Timing and Scoring 6.11 Page 42 (Letter to the SEB sent)
Last post 10-15-2006, 4:49 PM by talon95. 91 replies.
10-03-2006, 11:44 AM |
compaddict
Joined on 03-18-2002
Auburn, CA USA
Posts 79
Points 470
Timing and Scoring 6.11 Page 42 We had an incident on Fridays first run group in CSP were Ian Baker had installed a pre-warmed set of tires on his car. It caught my eye only because the tires were pre-wrapped in insulating blankets (he drove the car onto grid on Dirt Stockers). I went over and touched the tires and they were pretty hot so I asked how he got them so hot. Ian told me that they were in a car with the heater running for two hours. I was going to protest but got talked out of it by the chief of impound with the reasoning that a thirty-seven cent letter is far less expensive than a hundred and sixty dollar protest in case it does not go my way. Ian didn’t place and was behind me in the standings. I would like the rulebook to state that you can’t do what Ian did by changing the wording from “similar means” to “other means”. What Ian did was definitely “pre-heating” his tires but was it “similar”? I think it was without a doubt in my mind but the way the rules are written it leaves some room for human error. Vince Russell CSP 92
92/192 CSP Miata
10-03-2006, 11:54 AM |
Dan Cernese
Joined on 08-30-2002
Pepperell, MA, USA
Posts 68
Points 350
Re: Timing and Scoring 6.11 Page 42 (Letter to the SEB sent)
If you design an insulating skirt that includes the exhaust would that be excluded by your rewording?
124 ST[S|X] - '89 Civic Si (red or white, depending) 24 HS - '89 Civic Si white 95 ASP - '95 RX-7 R2 (for fun days)
10-03-2006, 12:02 PM |
solo-x
Joined on 09-19-2003
Posts 898
Points 14,625
active tire warming using heating blankets is an advantage not everyone can have because of the costs associated with it. everyone has access to a warm hotel room, a warm car or a warm tow vehicle so i fail to see how this is a form of warming the tires that needs to, or can, be banned.
10-03-2006, 12:17 PM |
AutoJim
Joined on 06-23-2004
SE Michigan
Posts 355
Points 4,920
Dan Cernese:If you design an insulating skirt that includes the exhaust would that be excluded by your rewording?
In years past, folks with the full skirts were told that they may NOT run their cars while the car was skirted. The Eguina/Berry ESP Camaro had the skirt but they kept the engine off whenever it was around the car, for example. As far as the pre-heating of tires, if I was on the PC and someone protested another driver for keeping the tires in a hotter-than-ambient environment until just before running, I would consider that to be "similar means" to individual tire heaters. But that's just my personal opinion, not anything that could be remotely considered official.
AutoJim ESP #65 '99 Mustang Cobra
AutoJim
SE Michigan
Posts 355
Points 4,920
Duplicate post deleted except that I can't delete it... so it's just being edited.
10-03-2006, 12:22 PM |
ChrisFranson
Joined on 07-07-2005
Posts 76
Points 970
Zauskycop:I saw a mini in grid with insulating sponges wrapped around the car at the base of the skirts to the ground, and then tire blankets put on. And running. Any heat from underneath the car was trapped and it looked pretty effective to me...
IIRC that wrapped cars, with engines running, have been protested in the past as having active tire warming. Those protests were upheld. We ran 4th heat in DSP, and wrapped the car each day but I was fanatical about being sure the engine was off before doing so. I'm sure my co-driver is now very glad I was so paranoid. I personally would have strongly considered filing a protest against a car wrapped with the engine running. As for Ian Baker's arrangement, it'd be pretty close to impossible to enforce a rule preventing that. What happens if someone was storing his or her car in one of the rented garages, which was warmer than a car that sat outside overnight? How do we distinguish between the two conditions? Edit: the phrase "other means" is far too vague. It is my interpretation that my above listed example would fall under the term "other means." There's no way to ensure that every competitor's tires are the same temperature. Taking it even further (and this is way out there), I'd say that using the term "other means" would also conflict with the allowance to have a co-driver.
10-03-2006, 12:28 PM |
Davebs14
Joined on 10-10-2001
Houston, Texas USA
Posts 1,827
Points 21,530
It was my understanding from past events that a runnign vehicle with a wrap around the tires constitutes active warming. However, if there's no wrap around it and just warmers over the tires and the car's running, that's ok. Just like tires in a car with the heater on is ok. My 2 cents. I always make sure my friends have their cars off if they have a wrap anyway. But I can fit my 4 tires in my miata with the heater on and top up if I want. Why not? I could leave it running a whole heat if I wanted :) Might be a heatsoaked motor, but hey :) lol David Hedderick Zauskycop:I saw a mini in grid with insulating sponges wrapped around the car at the base of the skirts to the ground, and then tire blankets put on. And running. Any heat from underneath the car was trapped and it looked pretty effective to me...
