Now I have a place to play in Prepared!
Last post 07-21-2009, 10:41 AM by Fair. 9 replies.
  •  06-24-2009, 6:11 PM 366471
    seeing that nobody has posted in the Prepared forums for awhile...
    According to the July fastrack
    Solstice GXP = FP
     So what's everybody's thought on this? I've always loved the idea but don't have the heart to cut my windshield off yet.
    Think it'll give the 240z's a run for their money?
     2000cc x 0.75 = 1500 lbs
    Turbo: 1500 + (.375 * 2000cc) = 2250 lbs
    With my 18x11 wheels: 2250 + 100 (over 10" width) + 100 (over 16" dia.) = 2450 lbs
    no car is allowed to weigh less then 1900 lbs and no more then 2500 lbs.
    It should be easy to get the car to 2450 considering it's a convertible (remove the top and windshild, but add a roll bar).
    You can fit a 16" wheel on the car but... i don't think it can be much wider then the stock 8" rim or it could have UCA interference.
    So what's some other first thoughts on the car in FP?
    Alex Jones
    2007 B-Street Prepared GXP
    www.CrazyMonkeyRacing.com
    "Your co-worker can't make it in today, the water pump on the Porsche broke"
    "Isn't his car air-cooled?!"
  •  06-24-2009, 6:48 PM 366478 in reply to 366471
    Re: Now I have a place to play in Prepared!
    I think the GXP will be an awesome FP car.
    • BSP is almost always faster than FP. Your car can be 400 lbs? lighter than in BSP trim.
    • FP has the fix for the GXPs short second gear with different rear ratio.
    • Dont take out that windsheild - take out all the weight you can insidd. Thats a "point of no return, loose all your money" kind of step
    • You should be able to tune that turbo motor to be the right range without much effort.
    • I might think of going down to 18x10s if you can go down to 2350 lbs. Once you take out that weight you might not need that extra tire.
    • You have to retune the car to work with a small air restrictor specified by FP
    The GXPs should be able to give the Zs a run for their money. But all that said we well built and more importantly well driven Evo 8 / 9 should be the ticket in FP.
    BTW I have a underprepared BMW e36 in FP. Its basically a DSP car MINUS 500 lbs.
    If I were you I would remove all the items that can be easily put back into the car, tune the car with the restrictor and a standalone and see what can be done. If theres is potential tear up that car further.
    Vinax
    1993 BMW E36 F-Prepared
    1978 Chevy Malibu C-Prepared
  •  06-24-2009, 6:53 PM 366479 in reply to 366471
    DrJones_CMR:
    Want a co-driver?   ;)
    Robert Puertas
    www.EvoSchool.com
  •  06-25-2009, 3:04 AM 366524 in reply to 366478
    vinax:
    I forgot about the restrictor for the Forced Induction cars. although the 52mm resitrictor is just over 2" and I'll have to check my intake pipe (or up pipe) to the turbo, it's probably pretty close to 2" already.
    More then likely i'd try to find a slightly damaged GXP and transfer the parts from my car to it. this way I wouldn't feel too bad about loosing the windshiled and such.
    Robert Puertas:
    I think the noble in your avitar already looks pretty fun :)
    Alex Jones
  •  06-25-2009, 1:23 PM 366674 in reply to 366524
    Yeah, the Noble is a blast.
    And hopefully, it'll have a class to play in next year.  (Write to the SEB with your support for the Noble in XP!)
    The second I saw the GXP classed in FP I thought it would be a ton of fun, too, hence my clever way to answer your question...
    Robert Puertas
    www.EvoSchool.com
  •  06-26-2009, 11:16 AM 366831 in reply to 366674
    Beating the Z's in FP is not the hard part... it's beating John Thomas in anything that is really freakin' hard!
    Tom
    JT's whipping boy since '04
    Tom Holt
    FP199 280Z
  •  07-01-2009, 4:05 PM 367556 in reply to 366831
    tholt29:
    Tom
    We're certainly looking forward to seeing everyone at Lincoln. Here's to hopin we get a big FP turnout.
    -Aaron Goldsmith
    www.EliteTint.com
    www.ChaseCam.com
  •  07-02-2009, 8:38 PM 367760 in reply to 366471
    DrJones_CMR:
    Solstice GXP = FP
    Eliminating the 16" dia. wheel penalty has been put out for member comment ....
    The idea of a 1900 - 2000 lb RX-8 is tempting too
    EDIT: ok, you saw it already ....
    Don't forget the 52mm inlet restrictor  Wink
  •  07-04-2009, 8:15 AM 367887 in reply to 366471
    Solstice with turbo sounds like a good combo.
    I have been on a mission with my 2.5 liter Boxster to make it a prepared car.  Its an FP car that I run in XP.  While down on power it moves pretty well.  I use 15x7" wheels with cantilever slicks.  I have the weight down to under 2275 lbs now and have goal to get it under 2000 lbs.  Lots of fiberglass available for Boxsters now - front hood and rear trunk lid are carbonfiber now.  I battle with lopping winsheild off too.  for now I'm leaving it on as I like to hillclimb and bring car to the track with the aluminum top on.   With Short 23" slicks I have a gearing issue that I'm trying to resolve but the Boxster is very quick for a 200 HP car with a small displacement motor. However  I certainly think a Solstice with turbo would have an advantage over my car and others even if it carried a little more weight.
    Grant
    99 Boxster FP/XP
  •  07-21-2009, 10:41 AM 370471 in reply to 367887
    Solstice turbo should be quite fun. Between this, the Z-cars and the EVO 8/9 (below) it should be a great class.
    Terry Fair - www.vorshlag.com
    $2010 GRM Challenge E30 V8 + E46 DSP Autox Build
