Separate ST Classes for 2 seaters... Why?
Last post 05-20-2008, 11:13 PM by skeeter119. 194 replies.
Page 6 of 10 (195 items)   « First ... < Previous 4 5 6 7 8 Next > ... Last »
  •  05-21-2007, 10:24 PM 245634 in reply to 245289
    Re: Separate ST Classes for 2 seaters... Why?
    Catch 22:
    PS - OK, lets forget about the s2000 (even though we shouldn't) because its an evil A Stock car.  Lets talk about why the B Stock 2 seaters aren't allowed in STU...  Lets discuss the 350z and BMW M Coupe (99-00).  B Stock cars that aren't in STU with all the other B Stock cars simply because they have 2 seats.  Someone please help me with my obviously flawed logic here and explain this.
    Thanks in Advance.
    So what would you think about Miata w/Torsen, S2K and 350Z/G35 coupe in STU with the AWD 245 tire limit? imho I think those cars could go in there with that tire limit and not upset the class yet still be able to play. Yes
    Jason Isley
    2005-2006-2007 B Stock National Champion
  •  05-21-2007, 10:27 PM 245636 in reply to 245631
    What happens if the 350z dominates STU???  Same thing that happened when the Z06 took over SS or the Mini owned GS or the Civic dominated STS...  Everyone gets a 350z.
    What is your damned point?
    You can't get paralysis because you are afraid of such things and you can't apply "but we're scared of overdogs" rules to STU that you aren't applying to SS, STS, GS or ASP or whatever.  Just stop it.
    If I stopped to think about everything that could kill me out there I'd board up the windows and never leave the house.  If the SCCA tries to never ever ever ever potentially create an overdog then I guess we're finished classing new cars.
    All I'm asking is why the 350z isn't in STU with all the other B Stock cars and you are asking for it to somehow prove it won't be a class killer.  First off, nobody can positively do that with ANY car unless you potentially misclass everything.  Second, you didn't have the same requirements of the other STU cars when THEY were classed.   Why?  Because they have 4 seats.  THAT ISN'T VALID CLASSING METHODOLOGY!!!  Thats using a class philosphy created when ST was nothing but STS.  And STU cars are in a wayyyyyyyyyy different category than STS cars.  Talk about round fruit.
    You are driving me NUTS.
    I'm really going to try to give up now.  Its giving me a headache.
    '91 ITB Civic DX
  •  05-21-2007, 10:38 PM 245641 in reply to 245634
    RX7 KLR:
    Miata with torsen ought to be in STX with the 2nd gen MR2.
    I can see the Mazdaspeed Miata (because its a turbo), S2000, and MR2 Turbo in STU with a tire restriction.  I really see no reason for the B stock normally aspirated 2 seaters to have a tire restriction.
    Again, and I can't stress this enough... Its illogical to assume that (for example) a BMW M Coupe needs a tire restriction to level it with an M3 in STU when it needs no such restriction in either Stock or Street Prepared.  What you are saying at that point, literally, is that 2 seat cars are inherently faster on street tires than 4 seat cars.  THATS what doesn't make sense and nobody has yet to justify.
    '91 ITB Civic DX
  •  05-21-2007, 10:41 PM 245643 in reply to 245636
    Catch 22:
    I think the 350Z with the current STU rules could be an over-dog. In BS the 350z was a close 2nd to the RX-8 at natls last year, .1, and it has some serious issue in stock trim. The 350Z in BS has very little front camber, crappy limited slip and is a porker (the fast guys run a full fuel tank to make up for the crappy LSD). These are all issue the RX-8 does not have in stock trim so you don't have to fix them in STU.  In STU trim you can fix the 350Z camber issue, replace the LSD and loose a lot of fuel weight. So with equal size tires, lots of power and all of the stock weaknesses fixed I think it could crush the class. That is why I would propose giving the "sports cars" the AWD 245 tire limit.
