Is it time for national sound limits?
Last post 05-12-2008, 7:45 PM by Andy Hollis. 95 replies.
05-08-2008, 6:08 PM |
CHRISFP78
Joined on 11-15-2003
SFR
Posts 157
Points 1,980
Re: Is it time for national sound limits?
marka:Howdy,
StrokerAce: I wonder if some people think you are more irritating than FSP cars?
Oh, lots of people, I'm sure.
Hell, I often agree with them!
(But that doesn't make a national sound limit any more appealing) To 1 in 9 on this discussion anyway.
05-08-2008, 6:10 PM |
CHRISFP78
SFR
Posts 157
Points 1,980
marka:Howdy,
And, being serious for a moment (hard to do, but I'll try.. :-)
I'm 100% in agreement with having sound limits and following them for any site where such limits are needed.
I just don't believe we need a national rule forcing sound limits on sites where they _aren't_ needed.
That is until you loose your site for sound
05-08-2008, 6:12 PM |
CHRISFP78
SFR
Posts 157
Points 1,980
Zauskycop:Generally, I think Mark is just being very passionate about his argument here, and he DOES have a good one. We in Chicago run at a drag strip....even the FM's are only mildly annoying here. But I think Mark touched on, but missed the big picture with that shot of the Rotary EM car.... We currently have no sound limit nationally, yet now there is discussion of putting one on us, and for many of us, for no apparent reason. Yup, it will be a cost to some competitors (myself included as I think the Spyder is a tad loud), and how much of a cost will be decided on what the "acceptable" level of noise is. Will it be as much as San Diego??? WHO KNOWS?!?! Yes, that is an EXTREME example, but certainly, the possibility cannot be discarded by saying "That is a bad example because they are HIGHLY restrictive". What is highly? What isn't? It is a slippery path to go down when you start arbitrarily regulating sound levels "just because it may become an issue". I see nothing wrong with national giving leadership on "using sound limits at sensitive sites" and giving guidance as to what would be a good limit. But to say "everyone needs to run this sound level" is just doing it because they can... Personally, I see a greater issue of SAFETY with SPEEDS on courses these days. Why aren't they pursuing that?
I think the idea is for Tour and Pro events only. YOU CAN BE AS LOUD AS YOU WANT AT YOUR LOCAL EVENTS.
05-08-2008, 9:13 PM |
StrokerAce
Joined on 05-24-2001
Houston
Posts 479
Points 6,710
CHRISFP78:I think the idea is for Tour and Pro events only. YOU CAN BE AS LOUD AS YOU WANT AT YOUR LOCAL EVENTS.
and nationals.
05-08-2008, 11:07 PM |
BigEnos
Joined on 07-16-2004
Sykesville, MD
Posts 228
Points 2,825
My .02 is that I agree with Mark in that keep your "national" sound limits away from my events. FWIW I believe that my car will meet most if not all sound restrictions in the country, but it doesn't need to because afaik there's no site-imposed limits at my local events. I think the case can be made for enforcing some reasonable sound restriction at Nationals, ProSolos, and Tours, but as was mentioned before "reasonable" is open to some pretty heated discussion. I seem to remember from my car audio days that 3db higher was percieved to be about twice as loud. If this is true, then the difference between 90-95-100 is an incredible amount. Most people seem to be going in 5db increments, and that's probably not smart. 90 may be too quiet for some cars to "reasonably" (there's that word again) meet, but 95 may be too loud. I'm no expert, and I've never had to police sound, but maybe someone with more experience can chime in on just what it takes with some typical autocross cars to meet these restrictions. Also, what is San Diego's sound parameters? (sorry if it was mentioned earlier and I missed it)
Brian "Big Enos" Burdette
05-08-2008, 11:28 PM |
solo-x
Joined on 09-19-2003
Posts 765
Points 12,115
BigEnos, some sound data from my cars.
My STS car had you typical intake and header bolt ons. I used an OEM cat, and downstream from the cat I had the resonator section of a magnaflow catback exhaust at 2.25" ID. The exhaust terminated in the tunnel. The highest readings I got with that setup on that car driven to a nationally competitive level was 87db at 75'.
My new DSP ITR is running a header, resonated test pipe (no catalytic) and a full magnaflow cat back exhaust. It hasn't even triggered the meter yet.
One of the big issues with measuring sound is measuring methodology. It is easy to set a standard method for measuring sound though. Ignoring that method of measuring sound can get you some odd results. For example, my STS car that I mentioned above was once measured at 104db. Why? The club that measured the sound was doing so by placing the meter on the top of a cone set next to the start area, about 4ft from the car. They would guess when you were 75' away and see what the meter said at that time. Further they were not aware of how to set the meter to get an accurate reading and that resulted in the meter also being on the wrong scale. That is a completely useless way of measuring sound.
What is the easiest way to make sure everyone has the same guideline for measuring sound? Putting it in the rulebook and spelling it out. So now when you go to a region that DOES have sound restrictions (and who doesn't like traveling to other regions?) if you know you passed at site A, Site B will use the same measuring method and unless you've changed something or your car is incredibly close to blowing sound already you're most likely not going to encounter an issue. While that is not a perfect assumption, its better then having no idea what that other club is going to do to measure sound
Mark, trust me, I get it. I understand your concern. I thought for sure that when we passed sound limits at Devens it was going to ruin the sport and kill the fun. It hasn't. The only drawback is that with all the other cars being quieter now, nothing drowns out the noise of those damn two-strokes reving there engines for an hour at the time. .
