330i setup?
Last post 06-13-2008, 5:57 PM by murph1379. 93 replies.
11-05-2006, 6:51 PM |
murph1379
Joined on 11-05-2006
Minneapolis
Posts 117
Points 1,800
I'm replacing my Mazdaspeed Protege with (provided the inspection checks out tomorrow) a 2001 330i sport. I took 2nd locally (missed first by a hair!), and all our DS regulars have decided to go to nationals together next year, though none of us expect to be contenders. (the other three are in Type-Rs) We're all in the top 20 PAX locally. I'd love to do better, but if I can be consistently 1st or 2nd locally (as this year) I'll be happy. I imagine it will take me some time to get used to RWD and a bit less steering feedback. I can tell the 330 is definitely not as well-sorted from the factory as the MSP was, so the question is, what do I need to do? I haven't found any definitive guides, but from what I read it seems that Koni double-adjustables, a front bar, and an alignment are what I'm looking at. Am I missing anything? Is there a specific line/model of koni's I should look for? The car seems to have 225/45/17's on it, with the M3 (sport package) wheels. I already have 225/45/17 V700's, so I'll use those, but I will need to buy another set of wheels, are there other options I have for this car? (I've heard that the newer 330CI can use bigger wheels, but AFAIK this one can't, correct?) Thanks for your input, Matt
11-05-2006, 8:12 PM |
11-05-2006, 8:46 PM |
mattm
Joined on 02-01-2004
Westport, Connecticut
Posts 1,107
Points 10,490
murph1379: I'm replacing my Mazdaspeed Protege with (provided the inspection checks out tomorrow) a 2001 330i sport. Matt
Why are you bailing from the MSP? They are very competent in D Stock. The MSP has a limited slip, correct?
Matt Murray I am perfectly capable of learning from my mistakes. I will surely learn a great deal today.
11-05-2006, 8:48 PM |
bren
Joined on 05-13-2005
Posts 66
Points 595
They are still there.....look at the bottom of Nat's results :p AFAIK, 225 isn't nearly enough tire. TC Kline sells Koni DA's and you'll want the largest front bar you can find (probably H&R or Ground Control.) I don't recall what years the 330 was available with 18" wheels, I think it was 2002 and possibly early 2003. Either way you'll want to find some light aftermarket wheels as the OE wheels are very heavy.
www.teamWTF.org WDCR AS C4 z51 ASP e46m3 "slower than an Evo" ;)
11-05-2006, 10:13 PM |
mattm
Posts 1,107
Points 10,490
bren: They are still there.....look at the bottom of Nat's results  AFAIK, 225 isn't nearly enough tire. TC Kline sells Koni DA's and you'll want the largest front bar you can find (probably H&R or Ground Control.) I don't recall what years the 330 was available with 18" wheels, I think it was 2002 and possibly early 2003. Either way you'll want to find some light aftermarket wheels as the OE wheels are very heavy.
You can still find them in the top third of the class. Look to about tenth. You can order Kline's stuff through Bob Tunnell at bimmerhaus.com. In '03 (actually late in the 2003 production run) BMW offered a "Performance Package" with an option code of ZHP. One part of the package was 18" wheels (8" in front and 8.5" in the rear), among other options. You could probably stuff a 285-18 on the rear.
11-05-2006, 10:58 PM |
Mike Shields
Joined on 08-25-2002
Temple, NH
Posts 277
Points 3,910
mattm: One part of the package was 18" wheels (8" in front and 8.5" in the rear), among other options. You could probably stuff a 285-18 on the rear.
Yeah, but would you want to? Does the 330i ZHP really need more rear-end grip? Was the problem at Topeka putting the power down?
Now possibly more interesting would be if a 285 all around would give you the extra grip that's obviously needed. The Solsti have run both 245 and 285 on their 18x8 wheels, albeit with a better front suspension design. I don't know if either way is faster
-Mike
Mike Shields 1993 BMW 325is | 92/192 DSP
11-05-2006, 11:33 PM |
11-05-2006, 11:43 PM |
11-06-2006, 1:32 AM |
Chris Hammond
Joined on 12-26-2000
St. Louis, MO
Posts 4,444
Points 27,525
mattm:Last time I checked, it was still in D Stock. At least they were in the end of September. You know something I don't?
I most likely just know nothing at all :) I thought there was rumors of moving them all to BS a earlier this year or last year? Chock it up to too much going on in my life, haven't followed the rule book enough lately. Perhaps after 12/2, more like 12/10, I'll have more time to stay up to date on things.
I am Chris Hammond. 2004 Z06 SS
11-06-2006, 9:23 AM |
bren
Posts 66
Points 595
Christoc: mattm:Last time I checked, it was still in D Stock. At least they were in the end of September. You know something I don't?
You are thinking of the (D)SP BMW's.
11-06-2006, 12:16 PM |
11-06-2006, 2:30 PM |
11-08-2006, 11:47 AM |
11-13-2006, 5:14 PM |
11-13-2006, 5:18 PM |
11-13-2006, 7:48 PM |
bren
Posts 66
Points 595
murph1379:Regarding the option of 18's in 2002, this is my understanding as well, does this mean the 18's are illegal for the 2001's?
Yes.
11-14-2006, 4:58 PM |
murph1379
Minneapolis
Posts 117
Points 1,800
ok, I've been trying to figure out what size wheels are actually on my car, and what sizes were offered for my year. (ie, what is DS legal) According to this site: http://www.realoem.com/bmw/partgrp.do?model=AV53&mospid=47725&hg=36&fg=15 the wheels I have, from the sport package, are 17x7.5 in the front, and 17x8.5 in the rear. It also states there were 17x8's and 18x8/18x8.5 available, which I'm pretty sure isn't correct. Does anyone know where I can find more definitive info? If I can use 17x8's, do you think that'll be better for autocross than 17x7.5/17x8.5 staggered? It'd certainly be easier to rotate, which might decide it for me. (not a national competitor) Thanks again!
11-14-2006, 7:47 PM |
11-14-2006, 9:03 PM |
Page 1 of 5 (94 items)