10-03-2006, 1:11 PM |
compaddict
Auburn, CA USA
Posts 79
Points 470
The words "active heating" or "active warming" would be a good idea as well. The problem as I see it is that the wording "similar" could mean different thing to different people. "Other" (in context) is quite a bit more clear. The other problem is keeping the rule book as short and simple as possible. Vince Russell 92 CSP
92/192 CSP Miata
10-03-2006, 1:19 PM |
harts
Joined on 11-05-2004
indiana
Posts 365
Points 3,850
Hey ! i cut up a perfectly good mattress to make those sponges, and then slept with my tires all night, alltho i didn't run the car while it was wrapped, on friday some friends droped by and put the rears on just before i went out, i would guess that they were probably 60 degrees or so when i left grid , but by the time i got to the start probably not much heat left in them at all,, the car sure didn't handle like their was.. i should of just swaped tires with one of the two driver cars as soon as they got back to grid,, wonder if that would be legal, running at 8:00 am in september on asphalt is a lot different than on concrete, the asphalt gets so much hotter in the sunlight than the crete, so when those cool nights come it sucks a lot more moisture out of the air, then you end up running on a damp surface, and if it is overcast it takes for ever to dry out, running first heat at HPT makes a two driver or allwheel drive car much more of an advantage than at forbes
10-03-2006, 2:20 PM |
Mike Shields
Joined on 08-25-2002
Temple, NH
Posts 287
Points 4,195
ChrisFranson: Zauskycop:I saw a mini in grid with insulating sponges wrapped around the car at the base of the skirts to the ground, and then tire blankets put on. And running. Any heat from underneath the car was trapped and it looked pretty effective to me...
IIRC that wrapped cars, with engines running, have been protested in the past as having active tire warming. Those protests were upheld. We ran 4th heat in DSP, and wrapped the car each day but I was fanatical about being sure the engine was off before doing so. I'm sure my co-driver is now very glad I was so paranoid. We were fanatical about it and I wouldn't have run the car with the wrap around. However, we did ponder a quirk... what's fully wrapped? would a 1" gap somewhere mean the car's not fully wrapped? I personally would have strongly considered filing a protest against a car wrapped with the engine running. As for Ian Baker's arrangement, it'd be pretty close to impossible to enforce a rule preventing that. What happens if someone was storing his or her car in one of the rented garages, which was warmer than a car that sat outside overnight? How do we distinguish between the two conditions? Edit: the phrase "other means" is far too vague. It is my interpretation that my above listed example would fall under the term "other means." There's no way to ensure that every competitor's tires are the same temperature. Taking it even further (and this is way out there), I'd say that using the term "other means" would also conflict with the allowance to have a co-driver.
Were you on the PC at some time recently? It seems like you've been thinking about these sorts of things lately :) I didn't know the mini was running all the time. I too would have protested it since I know that rulings in the past have been against fully wrapped and running cars. That is if the Mini driver hadn't shut off the engine after I had talked to them about active warming with the skirts. Not everone knows past precedent on this stuff. Also as I wrote this I realized that it might fall under the quirk I mentioned above about fully wrapping the car. Was there a gap somewhere? Did it matter or not? As for Ian's solution, I thought it was brilliant. He was thinking ahead and thought of the variables for what he could do within the rules. Others I know took tires to their hotel room overnight, or stored them in their cars/trucks prior to running. All of that isn't illegal. The active tire warming rule is to prevent on-the-car warming with active heat sources (and the requisite generators to run them). -Mike
Mike Shields 1993 BMW 325is | 92/192 DSP
10-03-2006, 2:49 PM |
ScottH560
Joined on 07-22-2004
DATS City
Posts 388
Points 5,715
Mike Shields: ChrisFranson: Zauskycop:I saw a mini in grid with insulating sponges wrapped around the car at the base of the skirts to the ground, and then tire blankets put on. And running. Any heat from underneath the car was trapped and it looked pretty effective to me...
Mike, you got to it before I did. I agree that Ian's idea was brilliant because that it was a way to get around "the rules." However, active tire warming is a subject that will have negative comments made about it until the disallow blankets, covers, wraps etc.... I don't think cost is so much a factor in tire warming as someone put it in an earlier post. What is the difference in the car running with tire blankets vs running with a wrap. The heat difference is almost negligible. If there is a difference, I would like someone to post statistics about it disproving the theory that wraps hold heat better than blankets. BTW Mike, CONGRATS on you 1st place finish. Your runs on day two were nothing short of phenominal! -d. scott bourne
D. Scott Bourne Cincy Region SCCA 192HS 409West SpeedSports DATS Racing LLC Kumho Motorsports Towery's Motorsports Tokico USA
10-03-2006, 2:53 PM |
ChrisFranson
Posts 76
Points 970
Mike Shields:Were you on the PC at some time recently? It seems like you've been thinking about these sorts of things lately :)
Wow, is it that obvious? :-)
10-03-2006, 3:18 PM |
fhrcng
Joined on 05-08-2003
Columbus, Ohio, USA
Posts 32
Points 280
I too thought that Ians idea was pretty ingenious and a way thinking outside of the box. I saw him working on his "blankets" on Wednesday evening and even helped him with part of the design. I did not see this as an active tire warming issue.