    As far as the S2K you are 200 lbs lighter than the RX-8 with more power and have LSD issues in stock, fix that in STU and give it a 275 and the class is Spec S2K. However again I think a skinny 245 could keep it in check.
    Jason Isley
  •  05-21-2007, 10:45 PM 245645 in reply to 245641
    Catch 22:
    Well I am not the only one that makes no sense....Wink The Mazdaspeed Miata is slower than the 99' sport in CS. There is no boost allowance in ST so why put the faster one in STX and the slower one in STU?
    Not every 2 seater is faster but you need to keep in mind some cars have problems in stock trim that slow them down and allow them to be classed with cars that have much less power, RX8 VS 350Z, but those problems will go away with ST/SP allowances.
    Jason Isley
  •  05-21-2007, 11:09 PM 245651 in reply to 245624
    • jzr is not online. Last active: 09/08/2008, 5:15 AM jzr
    • Top 75 Contributor
    • Joined on 10-20-2002
    • San Diego, CA
    • Posts 798
    • Points 11,610
    So after all that success with IT, why the move down to ST? Wink Just pokin' at cha...
    I don't really know much about IT, but is it not a collection of classes, each comprised of maybe 5-15 cars?  My point being, the number of cars, modifications, weights, etc., was relatively finite.  I liken this more to adding a new SP class, and performing some class reshuffling, where you have plenty of data to back the changes.
    The difference about ST, is that at present, it allows hundreds, if not thousands, of different car types to enter.  To make the paradigm change, that humongous collection of cars has to be distilled down by the poor overworked, volunteer AC and SEB members to the 5-15 per class the "club" wants to see competing.  A lot of feelings get hurt in this process "you mean I have to compete against a (car a) in my (car b)?!?!?!", or "whaddaya mean I can't run my (unpopular/unknown car) in STS anymore, I used to be able to?!?!?" etc.  Another problem making that process extra difficult, is we don't have a lot of good data on what makes an ideal ST car vs. an SP or Stock one.  We know how fast a Civic can go, Imprezas (2.5RS/WRX/Sti), M3s, Evos, 240s, and maybe a couple others, but that's about it.  All the others would have to be guessed at using piecemeal information.
    The risk, if this is not all done right/carefully, is "tipping the apple cart" so bad it makes all the current front-runners, back markers.  There are legions of Civic, WRX, and M3/StEvo drivers out there who will be very effective in contrary letter-writing to any proposal that threatens to unseat their positions.  Everybody wants to see a successful future to the category, but if it comes at the cost of sacrificing a significant cost and time investment for a large number of people, then support will no doubt be lessened.  That's why I say that any new paradigm needs to protect the investment of the current participants to have a chance of getting off the ground- ASt, BSt, Cst, etc. will have a much better chance if the current ST classes each fit neatly into one of the new performance-based classes.
    The present "seats and motor size" methodology which you say (in all caps) "isn't a valid methodology" is made valid by the fact that it's presently being used in ST, but also by SM, to class cars.  Its use, makes it valid - maybe not ideal, but valid.  In general, 2-seat cars are much more likely to be designed from the beginning for sport applications (smaller, lower, lighter, better suspensions), so when using very broad strokes for classification, it makes a good first swing.  When you start breaking things into 5+ classes as ST is presently it starts to show its shortcomings, but it wasn't such a bad tool to start a new category with.
    Movement to a performance-based classing methodology as per Stock and SP has the following challenges:
    • Distill virtually limitless number of cars down to 5-7 classes of 5-10 cars each, with very little solid data to go on
    • Maintain/preserve competitiveness/investment for members of presently highly subscribed classes, both initially and for a while after the change
    • Build in consistency of rules across the category to minimize confusion (tire sizes, why does CSt get cats and diffs but BSt doesn't?, etc.)
