Last post 09-22-2008, 4:53 PM by solo-x. 171 replies.
05-30-2008, 2:20 PM |
solo-x
Joined on 09-19-2003
Posts 845
Points 13,730
AceInHole:Pfft. Neither of you can match my fuel/oil/tire combo.
haha. You're not wrong! The fasteners that come off are entertaining as well.
06-02-2008, 10:01 PM |
solo-x
Posts 845
Points 13,730
Finally got the leak down test done. The good news? 1 and 4 have only 1-2% leakdown. The bad news? 2 and 3 have from 10 to 12.5% leak down.  That can't be good. Trying some different oil to see if that will resolve the oil burn off issue so I'll have money to freshen it up with when I finally get some time to do it.
06-03-2008, 3:18 PM |
solo-x
Posts 845
Points 13,730
Mike Shields:Hey Nate, I discovered a secret weapon this weekend. Look out...
Spy vs. Spy? A secret weapon is it? No secret weapons here. Though if Chang doesn't mind getting oil on his hands I might be able to find 5-8hp Friday night and get rid of this weird rpm dependent ticking...
06-04-2008, 2:21 AM |
Tom Bleh
Joined on 06-07-2001
Va Beach, Va.
Posts 23
Points 175
Mike,
Sorry to say I will now not be able to make it to Devens to give you guys a run!! I had a secret weapon too...........Its called an e30....LOL
Had to cancel today due to work,
Nate, dont blow your car up before DC..
See you in DC.
06-04-2008, 11:32 AM |
solo-x
Posts 845
Points 13,730
Sorry to hear that Tom. I don't think it'll blow up just yet, so we'll see you in DC.
06-05-2008, 2:12 AM |
Mike Shields
Joined on 08-25-2002
Temple, NH
Posts 282
Points 4,025
Bummer Tom. See ya in DC!
-Mike
Mike Shields 1993 BMW 325is | 92/192 DSP
06-05-2008, 1:23 PM |
alvanderp
Joined on 11-01-2004
Austin, TX
Posts 642
Points 8,575
solo-x:Finally got the leak down test done. The good news? 1 and 4 have only 1-2% leakdown. The bad news? 2 and 3 have from 10 to 12.5% leak down.  That can't be good. Trying some different oil to see if that will resolve the oil burn off issue so I'll have money to freshen it up with when I finally get some time to do it.
Even 10 - 12.5% leak isnt that bad. Optimal, obviously not, but not likely causing much of a drop in power. That said, it could be contributing to your oil consumption for sure. As someone mentioned earlier, are you running anything other than the OE crankcase ventilation system? Putting a catch can on the car could tell you alot about whether the oil is getting by the valveseals or not. The fact that you are getting bad smoke under engine braking does lead me to believe that it is blow-by though, and leaking valves would exacerbate that condition. You may just need new valves and seats and then would be fine. One other thing I have found on most Hondas is the breather ports on the valve cover are usually too small, creating high velocity at the port and dragging oil into the PCV and breather lines. I have a friend of mine that welded 4 -12 AN fittings on his valve cover and routed them all to a big catch can. This enabled him to vastly reduce crankcase pressure without consuming much(if any) oil.
-- Drew AS S2000
06-09-2008, 9:05 AM |
solo-x
Posts 845
Points 13,730
MTBGAEL:You're keeping up pretty well for an ailing hardly developed car there in Devens...
Meh, obviously I'd like to be a bit closer to Alex and Mike then I was. Alex was absolutely on fire this weekend while Mike and Chris continue to futz with the car. We were hoping to only be .5 off on both days, but fell short of that goal. Some of it was car, some of it was driver. The good news is that the different oil has reduced how quickly we burn through it, only going through 1/4qrt for the entire weekend, including driving to and from the event site.
06-09-2008, 5:00 PM |
Rodney
Joined on 01-16-2003
new friggin york
Posts 318
Points 4,390
solo-x:The good news is that the different oil has reduced how quickly we burn through it, only going through 1/4qrt for the entire weekend, including driving to and from the event site.
is your car legal in SP with the SM oil?
06-11-2008, 12:19 PM |
solo-x
Posts 845
Points 13,730
Rodney: solo-x:The good news is that the different oil has reduced how quickly we burn through it, only going through 1/4qrt for the entire weekend, including driving to and from the event site.
Yes. One question though, does the SM oil cause clutches to @sspl0d3?
06-11-2008, 9:54 PM |
Rodney
new friggin york
Posts 318
Points 4,390
solo-x: Yes. One question though, does the SM oil cause clutches to @sspl0d3?
no, that would be the SM tranny fluid....
06-23-2008, 5:15 PM |
solo-x
Posts 845
Points 13,730
Awesome driving by Mike this weekend. Great job. Hopefully I start to figure out how to drive this thing soon.
07-01-2008, 9:35 PM |
solo-x
Posts 845
Points 13,730
Welp, got it dyno'd today. Anybody want to make a guess before I publish the numbers? As a little hint, best power was made with full ignition advance on 93 octane fuel. That's how much the oil was affecting things. Turns out, oil has a really slow burn rate and a really low octane rating! I wouldn't suggest it as a good way to avoid knock though! Dynojet dyno btw....
07-01-2008, 10:26 PM |
ChrisFranson
Joined on 07-07-2005
Posts 72
Points 890
solo-x:Welp, got it dyno'd today. Anybody want to make a guess before I publish the numbers?
42. You decide whether that's HP or TQ or both.
07-01-2008, 11:02 PM |
solo-x
Posts 845
Points 13,730
Mike Shields:170HP, 130TQ
lol. 130tq? I wish!
PJ was the closest. Best pull was 165hp/117tq. Worst pull was 163/116. With timing set to 18* BTDC, it dropped to 159/112. The residents of Fall River can thank me for the misquito massacre. I honestly think the smoking is getting worse after every autocross. Haven't decided exactly what I want to do with the engine. Something is going to get done, just haven't decided what yet.
07-02-2008, 7:30 AM |
B1mmer
Joined on 12-27-2000
Charlotte, NC
Posts 868
Points 12,320
solo-x:
lol. 130tq? I wish!
Wow Nate. That sucks. My Celica for my stock pull prior to STS mods put down 163/119. Being down 30 whp and 15-20 lb/ft of torque explains a lot. Hopefully the rebuild isn't too bad. - AB
'06 Chrysler Crossfire - #87 DS '04 RX-8 #87 BS (retired) '01 Celica GTS #193 STS (retired in '05)
Page 7 of 9 (172 items)
... 7
