GChambers:Scott, I had a little trouble too. I wanted 190 but got 90. Could that be because I've already got it reserved from last year?
Just looked.....exactly the case. The '2010 Reserved Number' event was referencing the '2009 Reserved Number' event for numbers saved for some reason. I turned it off, so should be fine now.
Scott..... for the events you have set up for the season, make sure you make the event "reference" the 2010 Reserved Number entries (on the bottom of the page where you can edit registration form fields....should be a drop down box asking "Event to use for reserved numbers").
-Will
Will Lahee -- Indy Region
Section 8 Racing
Knowledge is realizing that the street is one-way, wisdom is looking both directions anyway