    • Justify creation of any new classes needed in the conversion
    I see that as being a lot of work, one that could easily take 5 years, hence my 20-teens comment.  Maybe it'll be sooner, who knows, but it's going to take a lot of effort to do it right.  Applied to the present question, you can't just stop at the 350Z - you have to consider not only the S2000 and MR2, but every other non-STS2 2-seater made, ever.  You know well how two very intelligent and educated people can disagree all day and night on how competitive a given car would be in a given class.  To get this done, hundreds of compromises will have to be made by dozens of people, many of them just as stubborn as you.  Maybe the 20-teens was being generous... Wink
    --Jason Rhoades
  •  05-21-2007, 11:16 PM 245654 in reply to 245643
    RX7 KLR:
     So what would people think if we push to have the 2 seater cars allowed into STU with the 245 tire limitation?  I think it would be a good idea to see the car's potential.  Then if the cars can't hack it on 245s maybe in the future push to have them allowed on 275s.  That seems like a good way to do it.  I don't have a dog in this fight but would really like to see a place for the 2 seaters to play in ST* other than STS2.
    Keith
    2005 Chrysler Crossfire-- DS
    1993 Subaru Legacy-- Rallycross car
  •  05-21-2007, 11:22 PM 245658 in reply to 245654
    skeeter119:
    I don't think STU needs to be screwed with, they are one of the biggest classes at most events. However I do see on a lot of forums a number of people asking for a place to run a sports based cars in ST. Giving them a tire restriction that already exist in the class could be a way to let them play without upsetting the current "balance" (aka AWD domination) Devil in the class. jmho
    Jason Isley
  •  05-21-2007, 11:34 PM 245661 in reply to 245658
    And Rotaries are notorious for making HUGE power gains when you make modifications to them, especially in the exhaust.  So maybe the RX8 is a potential STU overdog that needs narrow tires???  See my point?  I can pick SOMETHING on just about any car you can throw out there that might make it an overdog somewhere.
    But ignore what I just wrote.  I keep asking what 2 seats has to do with the price of buttermilk in Bhutan and you picked out some specific things about the 350z that has nothing to do with the 2 seats.  Fact is, if the 350z had a couple of little dinky rear seats in it it would very very likely ALREADY BE IN STU.
    What if Mazda rolled out a version of the RX8 that is EXACTLY THE SAME as the current car except it has no rear doors and a storage bin instead of rear seats???  Should it suddenly not be allowed in STU???!?!?!?!?!?!?!?!?!?!?!?!?!?!?!
    Please understand that this is the point.  Stop nitpicking this and that about particular cars.  Please.
    Jason... Time, Money and Commitment.  Its a whole lot less in STS2 than it is in ITC.  I miss racing, but I don't miss what it takes to race.
    '91 ITB Civic DX
  •  05-21-2007, 11:43 PM 245665 in reply to 245658
    RX7 KLR:
    As Catch 22 sticks his fingers in his ears and makes noises as other people speaks, I'll address this...
    I agree and I have said that STU does not need to be screwed with since the turnout, as it is, is fantastic and there are several makes competitive.   But, we all know that if the 2-seaters were to be given a place to play in STU with serious limitations--and said 2-seaters were far from competitive--people would yell about this also.  What's the point of doing this--for the locals?  As has been pointed out time and time again, locals are free to create any class they want.  I see no reason to handicap what could be an overdog into something that's not competitive.
    Seriously, it's a no-win to do this IMO.  That's why I am asking that folks be patient and write their letters in 2008.  For goodness sake--it's a freaking year to wait.  If enough people want a class for 2-seat based sports cars, then one might likely be considered.
    As for the other bold statement Catch22 made--if the 350Z is put into STU and seriously upsets the apple cart, people are going to be upset.  Catch needs to study SP classing a little closer to see how cars and shuffled around there and forget about stock class for a second, because how stock class behaves is a million miles away from what ST and SP do.  I've addressed that already but I guess my description was not good enough.