05-08-2008, 11:36 PM |
dubya
Joined on 03-26-2007
Houston
Posts 29
Points 240
My proposed limit is 150db at 150'.
I just caught up wit this thread and I say
"HUH?" "Whadeesay?"
FYI - SCCA club racing limit is 103 dbA @ 50'
Most Spec Racer Fords are 93-98 at 50'
Wayne Hill
DA-Sound Control, SOWDIV
"I WON!!" What did I win? A trip to the last ChampCar Race.
05-09-2008, 1:37 PM |
rjones
Joined on 05-16-2006
Posts 13
Points 35
I think we need sound limits at all events because of the 5% of cars that are WAY to load. I am so sick of getting my ears split by a few cars.
Robert
05-09-2008, 3:20 PM |
marka
Joined on 03-13-2001
Poland, OH
Posts 1,593
Points 22,460
rjones:
And miatas annoy me. So eliminate them too, while you're at it.
Oh, and street tire classes.
05-09-2008, 7:21 PM |
CHRISFP78
SFR
Posts 157
Points 1,980
marka:
rjones:
We could elliminate Mark while were at it too.
05-09-2008, 7:56 PM |
Zauskycop
Joined on 04-11-2002
Hinckley IL
Posts 411
Points 3,880
marka:Howdy,
rjones:
I always thought that the plural of Miata is Miati???
Tracy Ramsey Team Blenderblaster 2000 MR2 DP Spyder
05-11-2008, 1:02 PM |
Chris D
Joined on 12-14-2007
St. Louis, MO
Posts 69
Points 1,095
Zauskycop:I always thought that the plural of Miata is Miati???
Wouldn't it be Miatae?
-- I'm in favor of some sort of uniform sound restriction. All the obnoxious straw-man arguments in this thread aside, I think everyone can agree that cars operating at sound levels approaching the lower threshold of pain are not only completely irritating, but unsafe for both your hearing and your well-being on the track. OSHA says that 85db over a period of 8 hours causes permanent hearing damage, and the threshold of pain starts at 107db. If your car is distracting me while I'm working a corner because I'm involuntarily uncomfortable from the noise, then you're putting me and other drivers at risk. That's the only reason why I support this. Not for conformity (because no site will ever conform to LA SPL requirements), and not for retaining or acquiring a site (you can be just as "proactive" on this issue by asking your prospective/current site about levels they're comfortable with). That being established, the way that SPL is measured needs to be rethought. It's far too easy to cheat the system, which solves nothing and only makes the issue more complicated.
#12 STS 2007 Scion tC #24 ITS 1991 Nissan 240SX
05-11-2008, 3:54 PM |
redsts2
Joined on 03-05-2007
Posts 20
Points 395
Has anyone been to Toledo Express? You know, the home of the 180th figther wing and the cargo company BAX Global (same loading ramp where courses are set up). The roar of the fighter jets taking off is enough to shake the ground under your feet....and the cargo planes (727, DC8, and sometimes 747's) come and go all night. The planes (way back it was about 40+) start to come in around 11:30 p.m. and the last one goes out around 5 a.m.. I really doubt the neighbors care about the "angry bees" of a FM car or unmuffled anything.
05-12-2008, 9:33 AM |
Patrick Washburn
Joined on 12-26-2000
Wausau, WI
Posts 1,362
Points 17,255
redsts2:Has anyone been to Toledo Express? You know, the home of the 180th figther wing and the cargo company BAX Global (same loading ramp where courses are set up). The roar of the fighter jets taking off is enough to shake the ground under your feet....and the cargo planes (727, DC8, and sometimes 747's) come and go all night. The planes (way back it was about 40+) start to come in around 11:30 p.m. and the last one goes out around 5 a.m.. I really doubt the neighbors care about the "angry bees" of a FM car or unmuffled anything.
Odd as it sounds, I don't put it past anyone. Those are familiar noises to those people. Like living next to train tracks, they don't hear it anymore. Give them a new sound, and they will instantly pick up on it. Skidding tire sounds are the ones that seem to drive people up the wall most, not engine noise. That sound, while maybe not "registering" on the scale, will carry above most other sounds and people will hear it. And think the worst.
Anyway, don't really have any opinions...just thought I would mention that.
05-12-2008, 3:38 PM |
rjones
Posts 13
Points 35
marka:
rjones:
It's an old pic so go ahead they annoy me too when someone driving one beats me.
Nobody wants a hard sound limit with all the issues that come with it, but I think it is needed for peoples health and site retention.
It would be nice if everyone would atleast try to muffle their car to an reasonable level (people not holding their ears when they go bye) then it would not be needed. A few people will run straight pipes because they can to gain .001 sec. Is it fair to the person being a good neighbor to loose to someone runing straight pipes by .001 sec.?
Robert
05-12-2008, 7:45 PM |
Joined on 05-28-2003
Posts 3,893
Points 55,775
Dan Maloney's place, Arizona Motorsport Park, is right next to Luke AFB. Not that it gets the same amount of traffic as Toledo, but still plenty of two-ship afterburner takeoffs there. Yet he still got shutdown by the local developers and their nearby housing subdivision due to "motorsport noise". Something about the constancy (all day long).
I can see people tolerating "the sound of freedom" yet being annoyed by "the sound of kids squealing tires and revving motors". --Andy PS: Anybody know the latest on AMP? I keep hearing that he's still got a chance to revive through the legal/political process, but nothing ever materializes. Shame.
Page 5 of 5 (96 items)
5
