Bought an HD camcorder for $119+$30 for SD card for autox clips.
Last post 08-23-2008, 10:06 PM by Roy Dietsch. 85 replies.
03-08-2008, 8:03 PM |
03-19-2008, 1:43 AM |
Lister
Joined on 10-23-2007
Posts 4
Points 50
Re: Bought an HD camcorder for $119+$30 for SD card for autox clips.
Another couple of updates on my AIPTEK A-HD.
I had noticed after the firmware upgrade that the sound was much better but now I was having problems keeping the camera running during a session. I had no problems while using it handheld but even when sitting on the grid at times it would just shut down for no apparent reason not to mention when flogging around on the track. Then to get it functional again I would need to remove the battery and reinsert it and it would be fine, still indicating lots of battery left. All I could figure was the vibration was making the battery lose contact with the terminals so I put some electrical tape on the battery sides so it would no longer have any wiggle room and voila that fixed it right up and I was able to record 4x20 min session with no failures.
However after a few jaunts at the track I was getting noise again but this time it was different more like a vibration. I had been mounting this to an IO Port rollbar mount and was picking up a lot of vibration from the car which has been shaking the crap out of every camera that I have put on it. I removed the camera from the mount and could feel the vibration if I thumped or tapped the camera in the upper half above where the battery is located but I knew it could not be the battery since I padded it with the tape. Well I decided to take the camera apart and from what I can tell the vibration must have been coming from a large capacitor that has its leads bent 90 degrees so it lays flat against the circuit board. I put some small rubber tubing around the capacitor and now it is padded from the circuit board and the outer cover and after I got it back together it appears to have made a significant difference and when I thump it there is no more vibration. I just need to mount it back on the car this weekend to validate the fix but I expect that this solved this problem.
03-19-2008, 10:49 AM |
STS3gCivicSi
Joined on 04-18-2002
Austin, TX
Posts 885
Points 11,735
You can also use hot glue to keep those large components from vibrating around, but that is a last-ditch effort. One of the autocross guys in SoCal had the exact same problem, he returned it and got another with no problems. The I/O Port mount has a lot of arms and gadgetry that tends to make most any camera (especially lightweight ones) shake and vibrate around, maybe take a look at some of the ChaseCam mounts for a more stable option. Note-- I have no affiliation with the companies above, just offering an alternative. Name brands for illustration and are trademarked/copywrited by their respective owners
*Banned Again* Permanently
03-20-2008, 7:43 PM |
Sebastian R.
Joined on 08-09-2005
Posts 78
Points 780
I'm the autocross guy in SoCal; the second one only works sometimes, and let me down completely last weekend at the tour. It seems to work better for my wife than me (smoother driver?). I'll try tape on the battery, but taking it apart sounds scary!
03-20-2008, 11:28 PM |
STS3gCivicSi
Austin, TX
Posts 885
Points 11,735
Sebastian R.:I'm the autocross guy in SoCal; the second one only works sometimes, and let me down completely last weekend at the tour. It seems to work better for my wife than me (smoother driver?). I'll try tape on the battery, but taking it apart sounds scary!
Email sent, Seb.
03-22-2008, 8:10 PM |
The Nebulizer
Joined on 11-29-2007
Indy
Posts 413
Points 8,315
So, the updated firmware is not causing anyone any problems?
Are you also putting some tissue over the mic?
Jason P. Indy Region Moderator SMS - M3 LSB SMG E46
04-09-2008, 6:37 PM |
The Nebulizer
Indy
Posts 413
Points 8,315
The Nebulizer:
I updated my firmware with good results. Sound is much better and no problems.
How are you guys viewing/editing this on your computer? Mine is too slow to play the files - what kind of comuputers do you have/recommend?
04-09-2008, 8:07 PM |
Peppler33CS
Joined on 02-28-2002
Posts 115
Points 2,030
Upgrade your computer! Really, I couldn't play the vids on my 2200 AMD with 512k ram even with a Geforce video card. I recently upgraded to 4600 X2 AMD with 2 meg ram (so I can play Guitar Hero on PC hhehe) and it runs fine now.