    Todd
    Too many ST cars
    "Restricted Area Racing"
  •  05-22-2007, 12:48 AM 245682 in reply to 245661
    Catch 22:
    I wish the RX-8 could make big power...... The most I have seen from a BSP or STU trim RX-8 is 200 rwhp. Yep that is big. lol I guess no one will tell you what you want to hear so there is no point in going on. Rollseyes
    Jason Isley
  •  05-22-2007, 3:29 AM 245691 in reply to 245598
    Catch 22:
    PS - There STILL hasn't been any valid reason given for the B Stock 350z and M Coupe to not be in STU.  I wish I'd never mentioned the S2000 because *some* folks can't let that go and actually answer the real question.  Which is, one last time, "Why do 2 seats and street tires mean cars need a separate class?"  It really is just that simple a question.  I swear it is.  It seems really simple and straightforward because it IS simple and straighforward.  At least until we succeed at complicating it.
    I'm currently one of the freaks driving an M3 in STU.  Let me tell you what would happen with my '00 S52 M coupe in STU, given the same tire limitations as the M3.
    The AWD guys wouldn't know what hit them.  It wouldn't be remotely close.  Would I love that?  No.  Competition and challenge is what this is about, not decimating the other drivers.
    I know that isn't your point in the comment, but it's relevant to the concepts in this thread.  If we could create a class where the field is reasonably close, I'd love to run the M coupe.  That car is *perfect* for the ST rule set!  Not too much power, not too much weight (relatively speaking), stock suspension that sucks...
    Mike
  •  05-22-2007, 9:56 AM 245720 in reply to 245613
    Keith Casey - IMHO...:
    why mix it up when the class (STU) is still in it's formative years?
    because that's the perfect time to do it before it becomes so ingrained and inbred it's impossible to make any changes.
    Again, look at the removal of UD/BD in STS. It happened, but because it was early in, not that many people were hurt, but some still were.
    The philosophy of STS was penned when there was only... STS. (4 door sedans). The category has grown, I would guess faster than many had anticipated. Do those in charge want to keep the status quo, or, do they have a bigger vision they'd like to share?
    --kC
    (possibly a dupe post, browser crashed... )
    The folks that were hurt in the ST UD/BD, how many quit or changed classes?   Zero, or ??  Is ST as a whole bigger today or not?  Would there be more people affected by this or less?
    I'm really asking, not just rhetoric there... I truly don't know those answers... it may change my view to hear them.
    When STS was formed, there were indeed 2 seat sports cars out there, it's not like they just popped up in the last 2 or 3 years.  Was the reason they were 'omitted' then b/c no one really thought they'd deign to run 'just' a street-tire class?  I may be way off, but most folks I know who buy those sweet little 2-seat sports cars kind of stick their noses up at sedans anyway.  That's no reason to exclude them, for sure... but I would laugh my butt off if this allowance was made and no one attended anyway.  No, not making a point there, just idle observation :)
    People keep hinting at " no one guarantees your car will remain competitive..."...  likewise no one guaranteed your car would have a place to run when purchased.  I didn't buy my first WRX to autox, didn't even know what autox was.  It was just lucky that it's worked out.  Thanks to Subaru for putting the freebie SCCA membership in the glove-box.
    All that said, I also agree with the notion that if 'properly' limited, the cars could be wedged in the class.  Define properly limited now.  I also understand the point about SCCA possibly having a grander scheme at work and we'd all love to see it if it exists.  It could quell this mini-revolt right now.
    #555 STU HouSCCA
    underprepped and proud of it! ( or just very, very cheap, your call :p )
  •  05-22-2007, 10:06 AM 245723 in reply to 245661
    Catch 22:
    Addressing only your bold comment there:  If Mazda made such a beast, would you think it'd have better or worse weight distribution, power/weight, stiffness and handling?  Killing two gaping holes in the body structure would surely make the car stiffer, eliminating their weight makes it lighter.. those two things alone are pretty big differences.  Surely there are more, I'm not that smart to think of them all though.
