The Rules:S. OE pop-up headlights may be replaced with static headlights,
provided the replacement units are intended for automotive use on
public roads as a primary means of illumination, and retain high and
low beams as originally provided by the manufacturer. All associated
hardware may be removed, replaced or modified.
I think this is a great rule that a lot of the competitors in SSM can make use of. Miata, RX7, Corvette, MR2 everyone benefits. I looked around for various options for the Miata.
I always strive to make sure my car is 100% legal The solution I landed on replaced the turn signal lenses with clear ones and utilized a Sylvania 9007 bulb. I thought I had all the bases covered,
Static headlight - check
intended for automotive use on public roads as a primary means of illumination - check
retain high and low beams - check
I showed it to some local folks and they raised a concern that I had relocated the lights. It never occurred to me this could be an issue. I didn't even have to lengthen the wiring, just swap plugs. It seemed to me that no matter what solution you used the lights would have to move some amount. Anyway, the picture below shows what I did. I haven't covered the original openings yet in case I have to take a different approach. I am writing to the SEB tomorrow for clarification, but thought I would canvas this audience as well.
Thanks for your time,
--Chris
Clear lense
Stock lense
Chris
89 SSM