04-17-2008, 4:20 PM |
mrexotica
Joined on 11-09-2007
Posts 97
Points 1,535
By the way, Wallgreen's sells two different Aiptek (I believe) cameras.
One for $100 & one for $150
Of course, i didn't look at the details...
"Most amateur drivers go too fast in slow corners and too slow in fast corners" Emerson Fittipaldi
04-17-2008, 5:19 PM |
STS3gCivicSi
Austin, TX
Posts 885
Points 11,735
mrexotica:By the way, Wallgreen's sells two different Aiptek (I believe) cameras.
Aiptek also makes non-HD basic camcorders for about the same price range, I think I have also seen them at Walgreens.
04-19-2008, 9:25 PM |
Roy Dietsch
Joined on 05-26-2005
Milwaukee
Posts 185
Points 1,375
I used that unit and the recorder is great, however I have had problems with the light performance and quality on the lens because they cheap'ed out on the HAD and CCD to get the price so low. www.datatoys.com actually sells an external camera that uses a high quality HAD and CCD that makes it a very, very, very respectable package. They have the connections that make it completely integrable with the AIPTEK too. http://datatoys.com/singlecamsys.htm When ordering just state you need the cable to connect to the AIPTEK and George will set it all up.
www.Datatoys.com
04-20-2008, 1:21 AM |
STS3gCivicSi
Austin, TX
Posts 885
Points 11,735
Roy Dietsch:I used that unit and the recorder is great, however I have had problems with the light performance and quality on the lens because they cheap'ed out on the HAD and CCD to get the price so low. www.datatoys.com actually sells an external camera that uses a high quality HAD and CCD that makes it a very, very, very respectable package. They have the connections that make it completely integrable with the AIPTEK too. http://datatoys.com/singlecamsys.htm When ordering just state you need the cable to connect to the AIPTEK and George will set it all up.
That's the nicest part of the A-HD that it can still connect an external bullet camera....most if not all "new" camcorders have eliminated that feature. Another option for these as well -- http://www.cam-fx.com and http://www.cam-fx.com/category.sc?categoryId=3 , a bit less expensive alternative. Works great with the A-HD, that's the setup that I have been using since September.
04-29-2008, 1:46 AM |
The Nebulizer
Indy
Posts 413
Points 8,315
Fastmike:
OMG! I am pissed but happy...
60FPS
Yeah, I just saw this last weekend. 60fps would be a very nice feature to have.
04-29-2008, 10:16 AM |
04-29-2008, 11:09 PM |
SS RX7 R2
Joined on 03-26-2003
Irvine, CA
Posts 101
Points 1,690
Fastmike:
I read the Action model w/auto focus has problems in car applications. The new 1080HD AHD+? version at BestBuy is $149 this week - no Walmart! Supposed to have a better stereo mic than the 720 AHD also, but still has a lot of wind noise.
04-30-2008, 9:34 AM |
Fastmike
Joined on 12-16-2001
Seattle Wa USA
Posts 1,656
Points 22,710
Off to Bestbuy! Thanks for the tip.
I hope the 60FPS works out. I don't think my laptop will be able to handle playing that but my home computer(gamer) shouldn't have a problem doing it.
FM
05-05-2008, 3:06 PM |
angryfist
Joined on 07-17-2003
MI
Posts 40
Points 315
FM, Any updates on how the A-HD+ looks?
Jason Wong CrazyMonkeyRacing #54 STX *Retired
05-05-2008, 5:11 PM |
The Nebulizer
Indy
Posts 413
Points 8,315
angryfist:
FM,
Yeah, I think I am going to pick one up, but would like to hear a few comments from anyone who has tried it...
05-05-2008, 5:23 PM |
STS3gCivicSi
Austin, TX
Posts 885
Points 11,735
I just hope their hardware is getting a little bit better. I've had my A-HD since September, and it's finally very rattly and blanks out every once and a while. I think there is damage to the sensor, as I can't even shoot inside the house without some optical issues...hard to describe, I'll take it apart tonight and see what is up. Also, I have to tape up the slide switch from std to macro focus, as it keeps falling down just with gravity. Half a packing peanut or a torn-up napkin still works great on muffling the mic, though.
Page 4 of 5 (86 items)
4