    RX8's have double-wishbones, right?  Most of the 'top' STU cars are strut. If I had to pick, I'd pick wishbones to have.  You're -only- focusing on seats b/c that was a convenient metric to separate sports-cars from sedans.  You're omitting the notion that most 2-seat sports cars actually are designed to handle better right out of the box, not to speak of how they'd do w/the allowances that the porky/pushy sedans in ST classes get just to make them handle a -little- better.
    #555 STU HouSCCA
  •  05-22-2007, 10:16 AM 245726 in reply to 245682
    RX7 KLR:
    Thanks for helping me make my point.  All I did was speculate that RX8s could make huge power gains in STU trim because Rotaries traditionally make huge power gains due to all the factory restrictions for noise and emissions. Based on known information, that is a valid speculation.  If nobody had ever built an STU RX8 I could effectively argue to try to keep it out of the class as a potential killer.
    All you did was speculate that a 350z could dominate STU because it could add camber and an LSD.
    See... We both speculated.  See what happened there?  Oh, and that 350z gets that camber and LSD in BSP but last I checked it wasn't killing the world there.  See?
    And none of that still has anything to do with 2 seats. Remember the old 300zx 2+2???  What if Nissan made a 350z 2+2???  Should it then be allowed in STU???  I bet if they already made it it would already be in STU and if Jason is right EVERYONE would be running 350zs instead of AWD turbo cars.  You guys can keep nitpicking this and that if you want.  You're right, I have my fingers in my ears because what's being said still hasn't answered the original question.
    And I haven't helped.  I've tried to engage in debate using examples and all that has done is help many of you get off track.  What I should have done is answer EVERY response with "But what does that have to do with having 2 seats instead of 4?"
    Lets just take as written that this is my future response to every post in this thread.
    '91 ITB Civic DX
  •  05-22-2007, 10:24 AM 245729 in reply to 245723
    jamesohoh7:
    Dammit.  You guys just keep drawing me back in.
    To automatically exclude 2 seaters from classes because its assumed they will be better than 4 seaters is absurd.  Suspension design???  Well, the 88-91 CRX and Civic have the EXACT SAME suspension.  Same part numbers even.  How about the M Coupe and roadster, which by many BMW folks accounts doesn't have as good a suspension design as its brother the M3 coupe/sedan.
    I could come up with more, but there isn't any point in bothering.
    If the SEB wants to pick a couple of 2 seaters that legitimately look like overdogs for STU and exclude them or saddle them with a tire restriction... Fine.  But exclusions and tire restrictions JUST BECAUSE IT HAS 2 SEATS is just plain silly.
    '91 ITB Civic DX
  •  05-22-2007, 10:31 AM 245731 in reply to 245726
    Catch 22:
    Right because we all know Solo is all about power and not handling. Suspension gains are always going to make a bigger difference than power in autox. Perhaps when you were road racing 10 hp made a difference down those long straits. I think about every stock class driver with a camber limited car would give power for another degree of camber which they will gain in ST.
    For the official why section 14 of the rules spells it out:
    Vehicles eligible for this category must meet the Stock category
    eligibility requirements, and include all coupes/sedans with a minimum
    of four seats and four seat belts, that are non-sports car based
    with a maximum engine displacement of 3.1 liters, are normally
    aspirated; and the small-displacement turbocharged sedans referenced
    in Appendix A. No limited slip differentials are permitted except
    for factory standard viscous coupler type units.
    A sports car based vehicle would include those that are 2+2 variants
    of 2 seat sports cars. As a guideline, eligible cars would typically
    come from the D, F, G or H-Stock classes. Note that 3.2
    ‘VEHICLE CLASSIFICATION’, also applies to the Street Touring
    Category, including adding or removing cars from the exclusion lists.
    Jason Isley
  •  05-22-2007, 10:54 AM 245734 in reply to 245624
