Are Hoosier A6's legal in stock class?
Last post 07-06-2009, 5:28 PM by 00R101. 16 replies.
Page 1 of 2 (17 items)   1 2 Next >
  •  06-02-2009, 8:17 PM 363741
    Hey all,
    Just needed to double check before I spend the BIG $$$
    Thank you
     SB
  •  06-02-2009, 8:34 PM 363743 in reply to 363741
    Re: Are Hoosier A6's legal in stock class?
    yes they are legal
    Honda S2000
    AS 10
  •  06-02-2009, 9:23 PM 363748 in reply to 363741
    "yes they are legal" - and greatly encouraged Yes
    Matt S
    '99 Miata - STR
    '66 Mustang - CP
  •  06-02-2009, 9:42 PM 363752 in reply to 363741
    17 year old girls.....NOT LEGAL !
    Hoosier A6's legal
    Trying to get faster
  •  06-02-2009, 11:06 PM 363769 in reply to 363741
    SRT6:
    Hey all,
    Thank you
     SB
    What sizes are you looking at running?
    Just out of curiosity.
    Jeremy Foley
    2001 Subaru 2.5RS Retired G-Stock Beast (SOLD)
    2003 Evo 8 Modded Daily Driver (Crashed!)
    2004 RX-8 Former Borrowed B-Stock Killer (Too Slow!)
    2008 Z06 Super Stock Slayer!
    President
    Team if you can't beat them-spend more money!
  •  06-03-2009, 1:15 AM 363778 in reply to 363769
    Thanks guys, feeling much better now. Big Smile
    Rear size will be 295/30/19
    Front will be 285/30/18
    Car is a Chrysler Crossfire SRT6
  •  06-03-2009, 7:37 AM 363793 in reply to 363778
    SRT6:
    Make sure you have at least 5mm of spacer (or wheel with lower offset than oem) up front...preferably a full 1/4"
    on my base car, 285's rubbed the ball joint stud with 5mm...another guy had no rub with the 1/4"
    Bryan
    2008 Corvette Z51
    SS #127
  •  06-03-2009, 3:33 PM 363881 in reply to 363793
    Hey Bryan, I'm the guy that bought your 295/30/19's Big Smile
    Thanks for the comment on the spacers, these things are hanging me up. Confused
    I've got the stock rims front and back and was planning on going with 6mm spacers up front (or 1/4") and 10mm spacers in back. (These sizes come from what you and others on the XF forum have said). I just got off the phone with Fred at Wheeladapter com and he didn't think a 10mm, "hubcentric only", spacer would work and that it needed to be "hubcentric AND wheelcentric" but, he said, that wouldn't work either. (insert autojargon here that makes no sense to me). So Confusion Reins [*-)
    I've even got a tire shop telling me I should bolt a wheel adapter to the hub first, then use a spacer. No one on any forum I've visited said anything about a wheel adapter, then a spacer. This is becoming a complete pita for a non car guy. But I'm not giving up.
    Any further advice would be greatly appreciated.
    Steve B
  •  06-03-2009, 3:57 PM 363885 in reply to 363881
    If you are going to run the car in Stock class, you can only vary the original equipment wheel offset by 1/4" maximum, meaning those 10 mm spacers you want to run with the stock rear wheels will make the car illegal in Stock class.
    Keith Q.
    2004 BMW 330i ZHP
  •  06-03-2009, 5:12 PM 363892 in reply to 363885
    Thanks Kieth, I remember reading that a long time ago and forgot about it. Sucks bein' a newbie sometimes.
    Hey Bryan, 1/4" spacer won't be wide enough in the back right?
    EDIT: So not only does it suck to be a noob, sometimes it's also embarassingEmbarrassed
    After reading some more on the crossfire forum I decided to go put the rears on the car. No, I hadn't done that yet, that's the embarrasing part. And guess what, they fit...just fine thank you. So it appears that there is no need for spacers to make the tires fit. The only reason, as far as I can tell, to add spacers, would be to make a wider foot print. So, the wheels in the rear are good to go, and I may add 1/4" spacers (to stay legal) to get a bit wider for AXing. Next to tackle are the fronts... I have the rims but haven't bought the A6's yet.
  •  06-03-2009, 7:41 PM 363911 in reply to 363892
    yeah, you don't need or want spacers in the rear...front you'll need both the clearance and the help with grip from spacers
    Bryan
    2008 Corvette Z51
    SS #127
  •  06-03-2009, 7:47 PM 363913 in reply to 363911
    That's Great! Thanks again Bryan Big Smile
    One more qeustion if I might; so I'm looking for 1/4" hubcentric (not hub and wheel centric), is this correct?
  •  06-04-2009, 9:03 AM 363970 in reply to 363913
    SRT6:
    yes, 1/4" hubcentric spacers.  5mm will work and seem to be much more common these days, but the ball joint will cut a (harmless) groove in the inner shoulder.  Remember, you'll also need longer lug studs...I think I actually have a set in the garage if you're interested.
    Bryan
    2008 Corvette Z51
    SS #127
  •  06-04-2009, 9:15 AM 363972 in reply to 363752
    David Lehman:
     There's probably a real interesting story how you found that out.
  •  06-04-2009, 8:57 PM 364093 in reply to 363972
    Hey Bryan, Yes, interested in the longer studs. Let me know if you find them and how much you'd like for them.
    Thanks
