330i setup?
Last post 06-13-2008, 5:57 PM by murph1379. 93 replies.
Page 5 of 5 (94 items)   < Previous 1 2 3 4 5
  •  04-16-2008, 4:29 PM 295626 in reply to 295593
    Re: 330i setup?
    murph1379:
    Why would the Kumhos be any different than the Hoosiers? If anything I'd think the Hoosiers would be harder, since they're wider.
    As was already stated about the beads being different.  The problem is not so much getting the tire on the rim but getting it to bead up is the major PITA.  The sidewalls are so stiff on the Kuhmo that they just buckle and you almost can't push enough air into the tire to get it to bead up.  I have found that 285/30/18 Hoosiers are easier to mount on a 7.5 inch wheel than the 245/35/18 Kuhmos are to mount on the same wheel.
    Keith
    2005 Chrysler Crossfire-- DS
    1993 Subaru Legacy-- Rallycross car
  •  04-17-2008, 10:05 PM 295889 in reply to 295609
    Re: 330i setup?
    murph1379:
    You know they were calling me Matt Murray over the speaker at Nationals? The announcer thought you were having an especially bad day. =]-Matt Murphy
    Dude, you were definitely dissed. People have been shot for less. I've ruffled WAY too many feathers. You're due for a name change, or run in another class or something. Geeze.....
    Matt Murray
  •  04-28-2008, 3:23 PM 297423 in reply to 295256
    Re: 330i setup?
    bob clark:
    Todd and I both tried the 275 kumhos and the rubbed a bit but we lived with it. Bigger concern was that they are a considerably taller tire and for my taste the 330 is geared to tall already.
    To clarify, you ran Kumho 275/40/17's all around and they fit?
    They seem to be the same diameter as the 245/45/17, which I used at the beginning of last season. The shorter Hoosiers were better, but it wasn't a huge difference, IMO.
    I ask because I'm considering trying the 275 Hoosiers all around, which have a listed section width skinnier than the 275 Kumho's, or the 265 BFG R1's mentioned by CSBM5, which seems to indicate they'll very slightly rub or not rub at all.
    Or maybe I'll give the 275F/245R hoosier combo a try. I would have the gearing of the 245's, but the front grip of the 275's... the big loss is the ability to rotate them if the fronts are still wearing like crazy.
    Anyway, your input would be appreciated.
    Matt
  •  04-29-2008, 7:08 PM 297673 in reply to 297423
    Re: 330i setup?
    On my 330 I experienced some rubbing at the rear.  I ran the tires on non stock offset wheels at local events where no one cared so I can't say what the rubbing would be like on proper wheels.  Todd ran them on his stock wheels of his 325is.  The first used set he tried he filed down the tread to stop the rubbing he said it made no difference in the handling.  Subsequently he made some spacers which eliminated most if not all the rubbing. The spacers were less than 5 mm.  I have one good set of the 275 Kumhos sitting in the warehouse.  I wonder if I should buy another pair.  They look huge next to the 245 18 Kumhos.  The extra grip might be worth the poor gearing.  Todd does well with his 325is.  Interestingly we once compared cars with the same tires and had 2 national champions drive the cars as well.  The universal response was that his car turned much better but definitely more power on tap in the 330.  Todd's car is totally stock with some mild alignment. My car felt better in stock form too but wheelspin made it much slower. Todd gets wheelspin but not as bad perhaps because of the lower power.
  •  04-30-2008, 9:46 AM 297783 in reply to 297673
    Re: 330i setup?
    Thanks Bob, did they rub the fender or the inside? If spacers helped, it sounds like the inside.
  •  05-02-2008, 10:54 AM 298174 in reply to 295301
    Re: 330i setup?
    BadBrad:
    Let me know if anything is incorrect or incomplete.
    1. Wheels/Tires
    ·        Wheel notes:
    o       SSR GT2 wheels came in stock sizes, but no longer available
    o       Most 18x8 wheels have +40mm offset, which is 0.7mm beyond legal limit.
    §         Some folks machine off the 0.7mm extra to be legal
    BadBrad - your note about the SSR GT2's coming in stock sizes is not completely accurate - the diameters (18), widths (8.0 & 8.5), and rear offset are stock class legal, but the GT2 front wheel offset is ET40, which is (barely) illegal.  It actually/also falls into the "Most 18 x 8 wheels have +40  offset" category you mentioned above.
