Last Post 14 May 2019 11:27 AM by  coneracer
1988 Honda CRX SI STS prep $8000
coneracer
    1988 Honda CRX SI, I just built this car this winter so just about everything on it is new. Hate to look at what I have invested, but I'm sure it is north of 10 grand.
    Engine
    1991 CRX SI block full deck height, no milling, no numbers (this is common with the 91's Honda was using up replacement blocks)
    Honed stock bore with new Honda factory rings and bearings all stock replacement original sizes.
    New Factory head gasket
    1988 CRX SI cylinder head completely rebuilt, not milled, full factory height
    New distributor, cap, rotor, wires, plugs, factory cam and crank seals, Honda oil pump
    chipped and socketed ecu with launch and 7700 rev limit
    I have roughly $2600 in the engine alone.
    Suspension
    All new urethane bushings, control arms, outer tie rods, new steering rack, trailing arm bushings(Honda)
    Moton Motorsports double adjustable remote reservoir shocks
    Ground Control rear and Hypercoil front springs All new
    ASR 32 mm rear bar
    New brake pads, shoes, hardware, calipers, wheel cylinders.
    Transmission was rebuilt by previous owner and shifts fine
    New clutch kit factory
    Cold air intake with two configurations
    New radiator
    1320 header
    Custom exhaust ( short ) with titanium Micron Muffler and high flow cat weight is around 10lbs complete from header back
    Lithium Ion battery 2.2 lbs
    Sparco seat and suede steering wheel
    949 racing 15x7.5 wheels version 4 at 10.8 lbs
    205-50-15 Bridgestones with around 60 runs still 5/32
    Body was wet sanded and rust on rear quarters was fixed and then the car was wrapped
    I've built 3 cars that have run in this class and 2 have won nat's, this is really a no excuses car built to the rules and 1000% legal in every way
    $8000 price is firm
    Custom 83"x12 ft trailer with tilt bed and brakes, can be had with the car for $1000 extra, I just payed $1600
    Contact Ron Williams at 785 633 9399 for questions
