Kumho>Bridgestone?
Last post 06-13-2008, 1:39 PM by glagola1. 370 replies.
Page 4 of 19 (371 items)   « First ... < Previous 2 3 4 5 6 Next > ... Last »
  •  01-08-2008, 11:49 AM 279615 in reply to 279608
    Re: Kumho>Bridgestone?
    Available at http://www.good-win-racing.com/Mazda-Performance-Part/61-0099.html, and available for online purchase. They have other sizes under RX-8 and 06-08 MX-5 tabs.
     Somebody buy these and do some testing to save me some money
    Chris Raymond
    1990 Miata - STS2
  •  01-08-2008, 11:43 PM 279708 in reply to 279615
    Just got two sets from AIM. They are the tire shop at Sears Point in California. They are going to make a 245 - 17 in the near future. The 235 40 17's are huge on my 8.5 wheels. I measure 9.8 inches.
    I think they are going to work good for the subie.
     http://www.aimtire.com/typ_main.asp?ObjectID=528
    Drew
  •  01-09-2008, 4:22 PM 279785 in reply to 279708
    How much were the 235 Toyos shipped? I'd imagine Houston shipping would be within about $10-15 total :)
    I'm not sure what I'll try on the VW after the RE-01Rs wear out. Was looking at the Dunlop, then the Toyo, then the Kumho.
    David Hedderick
    Pearland (Houston), TX
    01 CRG YZ125
    08 Mazda 3s
  •  01-09-2008, 5:05 PM 279792 in reply to 279785
    so anyone done any testing?  It's time to buy tires....
  •  01-14-2008, 7:41 AM 280238 in reply to 279792
    Toyo>Bridgestone?
    Is anybody running R1Rs worried about the warning from Toyo about operating these tires in freezing temps? Atlanta's first event is in February and it could easily be freezing down here.
     - http://marktg.toyotires.com/file/TireStorage.pdf
    I also have found (please correct me if my information is bad) that this tire compound is at least 2 years old according to the link below. Not only that, but this tire is simply an evolution of an even older tire, the toyo trampio R1R. The improvements apparently being limited to increasing sidewall stiffness and decreasing tread wear.
    - http://www.jdm-option.com/eng/parts/05_12/r1r.html
    I am not meaning to come off as being against Toyo... I am simply sharing the information that I have found.
    Chris Raymond
    1990 Miata - STS2
  •  01-14-2008, 1:16 PM 280303 in reply to 280238
    Re: Toyo>Bridgestone?
    decke003:
    The RE-01R is an older compound too, just FYI. It has even been here for almost 2 years (April?)
    00' 328Ci
    01' Tahoe LT
    98' Camaro Z28 - dead
    95' 325is - STX 182
  •  01-14-2008, 6:21 PM 280348 in reply to 280303
    good point... i suppose its all speculation until we see numbers.
    Chris Raymond
    1990 Miata - STS2
  •  01-14-2008, 8:26 PM 280376 in reply to 280348
    AIM lists the tires for $170.00 each. I was able to knock it down a little for some feedback to them. Basically saved shipping. One set was shaved the other was full tread. By the way shaving is only $10.00 EACH TIRE! I let you know how they work next month, and it should be pretty cold......
    drew
  •  01-18-2008, 12:56 AM 280953 in reply to 280376
    Attachment: tires1.jpg
    I picked up my R1R tires today, along with a new set of RE-01R tires :)
    In pictures from left to right:
    205/45-16 RE-01R on 16x7 wheel
    195/50-15 R1R on 15x7 wheel
    205/45-16 RE-01R on 16x7.5 wheel
    Brian
    89/189 STS/STX '89 Civic Si
  •  01-18-2008, 1:00 AM 280954 in reply to 280953
    Attachment: tires2.jpg
    another
  •  01-18-2008, 1:02 AM 280955 in reply to 280954
    Surprise [:O] Re: Toyo>Bridgestone?
    Attachment: tires3.jpg
    R1R
  •  01-18-2008, 1:03 AM 280956 in reply to 280955
    Attachment: tires4.jpg
    shaved to 4/32nds
  •  01-18-2008, 1:07 AM 280958 in reply to 280956
    Attachment: tires6.jpg
    difference in height between 195/50-15 R1R on 15x7 and 205/45-16 re-01r on 16x7.5 (stack of 4)
    will see how they work next weekend at the dixie event :)
     btw, the toyo compound feels a bit softer then the bridgestone compound with the fingernail test.
  •  01-18-2008, 1:48 AM 280960 in reply to 280958
    BrianGT,
    Thanks for taking the time to post!  I can't believe how wide those R1R's are.  That's pretty crazy.  I can't wait to see what your impressions are after the Dixie Tour!  Keep us updated!!!!!!
    Blog
    Premium stock images
  •  01-18-2008, 3:12 AM 280961 in reply to 280960
    Well im gonna keep my eyes peeled for when Kumho releases their "Falken Killers" in a 225/50/16 i am looking to run these on a 16x7 Enkei RPF1 for my EP3 (2002 Civic Si)  in STX Class.
    Jake Kaminskis
    2002 Honda Civic Si STX
    SCCA MKE Region
    www.MidwestTuning.com
    www.Datatoys.com
  •  01-18-2008, 8:16 AM 280984 in reply to 280961
    Appreciate everyone else being the guinea pigs.  Should be useful when I go to buy new tires in May. Big Smile
    Sponsored by AgileAuto.com
    D.C./Philly Region - 3 STX
    cardomain.com/id/piknockout
  •  01-18-2008, 9:53 AM 281011 in reply to 280984
    Just as a point of reference, the Bridgestone 195/50-15 stacks higher than the Bridgestone 205/45-16 also.  Would be best to compare both brands in the same size.  Should be plenty of opportunity to do that at Dixie.
  •  01-18-2008, 10:24 AM 281021 in reply to 281011
    Second that. I was surprised the first time I saw the RE-01R 15's stacked next to the 16's...there was about an inch in height difference when 4 are stacked next to each other if I recall correctly. But once you look at how the tread is constructed, the 16's tread width was much wider compared to the 15's. I'm still evaluating what's faster...splitting hairs practically on the CRX and definitely course dependent.
    -Mike King
  •  01-18-2008, 10:55 AM 281028 in reply to 281021
    Yeah, I noticed that when I was looking at the 15" bridgestones too.  I will see if I can compare them at Dixie.  There is more tread on the 15" toyos than the 16" bridgestones.
    One more thing that I noticed before the tires were mounted was that the Toyos were heavier, and the sidewall was a good bit stiffer.  I need to pick up a durometer to monitor the tires, but I think that the Toyo R1Rs are definitely a softer compound.  It will be interesting to see how they hold up in the heat of summer compared to the Bridgestones.
  •  01-18-2008, 12:10 PM 281039 in reply to 281011
    The 195s Toyos do look wide, if not as wide as the 195 B-stones.  Will be real interested to see how wwwwiiidddeee those 225/45/15 Toyos are.
