Last post 09-22-2008, 4:53 PM by solo-x. 171 replies.
Page 7 of 9 (172 items)   « First ... < Previous 5 6 7 8 9 Next >
  •  05-30-2008, 2:20 PM 303077 in reply to 303031
    AceInHole:
    Pfft.  Neither of you can match my fuel/oil/tire combo.
    haha. You're not wrong! The fasteners that come off are entertaining as well.
    Nate Whipple
    NER
    188/88 DSP ITR
  •  06-02-2008, 10:01 PM 303563 in reply to 303077
    Finally got the leak down test done. The good news? 1 and 4 have only 1-2% leakdown. The bad news? 2 and 3 have from 10 to 12.5% leak down. Sad That can't be good. Trying some different oil to see if that will resolve the oil burn off issue so I'll have money to freshen it up with when I finally get some time to do it.
    Nate Whipple
    NER
    188/88 DSP ITR
  •  06-03-2008, 1:24 AM 303598 in reply to 303563
    Hey Nate, I discovered a secret weapon this weekend. Look out...
    Mike Shields
    1993 BMW 325is | 92/192 DSP
  •  06-03-2008, 3:18 PM 303701 in reply to 303598
    Mike Shields:
    Spy vs. Spy? A secret weapon is it?  No secret weapons here. Though if Chang doesn't mind getting oil on his hands I might be able to find 5-8hp Friday night and get rid of this weird rpm dependent ticking...
    Nate Whipple
    NER
    188/88 DSP ITR
  •  06-04-2008, 2:21 AM 303792 in reply to 303701
    Mike,
    Sorry to say I will now not be able to make it to Devens to give you guys a run!! I had a secret weapon too...........Its called an e30....LOL
    Had to cancel today due to work,Sad
    Nate, dont blow your car up before DC..
    See you in DC.
  •  06-04-2008, 11:32 AM 303835 in reply to 303792
    Sorry to hear that Tom. I don't think it'll blow up just yet, so we'll see you in DC.
    Nate Whipple
    NER
    188/88 DSP ITR
  •  06-05-2008, 2:12 AM 303979 in reply to 303835
    Bummer Tom. See ya in DC!
    -Mike
    Mike Shields
  •  06-05-2008, 1:23 PM 304059 in reply to 303563
    solo-x:
    Even 10 - 12.5% leak isnt that bad.  Optimal, obviously not, but not likely causing much of a drop in power.  That said, it could be contributing to your oil consumption for sure.  As someone mentioned earlier, are you running anything other than the OE crankcase ventilation system?  Putting a catch can on the car could tell you alot about whether the oil is getting by the valveseals or not.  The fact that you are getting bad smoke under engine braking does lead me to believe that it is blow-by though, and leaking valves would exacerbate that condition.  You may just need new valves and seats and then would be fine.  One other thing I have found on most Hondas is the breather ports on the valve cover are usually too small, creating high velocity at the port and dragging oil into the PCV and breather lines.  I have a friend of mine that welded 4 -12 AN fittings on his valve cover and routed them all to a big catch can. This enabled him to vastly reduce crankcase pressure without consuming much(if any) oil.
    -- Drew
    AS S2000
  •  06-07-2008, 10:29 PM 304408 in reply to 304059
    You're keeping up pretty well for an ailing hardly developed car there in Devens...
    1991 Saturn SC-226k miles- HS #106
    1990 Miata- Blue, with black spots- daily
  •  06-09-2008, 9:05 AM 304486 in reply to 304408
    MTBGAEL:
    Meh, obviously I'd like to be a bit closer to Alex and Mike then I was. Alex was absolutely on fire this weekend while Mike and Chris continue to futz with the car. We were hoping to only be .5 off on both days, but fell short of that goal. Some of it was car, some of it was driver. The good news is that the different oil has reduced how quickly we burn through it, only going through 1/4qrt for the entire weekend, including driving to and from the event site.
    Nate Whipple
    NER
    188/88 DSP ITR
  •  06-09-2008, 5:00 PM 304624 in reply to 304486
    solo-x:
    is your car legal in SP with the SM oil?
  •  06-11-2008, 12:19 PM 304978 in reply to 304624
    Rodney:
    solo-x:
    Yes. One question though, does the SM oil cause clutches to @sspl0d3? Stick out tongue
    Nate Whipple
    NER
    188/88 DSP ITR
  •  06-11-2008, 9:54 PM 305093 in reply to 304978
    solo-x:
    no, that would be the SM tranny fluid....
  •  06-23-2008, 5:15 PM 306621 in reply to 305093
    Awesome driving by Mike this weekend. Great job. Hopefully I start to figure out how to drive this thing soon.Snail
    Nate Whipple
    NER
    188/88 DSP ITR
  •  07-01-2008, 9:35 PM 308211 in reply to 306621
    Welp, got it dyno'd today. Anybody want to make a guess before I publish the numbers? As a little hint, best power was made with full ignition advance on 93 octane fuel. That's how much the oil was affecting things. Turns out, oil has a really slow burn rate and a really low octane rating! I wouldn't suggest it as a good way to avoid knock though! Dynojet dyno btw....
    Nate Whipple
    NER
    188/88 DSP ITR
  •  07-01-2008, 10:22 PM 308217 in reply to 308211
    170HP, 130TQ
    Mike Shields
  •  07-01-2008, 10:24 PM 308218 in reply to 308211
    Is this horse or hampster power?
    My guess is 162.4 hp
  •  07-01-2008, 10:26 PM 308219 in reply to 308211
    solo-x:
    42.
    You decide whether that's HP or TQ or both.
  •  07-01-2008, 11:02 PM 308226 in reply to 308217
    Mike Shields:
    170HP, 130TQ
    lol. 130tq? I wish!
    PJ was the closest. Best pull was 165hp/117tq. Worst pull was 163/116. With timing set to 18* BTDC, it dropped to 159/112. The residents of Fall River can thank me for the misquito massacre. I honestly think the smoking is getting worse after every autocross. Haven't decided exactly what I want to do with the engine. Something is going to get done, just haven't decided what yet.
    Nate Whipple
    NER
    188/88 DSP ITR
  •  07-02-2008, 7:30 AM 308253 in reply to 308226
    solo-x:
    lol. 130tq? I wish!
    Wow Nate.  That sucks.  My Celica for my stock pull prior to STS mods put down 163/119.  Being down 30 whp and 15-20 lb/ft of torque explains a lot.  Hopefully the rebuild isn't too bad.  - AB
    '06 Chrysler Crossfire - #87 DS
    '04 RX-8 #87 BS (retired)
    '01 Celica GTS #193 STS (retired in '05)