While I did not go to this much trouble in making a heat retention blanket, ( I used the traditional covers) I too stored my tires in the hotel room on Thursday evening and kept them in the warmth of my tow vehicle until about 15-20 minutes before we ran. I did not see this as a mechanical way of actually warming the tires. Yes, they were warmer than had they been on the car sitting in 45-48*F temps. Were they warm enough to have any positive affect on the conditions under which they were being run? I think not as by the time we made it from grid to the course the effects were absolutely negligible and the car was undriveable on the 1st set of runs given the ambient temp, the temp of the surface and the cold temp of the tires. Vince, if you had a problem with a competitor you should have talked to him about it and if you thought it was a rules infraction then protested whether or not he was ahead of or behind you. Rules are rules whether or not they affect you directly or not. FWIW:I saw cars later in the day who had total vehicle wraps which I remember as being illegal. Maybe because those cars were not running while wrapped was this not an issue. The idea behind the active tire warmer rule was that it was a cost and availability issue for all competitors and the fact that the SCCA did not want generators that power the warmers operating in grid during competition. Maybe the only solution to this is to ban all tire warmers, blankets, covers etc and move the Solo Nationals back 2 weeks to its original date so that we can all experience warmer conditions. Mike csp34 ( csp84 for Nationals )
Mike Feher csp34
10-03-2006, 4:13 PM |
Posts 642
Points 8,110
The tire warming rules are pretty much limited to what you can do on the grid. No active warming and that includes running the car with it wrapped. The engine actively generates heat so that is illegal. But what you can do before coming to grid is up for grabs. It would be very difficult to regulate what someone did with their car or tires before coming to grid. The one thing I see that might be a good idea is to include "tires" along with the car as to when it must report to grid. That would prevent someone from using active heaters in their rented garage and running them over to be fitted just before a run when the car was still sitting on grid to comply with the sups.
Steve Hoelscher #27 DP - Toyota MR2 http://www.terriehoward.com
10-03-2006, 4:33 PM |
compaddict
Auburn, CA USA
Posts 79
Points 470
I've heard the "no control over what happens before the car comes to grid" argument from a few people including Ian (I think it was Ian) but I can't find that in the rulebook. What's to say that I can't put my tires/rims in a warming box and get them up to 160 degrees before gridding? Would that fall under "ingenious" or "cheating"? About my rulebook comment. I'm not saying it's not there, I just can't find it. Vince
92/192 CSP Miata
10-03-2006, 4:59 PM |
harts
indiana
Posts 365
Points 3,850
Steve Hoelscher: The tire warming rules are pretty much limited to what you can do on the grid. No active warming and that includes running the car with it wrapped. The engine actively generates heat so that is illegal. But what you can do before coming to grid is up for grabs. It would be very difficult to regulate what someone did with their car or tires before coming to grid. The one thing I see that might be a good idea is to include "tires" along with the car as to when it must report to grid. That would prevent someone from using active heaters in their rented garage and running them over to be fitted just before a run when the car was still sitting on grid to comply with the sups.
you had better make that tires on the car, not in the car , which is how i brought my two back ones with me to grid
10-03-2006, 5:04 PM |
Surferjer
Joined on 09-17-2004
East Coast
Posts 755
Points 7,960
Wow, good conversation. I wondered what the point was of wrapping the whole car with the engine NOT running, as several of my competitors did this. I know it's totally legal, just wondered the benefit. I guess the engine would give off heat after it's shut off, but that seems pretty negligible. I used tire blankets, car shut off. But I did pull the right front and placed it in the sun before running. That would seem to be inactive warming, I think. Now, I previously would have considered placing tires in a running car prior to running "actively" warming. Placing tires in a non-running car would be inactive. But arguments about garages, hotel rooms and policing these actions has me wondering.... Maybe I need to create and patent a foldable tire warmer, complete with cigarette adapter for juice. I could sell a million in Topeka LOL. This whole subject is pretty sticky, pardon the pun.
Jer 1993 MR2 #196 ES 2005 Lotus Elise (retired) 1999 Dodge 4X4 tow vehicle 1993 Miata (just tired) 1987 Corolla Lemons car 1984 Citation Lemons car
