like compound. Either way, it's not recommended for autoX.
    my track blog:
    vsetrack.com
  •  06-07-2007, 10:31 PM 248183 in reply to 242834
    I have run RA-1s for several years now as a track/autox/street tire on my 911, and I think they are the best of all worlds.  I did an event on the Nitto NT-01s driving a Cayman S, and I thought they were almost worse than street tires.  I would not run the Nittos for autox.
    FWIW, Toyo's website says that the RA-1 has the same compound as the NT-555 Drag Radial, not the NT-01.
