Last Post 13 Mar 2019 09:35 PM by  DrStang
1999 10ae Miata Solo CSP For Sale
DrStang
04 Oct 2017 08:44 PM
    1999 Mazda Miata (10th Anniversary Edition) setup for SCCA Solo CSP.
    Pics:  https://imgur.com/a/M5Niq
    Engine:
    ---2004 VVT motor, 12k mile motor with only Autocross miles
    ---Hydra Nemesis 2.7 ECU, wideband O2, wiring harness and E85 map from Jeremy at Flyin' Miata.
    ---1999 intake manifold modified by George Doganis (multi-time CSP National Champion). Modified and extrude honed.
    ---Skunk2 64mm throttle body port matched to intake
    ---RX8 Yellow 420cc injectors cleaned & flow tested, DW200 fuel pump
    ---Maxim Works Header (unmodified)
    ---Hushpower muffler with turndown.
    ---Custom fiberglass cold air intake.
    ---Miata Roadster Delrin puck motor mounts.
    Drivetrain
    ---1990 5-speed transmission with Redline fluids.
    ---Quartermaster clutch.
    ---Stainless steel clutch line.
    ---OS Giken LSD with OS Giken fluids & 4.30 Ring and Pinion.
    ---Mazdaspeed differential mounts.
    Suspension
    ---Penske Double-Adjustable Shocks custom built/valved for the car by Guy Ankeny of Ankeny Racing Enterprises.
    ---Hypercoil 2.25" springs 800/450lb.
    ---Hypercoil rear zero-rate helper springs/spring perch.
    ---Custom delrin bushings in all control arms.
    ---Offset delrin bushing in front upper control arms.
    ---Adjustable rear upper control arms.
    ---Upper pillow ball mounts on front and rear shocks
    ---Power steering installed, manual steering rack available
    Brakes
    ---Miata 1.6L brakes.
    ---Custom cross drilled for reduced weight (6lb savings).
    ---OEM pads Front / Hawk Pads Rear.
    ---Stainless steel brake lines.
    Wheels/Tires
    ---Bogart 15x10's with Hoosier 275/35/15 A7s, 2 corded.
    ---949 6ul 15x10's with Hoosier 275/35/15 A7s, 2 corded. SOLD
    ---949 6ul 15x9's with Hoosier 225 wets, barely used and bagged for freshness.
    Other
    ---Early 1.6L non-electric mirrors.
    ---Early 1.6L dash and center console (removes passenger air bag).
    ---Recently installed Momo suede steering wheel
    ---Corbeau Forza driver's seat on Corbeau slider.
    ---Older Corbeau Forza passenger side.
    ---Softop delete.
    ---Hard Top in matching Twilight Blue Mica.
    ---Custom Street Prepared removeable front splitter.
    ---Custom rear spoiler.
    ---Fender flares.
    Asking: $15,900
    New Asking Price! $14,900
    2019 Spring Special!  $14,500
    Located in Tulsa, OK
    DrStang
    05 Oct 2017 08:36 PM
    History: This is Darby's (darbyfam) CSP car that he sold to Bryan (NoCones) who painted it, upgraded the driver side Forza and added both sets of 6ul's to the mix. Since the purchase from Bryan power has been increased, power steering added back and the front splitter rebuilt.
    After the positive battery terminal came loose on the test & tune course in Lincoln, the Nemesis went in to Hydra for a brand new board and a new O2 sensor was installed. Shortly after that, the injectors, fuel pump & throttle body were upgraded, and worked with Jeremy @ Flyin Miata to make the switch to E85.
    CliffordBRD
    06 Nov 2017 06:49 PM
    Is the Miata still for sale?
    DrStang
    07 Nov 2017 09:58 AM
    Car is still available and sent ya a message.
    DrStang
    04 Mar 2018 12:24 PM
    The 2018 season is kicking off and I know someone needs to join the CSP ranks!
    DrStang
    21 Aug 2018 04:21 PM
    Asking price $1k off and only 1 set of wheels gone!
    DrStang
    Spring special of $400 off and it's got 4 gallons of fresh E85 in it! Someone needs to join the CSP ranks and this is the ticket!