    Keith Q.
    2004 BMW 330i ZHP
  •  05-05-2008, 9:11 AM 298433 in reply to 298174
    Re: 330i setup?
    quik96m3:
    BadBrad:
    1. Wheels/Tires
    ·        Wheel notes:
    Yeah, I learned that after I posted that list.
     I autoxed my '04 ZHP sedan for the first time yesterday.  Everything is still stock except for the Kumho V710 245/35-18 tires.  I did knock out the front upper strut locator pins to gain some camber, but I think I'm still only getting about -1 degree up front.  Front toe is about zero, and I didn't touch the rear alignment, which had just a little bit of toe-in (~1/16" total).  I'm still trying to figure out tire pressures.  I started at 40f/35r and ended up around 37f/34r, but still not sure which way to go.  Any suggestions?
    Rear wheelspin was really annoying.  The course had an uphill start with some offsets, and I felt like the AWD cars gained seconds on me before the second gate.  When powering through turns I was spinning the inside rear tire severely.  The car was very good in high speed transitions, especially for a big heavy sedan (I have been autoxing Miatas for the last several years), but it really pushed in the sweepers.  It's hard to rotate the car, even using lift-throttle or trail-braking.
    My next step will be to install a bigger front swaybar.  I hope this will lessen the wheelspin problem without causing much more understeer in the sweepers.  No budget for shocks right now.
    BB
  •  05-05-2008, 9:21 AM 298434 in reply to 298433
    Re: 330i setup?
    BadBrad:
    A bigger front bar is easily the best thing you can do for your set-up, will make a major improvement in front & rear grip and tire wear.  A bigger front bar actually decrease understeer by loading the front tires more evenly (reducing sway increases front tire contact patch when turning by decreasing negative camber loss resulting from body roll).
    Keith Q.
    2004 BMW 330i ZHP
  •  05-06-2008, 8:09 AM 298631 in reply to 298434
    Re: 330i setup?
    Any recommendations on tire pressures for the V710s on this car?
  •  05-12-2008, 6:28 AM 299691 in reply to 298631
    Re: 330i setup?
    I find 37F/39R is a good starting point
  •  05-22-2008, 12:20 AM 301657 in reply to 299691
    Re: 330i setup?
    Has anyone ever tried the E90s?  I'm just wondering how competitive they can be?
  •  05-23-2008, 1:29 PM 301960 in reply to 301657
    Re: 330i setup?
    Has anyone figured out how low you can run the gas on these and still not run out or suffer fuel starvation?  I autocrossed on a 1/4 tank and had no starvation problems but I wonder how much lower I could go.  May test it this weekend.
  •  05-23-2008, 2:54 PM 301974 in reply to 301960
    Re: 330i setup?
    My 2004 330Ci starved on a course with a low speed clockwise mini oval loop around with slightly less than a 1/2 tank.
  •  06-13-2008, 5:57 PM 305376 in reply to 301974
    Re: 330i setup?
    so, I did some experimenting with 275's up front, and I thought I'd update here.
    When I first tried the 275's up front on my sport wheels, at 40psi all around, it was pretty awful. Sweeper grip was clearly improved, but turn in response was non-existent, it would take like half a second. I couldn't get closer than a foot from every cone. increasing front compression a bit and increasing the front tire pressure to 48 helped, but it still felt like I would have been faster on 245's. Increasing the pressure also hurt some of the sweeper grip that had been gained.
    I went to Milwaukee last weekend and talked with Bob and Todd down there a bit, and gave the 275's another shot, this time with even higher pressure, around 52. That felt better, and the times were looking pretty good. So for the afternoon runs I swapped to the 245, and right off the bat, I could tell they were still clearly better in transitional response. I still gave up a bit in the sweepers, but with the high pressures, the sweeper performance was pretty close between the 275's and 245's, but the slalom and offset performance was better with the 245's.
    I'm going to continue to test, but so far it looks like the 245's are the winner. I think the 275's may wear better, and that might make them worth running, but I have a good 15-20 runs before that will be clear.
